亲爱的先生,我使用的是E5071C,300 KHz到14 GHz的VNA。
当我使用保存的跟踪数据时,我只得到相应频率的幅度。 Q1。 如何以复杂的形式(实数和虚数)保存S参数。 Q2。 如何将S参数保存为图像。 以上来自于谷歌翻译 以下为原文 Dear Sir, I am using E5071C, 300 KHz to 14 GHz VNA. When i have use saved trace data, i got only magnitude to the corresponding frequencies. Q1. How to save S-parameters in complex form (real and imaginary). Q2. How to save S-parameters as image. |
4个回答
我不知道该分析器,但必须有一种方法来保存一个扩展名为.s1p或.s2p的Touchstone文件。
我会认为如何保存这样的文件是相当明显的,因为它可能在文件菜单上,但可能很难找到,所以你可能必须阅读手册以了解如何保存Touchstone文件。 Touchstone文件的格式可以在网上找到。 如果你找不到它,那么你将不得不寻求知识分析器的人的帮助,但我想我会发布这个,希望它可以帮助你之前有更多知识渊博的回复。 在撰写本文时,我希望能够支持仪器的大多数Keysight人员都睡着了! 戴夫。 以上来自于谷歌翻译 以下为原文 I don't know that analyser, but there must be a way to save a Touchstone file which will have the extension .s1p or .s2p. I would have thought it fairly obvious how to save such a file, as it's probably on the File menu, but it could conceivably be hard to find, so you might have to read the manual to find out how to save the Touchstone file. The format of the Touchstone file can be found on to web. If you can't find it, then you will have to seek the help of someone knowledgable with what analyser, but I thought I would post this, in the hope it might help you before someone more knowledgeable replies. At the time of writing, I would expect most of the Keysight people supporting the instruments to be asleep! Dave. |
复杂形式的S参数数据可以通过[保存/调用]> [保存SnP]> [S1P ...]保存在试金石格式中。
在保存数据之前,需要通过[保存/调用]> [保存SnP]> [实/虚]将试金石格式更改为复杂形式。 有关详细信息,请访问以下网站:http://ena.support.keysight.com/e5071c/manuals/webhelp/eng/measurement/data_output/saving_trace_data_to_a_file.htm#Saving_data_in_Touchstone_format通过[系统]>转储屏幕图像保存屏幕图像 ]如http://ena.support.keysight.com/e5071c/manuals/webhelp/eng/measurement/data_output/saving_the_screen_image_to_a_file.htm所述 以上来自于谷歌翻译 以下为原文 The S parameter data with complex form can be saved in the touchstone format through [save/recall]>[Save SnP]>[S1P….]. You need to change the touchstone format to complex form through [save/recall]>[Save SnP]>[ Real/Imaginary] before the data is saved. More information is available in the following website http://ena.support.keysight.com/e5071c/manuals/webhelp/eng/measurement/data_output/saving_trace_data_to_a_file.htm#Saving_data_in_Touchstone_format You save the screen image by [System]>Dump Screen Image] as described at http://ena.support.keysight.com/e5071c/manuals/webhelp/eng/measurement/data_output/saving_the_screen_image_to_a_file.htm |
CHENYUHENG 发表于 2018-9-26 08:01 亲爱的先生,谢谢你的回复。 我试图用给定的指令以csv格式保存跟踪。 但是当我在Matlab中导入它时,我只得到实部和虚部值为零。 我附上了我用过的文件。 Kinldy建议以哪种格式保存数据,因为我对复杂数据感兴趣。 以上来自于谷歌翻译 以下为原文 Dear Sir, Thanks for your reply. I have tried to save the trace in csv format with the given instructions. But when i import it in Matlab, i get only real part and imaginary part value is zero. I am attaching the file i have used. Kinldy suggest in which format the data should be saved as i am interested in complex data. 附件
> {quote:title = ANG001写道:} {quote}>尊敬的先生,>谢谢你的回复。 我试图用给定的指令以csv格式保存跟踪。 但是当我在Matlab中导入它时,我只得到实部和虚部值为零。 我附上了我用过的文件。 Kinldy建议以哪种格式保存数据,因为我对复杂数据感兴趣。 “很快”,谁是Keysight员工,给了你一个链接http://ena.support.keysight.com/e5071c/manuals/webhelp/eng/measurement/data_output/saving_trace_data_to_a_file.htm#Saving_data_in_Touchstone_format,了解有关保存_Touchstone_的信息 文件。 您附加的CSV文件不是* Touchstone文件。 如果你按照链接上的说明很快给你,那么你应该得到一个与下面大致相似但肯定不相同的文件。 这是使用我自己编写的软件在旧的HP 8720D上创建的。 但基本的一点是我的文件符合Touchstone规范,并且它具有幅度和相位数据。 您可以轻松地将该文件读入OpenOffice,Excell或任何其他合理的电子表格。 确保将列表分隔符设置为空格,而不是逗号或制表符。 Touchstone文件的不同格式在链接+很快+也给你。 以dB为单位的幅度和以度为单位的角度的格式是最常见的,但还有其他格式。 但是这一切都记录在你给出的链接中。 为什么不保存Touchstone文件,尝试自己解决,如果仍然卡住,请发布Touchstone文件? 戴夫! 这是一个Touchstone .s1p格式文件! 它被称为S11,即使从端口2收集,尽管这是从端口1收集的。 ! 它应该以.s1p扩展名保存! HEWLETT PACKARD,8720D,0,7.74! 日期= 2015年12月11日! 时间= 21:44:50! 起始频率= 0.050000000 GHz! 停止频率= 2.000000000 GHz! IF带宽= 100 Hz! 平滑=关闭! 平滑apeture = 1.000000%! 平均=关! 平均因子= 16! 源功率=开! 源功率=自动模式! 输出功率等级= 5.000000 dBm! 回力=关! 测试组切换=连续! 测试组切换的扫描次数(0 =保持,1 =连续,2-999 =扫描次数)= 1! 步骤扫描=开(检查)! 列表频率扫描=关闭(检查)! 清单列表模式下列表频率表的IFBW设置=禁用(检查)! 扫描列表模式下列表频率表的功率设置=禁用(检查)! 测量模式=印章A和B! 端口扩展= OFF! 端口扩展1 = 0.000000 ps! 端口扩展2 = 0.000000 ps! 积分= 401! 校准套件= 3.5 mm D! 校准= S11 1端口! 