在继《基于qualcomm平台的kinect教程一之windows配置篇》后,我们今天来获取kinect的深度图。
一.核心代码共享
// Copyright (c) Microsoft Corporation. All rights reserved.
#include "Depth-D3D.h"
// Global Variables
CDepthD3D g_Application; // Application class
LRESULT CALLBACK WndProc(HWND, UINT, WPARAM, LPARAM);
/// Entry point for the application
/// handle to the application instance
/// always 0
/// command line arguments
/// whether to display minimized, maximized, or normally
/// status
int WINAPI wWinMain(HINSTANCE hInstance, HINSTANCE hPrevInstance, LPWSTR lpCmdLine, int nCmdShow)
UNREFERENCED_PARAMETER(hPrevInstance);
UNREFERENCED_PARAMETER(lpCmdLine);
if ( FAILED( g_Application.InitWindow(hInstance, nCmdShow) ) )
return 0;
if ( FAILED( g_Application.InitDevice() ) )
return 0;
if ( FAILED( g_Application.CreateFirstConnected() ) )
MessageBox(NULL, L"No ready Kinect found!", L"Error", MB_ICONHAND | MB_OK);
return 0;
// Main message loop
MSG msg = {0};
while (WM_QUIT != msg.message)
if (PeekMessageW(&msg, NULL, 0, 0, PM_REMOVE))
TranslateMessage(&msg);
DispatchMessageW(&msg);
else
g_Application.Render();
return (int)msg.wParam;
/// Handles window messages, passes most to the class instance to handle
/// window message is for
/// message
/// message data
/// additional message data
/// result of message processing
LRESULT CALLBACK WndProc(HWND hWnd, UINT message, WPARAM wParam, LPARAM lParam)
PAINTSTRUCT ps;
g_Application.HandleMessages(hWnd, message, wParam, lParam);
switch( message )
case WM_PAINT:
BeginPaint(hWnd, &ps);
EndPaint(hWnd, &ps);
break;
case WM_DESTROY:
PostQuitMessage(0);
break;
default:
return DefWindowProc(hWnd, message, wParam, lParam);
return 0;
/// Constructor
CDepthD3D::CDepthD3D()
// get resolution as DWORDS, but store as LONGs to avoid casts later
DWORD width = 0;
DWORD height = 0;
NuiImageResolutionToSize(cDepthResolution, width, height);
m_depthWidth = static_cast(width);
m_depthHeight = static_cast(height);
m_hInst = NULL;
m_hWnd = NULL;
m_featureLevel = D3D_FEATURE_LEVEL_11_0;
m_pd3dDevice = NULL;
m_pImmediateContext = NULL;
m_pSwapChain = NULL;
m_pRenderTargetView = NULL;
m_pDepthStencil = NULL;
m_pDepthStencilView = NULL;
m_pVertexLayout = NULL;
m_pVertexBuffer = NULL;
m_PCBChangesEveryFrame = NULL;
m_pVertexShader = NULL;
m_pPixelShader = NULL;
m_pGeometryShader = NULL;
m_xyScale = 0.0f;
// Initial window resolution
m_windowResX = 1280;
m_windowResY = 960;
m_pDepthTexture2D = NULL;
m_pDepthTextureRV = NULL;
m_hNextDepthFrameEvent = INVALID_HANDLE_VALUE;
m_pDepthStreamHandle = INVALID_HANDLE_VALUE;
m_bNeARMode = false;
m_bPaused = false;
for (int i = 0; i < _MaxPlayerIndices; ++i)
m_minPlayerDepth = NUI_IMAGE_DEPTH_MAXIMUM >> NUI_IMAGE_PLAYER_INDEX_SHIFT;
m_maxPlayerDepth = NUI_IMAGE_DEPTH_MINIMUM >> NUI_IMAGE_PLAYER_INDEX_SHIFT;
/// Destructor
CDepthD3D::~CDepthD3D()
if (NULL != m_pNuiSensor)
m_pNuiSensor->NuiShutdown();
m_pNuiSensor->Release();
if (m_pImmediateContext)
m_pImmediateContext->ClearState();
SAFE_RELEASE(m_pCBChangesEveryFrame);
