我正在设计一个USB 3集线器。因为我只使用3个端口,我能用来自主机VBUS的5V来驱动系统,而不需要外部电源吗?显然,5V将进入电压调节器,以获得3.3V和1.2V的IC。
以上来自于百度翻译 以下为原文 I am designing an USB 3.0 hub. Since I will use just 3 ports is can I power the system using the 5V coming from the VBUS of the host without needing an external power source? Obviously the 5V will go in voltage regulator to obtain the 3.3V and 1.2V for the IC. |
你好,
首先,来自主机的VBUS(5V)是轮毂检测非嵌入式集线器的连接/断开状态所必需的。 从VBUS获得3.3V和1.2V是可能的,但是它可以为HX3 IC供电,但不能为下游连接的设备提供足够的功率。因此,建议使用自供电模式用于USB 3.0集线器。 请参阅HX3数据表中的“功耗”部分:HTTP://www. CyPress .COM/FIL/141031/下载 它列出了HX3在不同情况下的功耗。 为了您的参考,USB 3.0主机只能提供900Ma @ 5V。 问候,阿尼尔 以上来自于百度翻译 以下为原文 Hello, First of all, VBUS (5V) coming from the Host is required for the Hub to detect the connect/disconnect status for non-embedded Hubs. It is possible to obtain 3.3V and 1.2V from VBUS, but it can power HX3 IC but cannot provide sufficient power to the downstream connected devices. So, it is recommended to use self powered Mode for USB3.0 Hubs. Please refer "Power Consumption" section in the HX3 datasheet at http://www.cypress.com/file/141031/download which lists the power consumption of the HX3 in different cases. And for your reference, USB3.0 Host can provide only 900mA@5V. Regards, Anil |
757个成员聚集在这个小组
加入小组2133 浏览 1 评论
1873 浏览 1 评论
3696 浏览 1 评论
1809 浏览 6 评论
1556 浏览 1 评论
752浏览 2评论
505浏览 2评论
465浏览 2评论
416浏览 2评论
1106浏览 2评论
GMT+8, 2025-1-31 15:44 , Processed in 0.706664 second(s), Total 44, Slave 39 queries .