功率= 5.000000 dBm! freq magS11 angS11! 记录形式的大小! 角度以度为单位 #MHz S DB R 50 50.00000 -60.49609 -79.70312 54.87500 -58.95508 -79.62891 59.75000 -57.47461 -79.30859 64.62500 -56.93164 -82.45312 69.50000 -56.93555 -76.79297 74.37500 -56.41602 -81.92969 79.25000 -55.53320 -85.58984 84.12500 -54.59961 - 82.53516 89.00000 -54.41016 -83.92969 93.87500 -54.24609 -85.08984 98.75000 -53.64062 -86.23047 1975.62500 -32.82422 -165.03125 1980.50000 -32.82812 -165.25000 1985.37500 -32.82422 -165.35938 1990.25000 -32.83203 -165.57031 1995.12500 -32.83789 -165.74219 2000.00000 -32.83398 -165.90625编辑:drkirkby 在2016年3月16日上午10:09 以上来自于谷歌翻译 以下为原文 > {quote:title=ANG001 wrote:}{quote} > Dear Sir, > Thanks for your reply. I have tried to save the trace in csv format with the given instructions. But when i import it in Matlab, i get only real part and imaginary part value is zero. I am attaching the file i have used. Kinldy suggest in which format the data should be saved as i am interested in complex data. " soon", who is one the Keysight staff, gave you a link http://ena.support.keysight.com/e5071c/manuals/webhelp/eng/measurement/data_output/saving_trace_data_to_a_file.htm#Saving_data_in_Touchstone_format for information about saving a _Touchstone_ file. The CSV file you attach is *not* a Touchstone file. If you follow the instructions at the link soon gave you, then you should end up with a file broadly similar, but certainly not identical, to that below. This was created on an old HP 8720D using software I wrote myself. But the basic point is that my file conforms to the Touchstone specification and that it has magnitude and phase data. You can easily read that file into OpenOffice, Excell, or any other half-reasonable spreadsheet. Make sure to set the list separator as a space, and not a comma or tab. The different formats of the Touchstone file is in the link +soon+ gave you too. The format with magnitudes in dB and angles in degrees is the most common, but there are others. But it is all documented in the link you were given. Why don't you save a Touchstone file, try to work it out yourself, and if you are still stuck, post your Touchstone file? Dave ! This is a Touchstone .s1p format file ! It is called S11, even if collected from port 2, although this was collected from port 1 anyway. ! It should be saved with .s1p extension ! HEWLETT PACKARD,8720D,0,7.74 ! Date = 11 Dec 2015 ! Time = 21:44:50 ! Start frequency = 0.050000000 GHz ! Stop frequency = 2.000000000 GHz ! IF bandwidth = 100 Hz ! Smoothing = OFF ! Smoothing apeture = 1.000000 % ! Averaging = OFF ! Averaging factor = 16 ! Source power = On ! Source power = Auto mode ! Output power level = 5.000000 dBm ! Retrace power = Off ! Testset switching = Continuous ! Number of sweeps for test set switching (0=hold, 1=continuous,2-999 = number of sweeps) = 1 ! Step sweep = On (check) ! List frequency sweep = Off (check) ! IFBW setting for a list-frequency table in swept list mode = Disabled (Check) ! Power setting for a list-frequency table in swept list mode = Disabled (Check) ! Measurement mode = Chop A and B ! Port extensions = OFF ! Port extension 1 = 0.000000 ps ! Port extension 2 = 0.000000 ps ! Points = 401 ! Calibration kit = 3.5 mm D ! Calibration = S11 1-port ! Power = 5.000000 dBm ! freq magS11 angS11 ! Magnitudes are in log form ! Angles are in degrees # MHz S DB R 50 50.00000 -60.49609 -79.70312 54.87500 -58.95508 -79.62891 59.75000 -57.47461 -79.30859 64.62500 -56.93164 -82.45312 69.50000 -56.93555 -76.79297 74.37500 -56.41602 -81.92969 79.25000 -55.53320 -85.58984 84.12500 -54.59961 -82.53516 89.00000 -54.41016 -83.92969 93.87500 -54.24609 -85.08984 98.75000 -53.64062 -86.23047 1975.62500 -32.82422 -165.03125 1980.50000 -32.82812 -165.25000 1985.37500 -32.82422 -165.35938 1990.25000 -32.83203 -165.57031 1995.12500 -32.83789 -165.74219 2000.00000 -32.83398 -165.90625 Edited by: drkirkby on Mar 16, 2016 10:09 AM |
1333 浏览 0 评论
2397 浏览 1 评论
2216 浏览 1 评论
2086 浏览 5 评论
2974 浏览 3 评论
1238浏览 1评论
784浏览 0评论
1035浏览 0评论
1335浏览 0评论
GMT+8, 2025-1-13 20:10 , Processed in 1.233158 second(s), Total 48, Slave 43 queries .