SAFE_RELEASE(m_pGeometryShader);
SAFE_RELEASE(m_pPixelShader);
SAFE_RELEASE(m_pVertexBuffer);
SAFE_RELEASE(m_pVertexLayout);
SAFE_RELEASE(m_pVertexShader);
SAFE_RELEASE(m_pDepthStencil);
SAFE_RELEASE(m_pDepthStencilView);
SAFE_RELEASE(m_pDepthTexture2D);
SAFE_RELEASE(m_pDepthTextureRV);
SAFE_RELEASE(m_pRenderTargetView);
SAFE_RELEASE(m_pSwapChain);
SAFE_RELEASE(m_pImmediateContext);
SAFE_RELEASE(m_pd3dDevice);
CloseHandle(m_hNextDepthFrameEvent);
/// Register class and create window
/// S_OK for success, or failure code
HRESULT CDepthD3D::InitWindow(HINSTANCE hInstance, int nCmdShow)
// Register class
WNDCLASSEX wcex;
wcex.cbSize = sizeof(WNDCLASSEX);
wcex.style = CS_HREDRAW | CS_VREDRAW;
wcex.lpfnWndProc = WndProc;
wcex.cbClsExtra = 0;
wcex.cbWndExtra = 0;
wcex.hInstance = hInstance;
wcex.hIcon = LoadIconW(hInstance, (LPCTSTR)IDI_APP);
wcex.hCursor = LoadCursorW(NULL, IDC_ARROW);
wcex.hbrBackground = (HBRUSH)(COLOR_WINDOW + 1);
wcex.lpszMenuName = NULL;
wcex.lpszClassName = L"DepthD3DWindowClass";
wcex.hIconSm = LoadIconW(wcex.hInstance, (LPCTSTR)IDI_APP);
if ( !RegisterClassEx(&wcex) )
return E_FAIL;
// Create window
m_hInst = hInstance;
RECT rc = { 0, 0, m_windowResX, m_windowResY };
AdjustWindowRect(&rc, WS_OVERLAPPEDWINDOW, FALSE);
m_hWnd = CreateWindow( L"DepthD3DWindowClass", L"Depth-D3D", WS_OVERLAPPEDWINDOW,
CW_USEDEFAULT, CW_USEDEFAULT, rc.right - rc.left, rc.bottom - rc.top, NULL, NULL, hInstance,
NULL );
if (NULL == m_hWnd)
return E_FAIL;
ShowWindow(m_hWnd, nCmdShow);
return S_OK;
/// Handles window messages, used to process input
/// message
/// message data
LRESULT CDepthD3D::HandleMessages(HWND hWnd, UINT uMsg, WPARAM wParam, LPARAM lParam)
m_camera.HandleMessages(hWnd, uMsg, wParam, lParam);
switch(uMsg)
case WM_SIZE:
if (SIZE_MINIMIZED == wParam)
m_bPaused = true;
break;
case WM_ACTIVATEAPP:
if (wParam == TRUE)
m_bPaused = false;
break;
case WM_KEYDOWN:
int nKey = static_cast(wParam);
if (nKey == 'N')
ToggleNearMode();
break;
return 0;
/// Create the first connected Kinect found
/// indicates success or failure
HRESULT CDepthD3D::CreateFirstConnected()
INuiSensor * pNuiSensor;
HRESULT hr;
int iSensorCount = 0;
hr = NuiGetSensorCount(&iSensorCount);
if (FAILED(hr) ) { return hr; }
// Look at each Kinect sensor
for (int i = 0; i < iSensorCount; ++i)
// Create the sensor so we can check status, if we can't create it, move on to the next
hr = NuiCreateSensorByIndex(i, &pNuiSensor);
if (FAILED(hr))
continue;
// Get the status of the sensor, and if connected, then we can initialize it
hr = pNuiSensor->NuiStatus();
if (S_OK == hr)
m_pNuiSensor = pNuiSensor;
break;
// This sensor wasn't OK, so release it since we're not using it
if (NULL == m_pNuiSensor)
return E_FAIL;
// Initialize the Kinect and specify that we'll be using depth
hr = m_pNuiSensor->NuiInitialize(NUI_INITIALIZE_FLAG_USES_DEPTH_AND_PLAYER_INDEX);
// Create an event that will be signaled when depth data is available
m_hNextDepthFrameEvent = CreateEvent(NULL, TRUE, FALSE, NULL);
