嗨,
我们希望通过Citrix为用户提供远程访问,因此将在用户的机柜机器上安装VDA + HDX 3d PRO。 我们的大多数机器都配有NVIDIA k2200,k2000或NVS 310.Ks和NVS之间存在很大差异。 您是否会在所有卡上安装带有HDX 3D Pro的VDA,还是应该在NVS上安装常规VDA? 如果您有使用Remote PC + HDX 3d pro的经验,请查看P1000和P2000,但需要您的建议,请分享任何链接 谢谢 以上来自于谷歌翻译 以下为原文 Hi, We want to provide our users with Remote Access via Citrix so will be installing the VDA + HDX 3d PRO on user's cubicle machines. Most of our machines have NVIDIA k2200, k2000 or NVS 310. There is a big difference between the Ks and the NVS. Would you install VDA with HDX 3D Pro on all cards or should I install regular VDA on NVS? Also looking at the P1000 and P2000 but wanted your advice if you have experience with Remote PC + HDX 3d pro and please share any links Thanks |
嗨,mostro,
你在做什么与虚拟GPU无关。 这只是物理工作站上的Citrix远程处理。 当然,Quadro和NVS之间存在很大差异。 顺便说一句,Citrix最新的VDA中没有HDX3D Pro安装程序,所以不确定您期望的响应。 问题或多或少是您想要实现的以及您正在运行的应用程序,因此您应该使用一个或另一个远程协议。 如果没有更多详细信息,您将无法获得有用的响应。 问候 西蒙 以上来自于谷歌翻译 以下为原文 Hi mostro, what you are doing has nothing to do with virtual GPU. This is just a Citrix remoting on a physical workstation. For sure there is a big difference between Quadro and NVS. BTW there is no HDX3D Pro installer any more in the latest VDAs from Citrix so not sure which response you are expecting. The question is more or less what you want to achieve and which applications you are running so you should use the one or the other remoting protocol. Without having more details you won't get a useful response. Regards Simon |
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3129 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3539 浏览 4 评论
GMT+8, 2024-12-25 11:02 , Processed in 0.434656 second(s), Total 45, Slave 39 queries .
