你好-我已经成功下载并运行了SNIP扫描,然后我改变了我的调试器,不能退出它。我得到了下面的错误-任何帮助都是值得赞赏的,我没有寻找确切的答案,也许指向我能在哪里找出我错了。谢谢您!
注意:在Windows W/NO虚拟机上运行。 正在下载引导加载程序… 该进程无法访问文件,因为该文件正在被另一进程使用。 “***OpenOCD失败了——确保您已经从驱动程序目录中安装了驱动程序,并且调试器没有在Linux中运行***,这可能是由于USB访问权限。在虚拟机中,可能是由于USB通过设置。检查另一个OpenOCD进程没有运行的任务列表。检查是否有正确的目标和JTAG设备插在。****** 进程无法访问文件,因为另一个进程正在使用它。 下载DCT… 进程无法访问文件,因为另一个进程正在使用它。 进程无法访问文件,因为另一个进程正在使用它。 “**** OpenOCD失败-确保您已安装的驱动程序的驱动程序的目录,并且调试器运行不*** Linux,这可能是由于USB的访问权限。在一个虚拟机,这可能是由于USB直通设置。检查另一个OpenOCD进程没有运行的任务列表。检查是否有正确的目标和JTAG设备插在。****** 下载应用程序… 进程无法访问文件,因为另一个进程正在使用它。 “**** OpenOCD失败-确保您已安装的驱动程序的驱动程序的目录,并且调试器运行不*** Linux,这可能是由于USB的访问权限。在一个虚拟机,这可能是由于USB直通设置。检查另一个OpenOCD进程没有运行的任务列表。检查是否有正确的目标和JTAG设备插在。****** 进程无法访问文件,因为另一个进程正在使用它。 重置目标 进程无法访问文件,因为另一个进程正在使用它。 以上来自于百度翻译 以下为原文 Hello - I have successfully downloaded and ran the snip-scan then I changed my debugger and cant back out of it. I get the following error - any help is appreciated and I am not looking for the exact answer as maybe pointing to where I can figure out where I am going wrong. Thank you! Note - running on windows w/no virtual machine. Downloading Bootloader ... The process cannot access the file because it is being used by another process. "**** OpenOCD failed - ensure you have installed the driver from the drivers directory, and that the debugger is not running **** In Linux this may be due to USB access permissions. In a virtual machine it may be due to USB passthrough settings. Check in the task list that another OpenOCD process is not running. Check that you have the correct target and JTAG device plugged in. ****" The process cannot access the file because it is being used by another process. Downloading DCT ... The process cannot access the file because it is being used by another process. The process cannot access the file because it is being used by another process. "**** OpenOCD failed - ensure you have installed the driver from the drivers directory, and that the debugger is not running **** In Linux this may be due to USB access permissions. In a virtual machine it may be due to USB passthrough settings. Check in the task list that another OpenOCD process is not running. Check that you have the correct target and JTAG device plugged in. ****" Downloading Application ... The process cannot access the file because it is being used by another process. "**** OpenOCD failed - ensure you have installed the driver from the drivers directory, and that the debugger is not running **** In Linux this may be due to USB access permissions. In a virtual machine it may be due to USB passthrough settings. Check in the task list that another OpenOCD process is not running. Check that you have the correct target and JTAG device plugged in. ****" The process cannot access the file because it is being used by another process. Resetting target The process cannot access the file because it is being used by another process. |
3个回答
错误主要是由于驱动程序安装不正确所致。请检查设备管理器窗口。它应该看起来像这样
正如您提到的,您能够成功地运行SNIP.SCAN,但在调试器模式下,您将面临这个问题。相同的一些通用的原因是有时已经调试程序(ARM无EABI GDB)在后台运行。检查您的任务管理器的任何这样的进程,并杀死这些进程启动调试器。另外,您可以按照Re:调试BCM943362WCD4YEVB来正确配置调试器。如果问题仍然存在,请重新回到这个线程上。 以上来自于百度翻译 以下为原文 The error mostly comes due to incorrect driver installation. Please check your device manager window. It should look something like this As you have mentioned that you were able to run snip.scan successfully but in debugger mode you are facing the issue. Some generic reasons for the same is sometimes already debugger process (arm-none-eabi-gdb) runs in background. Check your task manager for any such processes and kill those processes to launch the debugger. Additionally, you can follow Re: Debugging the BCM943362WCD4_EVB to correctly configure the debugger. Please revert back on this thread if the issue persists. |
chm5 发表于 2018-9-26 10:41 知道了。谢谢您! 里克卡蒂埃 775/29—64 以上来自于百度翻译 以下为原文 Got it. Thank you! Rick Cartier 775/297-6417 |
chm5 发表于 2018-9-26 10:41 谢谢分享这个有用的帖子,我会经常跟着博客 外壳冲击器 以上来自于百度翻译 以下为原文 Thanks for sharing this useful post, I will regularly follow blog shell shockers |
775个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
3704 浏览 0 评论
2307 浏览 1 评论
2026 浏览 1 评论
3870 浏览 1 评论
1927 浏览 6 评论
4349浏览 2评论
2876浏览 2评论
588浏览 2评论
566浏览 2评论
4627浏览 2评论
GMT+8, 2025-7-19 06:53 , Processed in 1.106033 second(s), Total 79, Slave 63 queries .