// Open a depth image stream to receive depth frames
hr = m_pNuiSensor->NuiImageStreamOpen(
NUI_IMAGE_TYPE_DEPTH_AND_PLAYER_INDEX,
NUI_IMAGE_RESOLUTION_640x480,
0,
2,
m_hNextDepthFrameEvent,
&m_pDepthStreamHandle);
// Start with near mode on
ToggleNearMode();
return hr;
/// Toggles between near and default mode
/// Does nothing on a non-Kinect for Windows device
HRESULT CDepthD3D::ToggleNearMode()
HRESULT hr = E_FAIL;
if ( m_pNuiSensor )
hr = m_pNuiSensor->NuiImageStreamSetImageFrameFlags(m_pDepthStreamHandle, m_bNearMode ? 0 : NUI_IMAGE_STREAM_FLAG_ENABLE_NEAR_MODE);
if ( SUCCEEDED(hr) )
m_bNearMode = !m_bNearMode;
return hr;
/// Compile and set layout for shaders
HRESULT CDepthD3D::LoadShaders()
// Compile the geometry shader
ID3D10Blob* pBlob = NULL;
HRESULT hr = CompileShaderFromFile(L"Depth-D3D.fx", "GS", "gs_4_0", &pBlob);
if ( FAILED(hr) ) { return hr; };
// Create the geometry shader
hr = m_pd3dDevice->CreateGeometryShader(pBlob->GetBufferPointer(), pBlob->GetBufferSize(), NULL, &m_pGeometryShader);
SAFE_RELEASE(pBlob);
// Compile the pixel shader
hr = CompileShaderFromFile(L"Depth-D3D.fx", "PS", "ps_4_0", &pBlob);
// Create the pixel shader
hr = m_pd3dDevice->CreatePixelShader(pBlob->GetBufferPointer(), pBlob->GetBufferSize(), NULL, &m_pPixelShader);
// Compile the vertex shader
hr = CompileShaderFromFile(L"Depth-D3D.fx", "VS", "vs_4_0", &pBlob);
// Create the vertex shader
hr = m_pd3dDevice->CreateVertexShader(pBlob->GetBufferPointer(), pBlob->GetBufferSize(), NULL, &m_pVertexShader);
// Define the vertex input layout
D3D11_INPUT_ELEMENT_DESC layout[] = { { "POSITION", 0, DXGI_FORMAT_R16_SINT, 0, 0, D3D11_INPUT_PER_VERTEX_DATA, 0 } };
// Create the vertex input layout
hr = m_pd3dDevice->CreateInputLayout(layout, ARRAYSIZE(layout), pBlob->GetBufferPointer(), pBlob->GetBufferSize(), &m_pVertexLayout);
// Set the input vertex layout
// In this case we don't actually use it for anything
// All the work is done in the geometry shader, but we need something here
// We only need to set this once since we have only one vertex format
m_pImmediateContext->IASetInputLayout(m_pVertexLayout);
return hr;
/// Create Direct3D device and swap chain
HRESULT CDepthD3D::InitDevice()
HRESULT hr = S_OK;
RECT rc;
GetClientRect(m_hWnd, &rc);
UINT width = rc.right - rc.left;
UINT height = rc.bottom - rc.top;
UINT createDeviceFlags = 0;
// Likely won't be very performant in reference
D3D_DRIVER_TYPE driverTypes[] =
D3D_DRIVER_TYPE_HARDWARE,
D3D_DRIVER_TYPE_WARP,
D3D_DRIVER_TYPE_REFERENCE,
UINT numDriverTypes = ARRAYSIZE(driverTypes);
// DX10 or 11 devices are suitable
D3D_FEATURE_LEVEL featureLevels[] =
D3D_FEATURE_LEVEL_11_0,
D3D_FEATURE_LEVEL_10_1,
D3D_FEATURE_LEVEL_10_0,
UINT numFeatureLevels = ARRAYSIZE(featureLevels);
DXGI_SWAP_CHAIN_DESC sd = {0};
sd.BufferCount = 1;
sd.BufferDesc.Width = width;
sd.BufferDesc.Height = height;
sd.BufferDesc.Format = DXGI_FORMAT_R8G8B8A8_UNORM;
sd.BufferDesc.RefreshRate.Numerator = 60;
