LSM9DS1数据表显示加速度计/陀螺仪模块的两个中断可配置为漏极开路或推/拉。但是,我错过了磁力计模块中断的描述。我认为这意味着它是固定的,不能由用户配置。它是固定为开漏型还是推/拉型?
#interrupts#lsm9ds1#push-pull-output-or-open-drain-output 以上来自于谷歌翻译 以下为原文 The LSM9DS1 data sheet shows that the accelerometer/gyroscope module's two interrupts can be configured either as open-drain or push/pull. However, I am missing the description of the magnetometer module's interrupt. I assume that means it is fixed and cannot be user-configured. Is it fixed as open-drain type, or as push/pull type? #interrupts #lsm9ds1 #push-pull-output-or-open-drain-output |
3个回答
DRDY_M(磁传感器数据就绪)引脚为推挽式,具有高电平有效。
以上来自于谷歌翻译 以下为原文 The DRDY_M (Magnetic sensor data ready) pin is push-pull, with active high level. |
谢谢,这有帮助。但我实际上是在询问磁力计中断,Pin 10,INT_M。我在数据表中找不到任何东西,说它是推拉还是开漏。有效电平(高/低)可以用软件配置,但不能显示输出类型。你知道它是哪个吗?
以上来自于谷歌翻译 以下为原文 Thanks, that helps. But I was actually asking about the magnetometer interrupt, Pin 10, INT_M. I couldn't find anything in the data sheet saying whether it's push-pull or open drain. The active level (high/low) can be configured in software but not, apparently, the output type. Do you know which it is? |
2987 浏览 1 评论
3318 浏览 1 评论
1895 浏览 1 评论
3754 浏览 6 评论
6169 浏览 21 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
62浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
63浏览 5评论
97浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
62浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
61浏览 5评论
GMT+8, 2025-4-9 11:50 , Processed in 0.836777 second(s), Total 81, Slave 65 queries .
