我尝试使用GYFX3BOOTGPIFSMART函数在SRAM示例中启动GPIF MasHin。在调试模式CYU3PGPIFLoad函数返回状态值=0,但CYFX3BOOTGPIFSMSTART函数返回值=68。如何修复这个错误?错误代码描述在哪里?
以上来自于百度翻译 以下为原文 I tried to start GPIF mashine as in SRAM example using CyFx3BootGpifSMStart function. In debug mode CyU3PGpifLoad function return status value = 0 but CyFx3BootGpifSMStart function return value = 68. How can I fix this error? Where is error code discriptions? |
你好,
上述错误说明: 未配置CyuU3PyErrRoNoxLoad配置的/**lt对象/模块。*/ (在C:程序文件(X86) EX-FX3SDK 1.3固件 FX3YSDK11Y33YSRCSDKSDK固件包含CYU3Err.H.H”中,可以在“C:程序文件(x86) CyPress EZ-USB FX3 SDK 1.3固件 FX3YSDK11Y33YSRC FX3固件 BooToFFLBSRCCYFX3PI)中引用该API的源代码。B.C) 似乎没有配置GPIF。请将您的固件与GPIF状态机设计一起共享,以便我们可以在这里调试它。 感谢和问候 阿比纳夫 以上来自于百度翻译 以下为原文 Hi, The above error states that: CY_U3P_ERROR_NOT_CONFIGURED, /**< Object/module referred to has not been configured. */ (This error is defined in "C:Program Files (x86)CypressEZ-USB FX3 SDK1.3firmwarefx3_sdk_1_3_3_srcsdkfirmwareincludecyu3error.h".You can refer to the source code of this API in "C:Program Files (x86)CypressEZ-USB FX3 SDK1.3firmwarefx3_sdk_1_3_3_srcFX3firmwareboot_fwlibsrccyfx3pib.c) It seems that GPIF is not configured. Could you please share your firmware along with GPIF state machine design so that we can try to debug it here. Thanks & Regards Abhinav |
759个成员聚集在这个小组
加入小组2151 浏览 1 评论
1897 浏览 1 评论
3718 浏览 1 评论
1828 浏览 6 评论
1574 浏览 1 评论
778浏览 2评论
534浏览 2评论
482浏览 2评论
443浏览 2评论
1138浏览 2评论
GMT+8, 2025-2-23 10:46 , Processed in 0.984886 second(s), Total 77, Slave 61 queries .