sd.BufferDesc.RefreshRate.Denominator = 1;
sd.BufferUsage = DXGI_USAGE_RENDER_TARGET_OUTPUT;
sd.OutputWindow = m_hWnd;
sd.SampleDesc.Count = 1;
sd.SampleDesc.Quality = 0;
sd.Windowed = TRUE;
for (UINT driverTypeIndex = 0; driverTypeIndex < numDriverTypes; ++driverTypeIndex)
hr = D3D11CreateDeviceAndSwapChain( NULL, driverTypes[driverTypeIndex], NULL, createDeviceFlags, featureLevels, numFeatureLevels,
D3D11_SDK_VERSION, &sd, &m_pSwapChain, &m_pd3dDevice, &m_featureLevel, &m_pImmediateContext );
break;
if ( FAILED(hr) )
MessageBox(NULL, L"Could not create a Direct3D 10 or 11 device.", L"Error", MB_ICONHAND | MB_OK);
return hr;
// Create a render target view
ID3D11Texture2D* pBackBuffer = NULL;
hr = m_pSwapChain->GetBuffer(0, __uuidof(ID3D11Texture2D), (LPVOID*)&pBackBuffer);
hr = m_pd3dDevice->CreateRenderTargetView(pBackBuffer, NULL, &m_pRenderTargetView);
pBackBuffer->Release();
// Create depth stencil texture
D3D11_TEXTURE2D_DESC descDepth = {0};
descDepth.Width = width;
descDepth.Height = height;
descDepth.MipLevels = 1;
descDepth.ArraySize = 1;
descDepth.Format = DXGI_FORMAT_D24_UNORM_S8_UINT;
descDepth.SampleDesc.Count = 1;
descDepth.SampleDesc.Quality = 0;
descDepth.Usage = D3D11_USAGE_DEFAULT;
descDepth.BindFlags = D3D11_BIND_DEPTH_STENCIL;
descDepth.CPUAccessFlags = 0;
descDepth.MiscFlags = 0;
hr = m_pd3dDevice->CreateTexture2D(&descDepth, NULL, &m_pDepthStencil);
// Create the depth stencil view
D3D11_DEPTH_STENCIL_VIEW_DESC descDSV;
ZeroMemory( &descDSV, sizeof(descDSV) );
descDSV.Format = descDepth.Format;
descDSV.ViewDimension = D3D11_DSV_DIMENSION_TEXTURE2D;
descDSV.Texture2D.MipSlice = 0;
hr = m_pd3dDevice->CreateDepthStencilView(m_pDepthStencil, &descDSV, &m_pDepthStencilView);
m_pImmediateContext->OMSetRenderTargets(1, &m_pRenderTargetView, m_pDepthStencilView);
// Create depth texture
D3D11_TEXTURE2D_DESC depthTexDesc = {0};
depthTexDesc.Width = m_depthWidth;
depthTexDesc.Height = m_depthHeight;
depthTexDesc.MipLevels = 1;
depthTexDesc.ArraySize = 1;
depthTexDesc.Format = DXGI_FORMAT_R32_SINT;
depthTexDesc.SampleDesc.Count = 1;
depthTexDesc.SampleDesc.Quality = 0;
depthTexDesc.Usage = D3D11_USAGE_DYNAMIC;
depthTexDesc.BindFlags = D3D11_BIND_SHADER_RESOURCE;
depthTexDesc.CPUAccessFlags = D3D11_CPU_ACCESS_WRITE;
depthTexDesc.MiscFlags = 0;
hr = m_pd3dDevice->CreateTexture2D(&depthTexDesc, NULL, &m_pDepthTexture2D);
hr = m_pd3dDevice->CreateShaderResourceView(m_pDepthTexture2D, NULL, &m_pDepthTextureRV);
// Setup the viewport
D3D11_VIEWPORT vp;
vp.Width = static_cast(width);
vp.Height = static_cast(height);
vp.MinDepth = 0.0f;
vp.MaxDepth = 1.0f;
vp.TopLeftX = 0;
vp.TopLeftY = 0;
m_pImmediateContext->RSSetViewports(1, &vp);
hr = LoadShaders();
if ( FAILED(hr) )
MessageBox(NULL, L"Could not load shaders.", L"Error", MB_ICONHAND | MB_OK);
return hr;
// Create the vertex buffer
D3D11_BUFFER_DESC bd = {0};
bd.Usage = D3D11_USAGE_DEFAULT;
bd.ByteWidth = sizeof(short);
bd.BindFlags = D3D11_BIND_VERTEX_BUFFER;
bd.CPUAccessFlags = 0;
