我在使用LSM9DS0 iNEMO惯性模块进行i2c通信时遇到了麻烦。我已将它连接起来,但它没有响应who_am_i读取请求。我已经将SDO连接到1,所以使用默认的i2c地址0x3A,但我没有得到从机ACK信号。出于绝望,想知道我的地址是否错误,我查了每个i2c地址,但仍然没有发现任何响应。我尝试过100 kHz和400 kHz,结果相同。我也连接了不同的i2c传感器,它们工作正常,所以我知道我的其余部分工作。是否有任何技巧让i2c工作?
以上来自于谷歌翻译 以下为原文 I'm having trouble getting i2c communications working with LSM9DS0 iNEMO inertial module. I've wired it up, but it isn't responding to who_am_i read request. I've wired SDO to 1, so am using your default i2c address 0x3A, but I'm getting no slave ACK signals. Out of desperation wondering if I had the address wrong I pinged every i2c address, and still found no response. I've tried 100 kHz and 400 kHz, same result. I've also wired different i2c sensors, and they work fine, so I know the rest of my board works. Are there any tricks getting i2c to work? |
5个回答
焊接不好,让i2c使用陀螺仪,加速度计仍然没有运气...
以上来自于谷歌翻译 以下为原文 bad soldering, got i2c working with gyro, still no luck with accelerometer... |
你好克里斯,
我目前正在验证您的主题的答案。 如果您有任何进展或有任何其他问题,请告诉我。 谢谢, 蒂亚戈雷斯 以上来自于谷歌翻译 以下为原文 Hello Chris, I am currently verifying an answer for your topics. Please let me know if you have any advance or have any other questions. Thank you, Thiago Reis |
我也有同样的问题陀螺仪工作但加速度计不工作,有没有办法检查是硬件问题或软件问题或焊接问题
以上来自于谷歌翻译 以下为原文 Me too have the same problem gyro is working but accelerometer is not working, is there any way to check whether it is a hardware problem or software problem or soldering problem |
它仍然是两块板上的焊接问题......:S
以上来自于谷歌翻译 以下为原文 It still was a soldering problem on both boards... :S |
2747 浏览 1 评论
3244 浏览 1 评论
1813 浏览 1 评论
3655 浏览 6 评论
6044 浏览 21 评论
1342浏览 4评论
204浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
359浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
449浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
276浏览 2评论
GMT+8, 2024-12-29 00:22 , Processed in 0.959231 second(s), Total 85, Slave 69 queries .
