大家好,
我正在做一个鹰画一个PCB,需要的尺寸和位置的引脚的发展领域的PSoC 5LP发展板。 我想知道是否有一张我可以使用的现有图画。我们的目标是将我的模式直接导入到PSoC鹰绘图中。 请告知。 非常恭敬, 作记号 以上来自于百度翻译 以下为原文 Hello all, I am doing an Eagle drawing for a PCB and need the dimensions and location of the pins of the developmental area of the PSoC 5LP developmental board. I was wondering if there was an existing drawing I could use. The goal is to import my schematic directly into the PSoC Eagle drawing. Please advise. Very Respectfully, Mark |
3个回答
您可以得到的AlelGro韵律兼容的PSoC 5LP开发板的示意性文件,可在这个链接:
HTTP://www. CyPress .COM/DICONTION/Debug -KITSBBOARDS/CY8CKIT-050-PSOC-5LP开发套件 HTTP://www. CyPress .COM/DICONTION/Deavest-KITSBBOARDS/CY8CKIT-059PSOC-5LP原型KIT-OLAND程序员 以上来自于百度翻译 以下为原文 you can get the Allegro Cadence compatible only schematic files of PSoC 5LP developmental board which is available at this link: http://www.cypress.com/documentation/development-kit***oards/cy8ckit-050-psoc-5lp-development-kit http://www.cypress.com/documentation/development-kit***oards/cy8ckit-059-psoc-5lp-prototyping-kit-onboard-programmer-and |
muuwfwr 发表于 2018-9-26 17:50 你好。 当我尝试打开文件时,我收到以下错误: 错误: 第1行,第1栏:预期的开始标记。 你能建议一下吗? 恭敬地, 作记号 以上来自于百度翻译 以下为原文 Hello. When I try to open the file, I receive the following error: Error: line 1, column 1: Start tag expected. Can you please advise? Respectfully, Mark |
您正在尝试打开文件.DSN在哪个工具?鹰不能打开.DSN文件 以上来自于百度翻译 以下为原文 you are trying to open file .dsn in which tool? Eagle can't open the .dsn files |
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1761 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
275浏览 2评论
170浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-21 01:40 , Processed in 0.562569 second(s), Total 48, Slave 43 queries .