hr = m_pd3dDevice->CreateBuffer(&bd, NULL, &m_pVertexBuffer);
// Set vertex buffer
UINT stride = 0;
UINT offset = 0;
m_pImmediateContext->IASetVertexBuffers(0, 1, &m_pVertexBuffer, &stride, &offset);
// Set primitive topology
m_pImmediateContext->IASetPrimitiveTopology(D3D11_PRIMITIVE_TOPOLOGY_POINTLIST);
// Create the constant buffers
bd.ByteWidth = sizeof(CBChangesEveryFrame);
bd.BindFlags = D3D11_BIND_CONSTANT_BUFFER;
hr = m_pd3dDevice->CreateBuffer(&bd, NULL, &m_pCBChangesEveryFrame);
// Initialize the projection matrix
m_projection = XMMatrixPerspectiveFovLH(XM_PIDIV4, width / static_cast(height), 0.1f, 100.f);
// Calculate correct XY scaling factor so that our vertices are correctly placed in the world
// This helps us to unproject from the Kinect's depth camera back to a 3d world
// Since the Horizontal and Vertical FOVs are proportional with the sensor's resolution along those axes
// We only need to do this for horizontal
// I.e. tan(horizontalFOV)/depthWidth == tan(verticalFOV)/depthHeight
// Essentially we're computing the vector that light comes in on for a given pixel on the depth camera
// We can then scale our x&y depth position by this and the depth to get how far along that vector we are
const float DegreesToRadians = 3.14159265359f / 180.0f;
m_xyScale = tanf(NUI_CAMERA_DEPTH_NOMINAL_HORIZONTAL_FOV * DegreesToRadians * 0.5f) / (m_depthWidth * 0.5f);
// Set rasterizer state to disable backface culling
D3D11_RASTERIZER_DESC rasterDesc;
rasterDesc.FillMode = D3D11_FILL_SOLID;
rasterDesc.CullMode = D3D11_CULL_NONE;
rasterDesc.FrontCounterClockwise = true;
rasterDesc.DepthBias = false;
rasterDesc.DepthBiasClamp = 0;
rasterDesc.SlopeScaledDepthBias = 0;
rasterDesc.DepthClipEnable = true;
rasterDesc.ScissorEnable = false;
rasterDesc.MultisampleEnable = false;
rasterDesc.AntialiasedLineEnable = false;
ID3D11RasterizerState* pState = NULL;
hr = m_pd3dDevice->CreateRasterizerState(&rasterDesc, &pState);
m_pImmediateContext->RSSetState(pState);
SAFE_RELEASE(pState);
return S_OK;
/// Process depth data received from Kinect
HRESULT CDepthD3D::ProcessDepth()
NUI_IMAGE_FRAME imageFrame;
HRESULT hr = m_pNuiSensor->NuiImageStreamGetNextFrame(m_pDepthStreamHandle, 0, &imageFrame);
INuiFrameTexture* pFrameTexture;
hr = m_pNuiSensor->NuiImageFrameGetDepthImagePixelFrameTexture(m_pDepthStreamHandle, &imageFrame, nullptr, &pFrameTexture);
NUI_LOCKED_RECT LockedRect;
hr = pFrameTexture->LockRect(0, &LockedRect, NULL, 0);
short minPlayerDepthThisFrame[_MaxPlayerIndices];
short maxPlayerDepthThisFrame[_MaxPlayerIndices];
short minDepth = 1;
short maxDepth = SHRT_MAX;
for (int player = 0; player < _MaxPlayerIndices; ++player)
minPlayerDepthThisFrame[player] = maxDepth;
maxPlayerDepthThisFrame[player] = minDepth;
// copy to our d3d 11 depth texture
D3D11_MAPPED_SUBRESOURCE msT;
hr = m_pImmediateContext->Map(m_pDepthTexture2D, NULL, D3D11_MAP_WRITE_DISCARD, NULL, &msT);
memcpy(msT.pData, LockedRect.pBits, LockedRect.size);
