51单片机控制 舵机 为什么不转?
#include #define Red_duankou P1 //红外检测的信号端 #define led P2 //小灯 检测红外检测是否工作 正常 ***it Control_Port = P0^0; //给舵机输入信号 unsigned char PWM = 15; //初始值 脉宽 1.5ms unsigned int Cheek_time_50ms; void Time0_Init() { TMOD |= 0X01; TH0 = (65536-100)/256; // 0.1 ms TL0 = (65536-100)%256; EA = 1; ET0 = 1; TR0 = 1; } unsigned char RED_Cheek() //检测黑线在哪 { unsigned char RESULT,Red; Red = Red_duankou; Red = Red & 0X1F; switch (Red) { case 0X01: RESULT = 1;break;// 000 00001 最大右拐 case 0X02: RESULT = 2;break;// 000 00010 较小右拐 case 0X04: RESULT = 3;break;// 000 00100 中间位置 case 0X08: RESULT = 4;break;// 000 01000 较小左拐 case 0X10: RESULT = 5;break;// 000 10000 最大左拐 } return RESULT; } void main () { unsigned char input; Time0_Init(); while(1) { if (Cheek_Time_50ms >= 500) { Cheek_Time_50ms = 0; input = RED_Cheek(); switch(input) { case 1: PWM = 6; led= 0xfe; break; case 2: PWM = 10; led= 0xfd; break; case 3: PWM = 15; led= 0xfb; break; case 4: PWM = 19; led= 0xf7; break; case 5: PWM = 23; led= 0xef; break; } } } } void TIME0() interrupt 1 { unsigned int counter = 0; TH0 = (65536-100)/256; // 0.1 ms TL0 = (65536-100)%256; Cheek_Time_50ms++; Control_Port = (counter < PWM)? 1 : 0; counter ++; if (counter >= 200) //一个周期20ms counter = 0; } |
644 浏览 0 评论
求助一下关于51系列单片机的Timer0的计时问题,TH0、TL0+1的时间是怎么算的?
1819 浏览 1 评论
【RA-Eco-RA4E2-64PIN-V1.0开发板试用】开箱+Keil环境搭建+点灯+点亮OLED
1262 浏览 0 评论
【敏矽微ME32G070开发板免费体验】使用coremark测试敏矽微ME32G070 跑分
1136 浏览 0 评论
【敏矽微ME32G070开发板免费体验】开箱+点灯+点亮OLED
1357 浏览 2 评论
12025 浏览 31 评论
GMT+8, 2024-12-24 07:39 , Processed in 0.392738 second(s), Total 37, Slave 30 queries .
