嗨,我一直在使用85070E同轴探头和E5072A矢量网络分析仪进行半固体材料的介电表征,特别是像明胶或果冻这样的凝胶。
我的问题是S~11~参数高度依赖于凝胶表面上施加的压力,由于材料的变形,所以我不知道我是否得到样品的“真实”介电常数。 我认为最好的解决方案是在不破坏凝胶的情况下按压最大值以避免探针和凝胶表面之间的气隙,但它可以改变凝胶密度,从而改变其介电性能。 有谁知道如何解决问题或使用半固体? 谢谢,sercaspa 以上来自于谷歌翻译 以下为原文 Hi, I've been working with the 85070E coaxial probe and the E5072A vector network analyzer for dielectric characterization of semisolid materials, specifically gels like gelatin or jelly. My problem is that S ~11~ parameters are highly dependent on the applied pressure over the gel surface, due to the deformation of the material, so I don't know if I'm getting the "real" permittivity of the sample. I thought that the best solution is to press the maximum without breaking the gel in order to avoid air gap between the probe and the gel surface, but it could change the gel density and thus its dielectric properties. Does anyone know how to solve the problem or has worked with semisolids? Thanks, sercaspa |
3个回答
> {quote:title = sercaspa写道:} {quote}>嗨,>>我一直在使用85070E同轴探头和E5072A矢量网络分析仪进行半固体材料的介电特性分析,特别是像明胶或果冻这样的凝胶。
我的问题是S~11~参数高度依赖于凝胶表面施加的压力,由于材料的变形,我前几天看到你的问题,但没有回应,因为我对此知之甚少。 但我知道日本开发阻抗分析仪的人在这些论坛上看起来并不活跃。 但我偶然发现了一个可能对你有帮助的参考资料。 它的应用笔记5966-1926E Agilent 4291B射频阻抗/材料分析仪第一部分介绍平行板方法,然后讨论粗糙表面。 我不知道是否有任何帮助,但值得一看。 DaveEdited:drkirkby于2015年12月12日下午9:22 以上来自于谷歌翻译 以下为原文 > {quote:title=sercaspa wrote:}{quote} > Hi, > > I've been working with the 85070E coaxial probe and the E5072A vector network analyzer for dielectric characterization of semisolid materials, specifically gels like gelatin or jelly. My problem is that S ~11~ parameters are highly dependent on the applied pressure over the gel surface, due to the deformation of the material, I see your question the other day, but did not respond as I know very little about this. But I do know that the people in Japan developing the impedance analyzers don't appear very active on these forums. But I stumbled across a reference which might help you. It's application note 5966-1926E Agilent 4291B RF Impedance / Material Analyzer The first section introduces the parallel plate method, then goes onto talk about rough surfaces. I don't know if it any help, but it might be worth a look. Dave Edited by: drkirkby on Dec 12, 2015 9:22 PM |
我在处理土壤样本时遇到了类似的问题。
我遵循尼尔森的论文中的建议,他建立了一个力量监测系统。 我建立了一个几乎相同的系统,以便我可以在样本上持续使用相同的力。 这不能回答正确力量的问题,只是如何保持一致。 我认为您将不得不尝试找到一个您认为可以接受的值,并将它用于每次测量。 在这方面,固体和液体更容易处理。 Nelson,Stuart O.,2012,威廉希尔官方网站 说明:用于介电特性测量的同轴探针接触力监测,农业应用工程,v28,n1,pp149-152 以上来自于谷歌翻译 以下为原文 I have dealt with a similar issue when using soil samples. I have followed the suggestions in the paper by Nelson where he built a force monitoring system. I built an almost identical system so that I can consistently use the same force on the sample. This doesn't answer the question of the correct force, just how to be consistent. I think you will have to experiment to find a value that you find acceptable and they use that for every measurement. Solids and liquids are much easier to deal with in this regard. Nelson, Stuart O., 2012, Technical Note: Coaxial-Probe Contact-Force Monitoring for Dielectric Properties Measurement, Applied Engineering in Agriculture, v28, n1, pp149-152 附件
非常感谢你们两位的答案!
关于drkirkby,平行板方法与开放式同轴方法完全不同,因为它首先是基于电容测量而最后是基于反射系数,所以我不知道是否有力 应用于样本以相同的方式影响。 我希望我可以尝试这种方法来比较,也许这是一种更好的方法来测量半固体。 关于ryanenorth,这是一个很好的解决方案,可确保可重复性并注意随时间的变化或类似样品之间的差异。 我担心施加的力的影响在不同的材料之间是不一样的。 此外,我会不确定样本的实际价值,这是我感兴趣的。 目前,我将继续使用探头施加最大可能的力而不会破坏它。 我相信这是空气去除的最佳近似值。 以上来自于谷歌翻译 以下为原文 Thank you very much to you both for the answers! With regard to drkirkby, the parallel plate method is quite different from the open-ended coaxial method, inasmuch as it the first is based on the capacitance measurement and the last is based on the reflection coefficient, so I don't know if the force applied to the sample affects in the same way. I wish I could try this method in order to compare, maybe it's a better method to measure semisolids. With respect to ryanenorth, this is a nice solution for ensuring repeatability and noting changes over time or differences between similar samples. I fear that the influence of the applied force won't be the same between diferrent materials. Moreover, I would keep the uncertainty to the real value of the sample, which is of interest to me. For the moment I will continue applying the maximum possible force with the probe without breaking it. I believe it's the best approximation due to the air removing. |
924 浏览 0 评论
2214 浏览 1 评论
1997 浏览 1 评论
1865 浏览 5 评论
2733 浏览 3 评论
715浏览 1评论
515浏览 0评论
605浏览 0评论
2397浏览 0评论
1446浏览 0评论
GMT+8, 2024-8-25 07:54 , Processed in 1.244670 second(s), Total 80, Slave 64 queries .
