我有一个带有OPT 1EA高功率(SN3537A01391)的8648C,它的A10频率很差。
分机。 Asy(08648-60040)看来输出放大器IC(金盖子用4个艾伦帽螺丝固定到位)。 有没有人知道这部分是否可用,或者是否有人将一个拥有该模块的单元分开。 还可以在此发生器中使用其他A10模块(可能是没有1EA功能的模块)吗? 有人修理或更换这些吗? 这是我的火腿小屋所以我的预算有限(我这样做了)。 因此,如果有人有任何建议,他们将不胜感激。 Sam W3OHM 以上来自于谷歌翻译 以下为原文 I have a 8648C with OPT 1EA High Power (SN3537A01391) that has a bad A10 Freq. Ext. Asy (08648-60040) it appears that the output amplifier IC (the one with the gold lid that is held in place with 4 allen cap screws). Does anyone know if this part is available or is anyone parting out a unit that would have this module. Also is it possible to use other A10 modules (perhaps one that does not have the 1EA feature) in this generator? Does anyone repair or exchange these anymore? This is from my ham shack so I have a limited budget to repair (I got it this way). So if anyone has any suggestions they would be greatly appreciated. Sam W3OHM |
3个回答
亲爱的Sam,您是否找到了8648 RF发生器中坏放大器的解决方案?
我问这个是因为我的8648B也有同样的失败。 互联网上几乎没有关于1GG3-4202的信息。 最好的问候,弗兰克 以上来自于谷歌翻译 以下为原文 Dear Sam, Did you found a solution for the bad amplifier in the 8648 RF generator? I ask this because my 8648B has the same failure. There is almost no information on the internet about the 1GG3-4202. Best regards, Frank |
该部分绝对不是Keysight提供的。
1GGx前缀表示它是Keysight制造的专有部件。 不幸的是,A10的低输出是最常见的故障之一,因此废料单元可能会出现同样的问题。 以上来自于谷歌翻译 以下为原文 That part is definitely not available from Keysight. The 1GGx prefix indicates it is a proprietary Keysight-manufactured part. Unfortunately low output from the A10 was one of the most common failures, so scrap units may have the same issue. |
山川1998 发表于 2018-9-26 11:55 谢谢你的信息。 以上来自于谷歌翻译 以下为原文 Thank you kindly for the information. |
1652 浏览 0 评论
2585 浏览 1 评论
2460 浏览 1 评论
2307 浏览 5 评论
3246 浏览 3 评论
1059浏览 0评论
1653浏览 0评论
249浏览 0评论
GMT+8, 2025-8-7 12:38 , Processed in 0.645067 second(s), Total 75, Slave 59 queries .