m_pImmediateContext->Unmap(m_pDepthTexture2D, NULL);
NUI_DEPTH_IMAGE_PIXEL * pBufferRun = reinterpret_cast(LockedRect.pBits);
NUI_DEPTH_IMAGE_PIXEL * pBufferRunEnd = pBufferRun + LockedRect.size/sizeof(NUI_DEPTH_IMAGE_PIXEL);
while (pBufferRun != pBufferRunEnd)
NUI_DEPTH_IMAGE_PIXEL depthPixel = *pBufferRun++;
if (depthPixel.depth <= maxDepth && depthPixel.depth >= minDepth)
USHORT depth = depthPixel.depth;
USHORT player = depthPixel.playerIndex;
if (depth < minPlayerDepthThisFrame[player])
minPlayerDepthThisFrame[player] = depth;
else if (depth > maxPlayerDepthThisFrame[player])
maxPlayerDepthThisFrame[player] = depth;
hr = pFrameTexture->UnlockRect(0);
hr = m_pNuiSensor->NuiImageStreamReleaseFrame(m_pDepthStreamHandle, &imageFrame);
// perform temporal range smoothing
// these min/max values get passed to the shader
// so it can interpolate over the min and max rather than the full possible range
// this makes detail easier to see
minPlayerDepthThisFrame[player];
maxPlayerDepthThisFrame[player];
const float _LastFrameMinMaxWeight = 9.f;
const float _TotalMinMaxWeight = 10.f;
m_minPlayerDepth[player] = (m_minPlayerDepth[player] * _LastFrameMinMaxWeight + minPlayerDepthThisFrame[player]) / _TotalMinMaxWeight;
m_maxPlayerDepth[player] = (m_maxPlayerDepth[player] * _LastFrameMinMaxWeight + maxPlayerDepthThisFrame[player]) / _TotalMinMaxWeight;
return hr;
/// Renders a frame
HRESULT CDepthD3D::Render()
if (m_bPaused)
return S_OK;
if ( WAIT_OBJECT_0 == WaitForSingleObject(m_hNextDepthFrameEvent, 0) )
ProcessDepth();
// Clear the back buffer
static float ClearColor[4] = { 0.0f, 0.0f, 0.0f, 1.0f };
m_pImmediateContext->ClearRenderTargetView(m_pRenderTargetView, ClearColor);
// Clear the depth buffer to 1.0 (max depth)
m_pImmediateContext->ClearDepthStencilView(m_pDepthStencilView, D3D11_CLEAR_DEPTH, 1.0f, 0);
// Update the view matrix
m_camera.Update();
XMMATRIX viewProjection = XMMatrixMultiply(m_camera.View, m_projection);
// Update variables that change once per frame
CBChangesEveryFrame cb;
cb.ViewProjection = XMMatrixTranspose(viewProjection);
// precalculate the denominator used by the shader and pass it in the z coordinate
float depthRange = m_maxPlayerDepth - m_minPlayerDepth;
float log2DepthRange = log( m_maxPlayerDepth - m_minPlayerDepth ) / log(2.f);
cb.PlayerDepthMinMax = XMVectorSet(m_minPlayerDepth, m_maxPlayerDepth, depthRange, log2DepthRange);
cb.XYScale = XMFLOAT4(m_xyScale, -m_xyScale, 0.f, 0.f);
m_pImmediateContext->UpdateSubresource(m_pCBChangesEveryFrame, 0, NULL, &cb, 0, 0);
// Set up shaders
m_pImmediateContext->VSSetShader(m_pVertexShader, NULL, 0);
m_pImmediateContext->GSSetShader(m_pGeometryShader, NULL, 0);
m_pImmediateContext->GSSetConstantBuffers(0, 1, &m_pCBChangesEveryFrame);
m_pImmediateContext->GSSetShaderResources(0, 1, &m_pDepthTextureRV);
m_pImmediateContext->PSSetShader(m_pPixelShader, NULL, 0);
// Draw the scene
m_pImmediateContext->Draw(m_depthWidth * m_depthHeight, 0);
// Present our back buffer to our front buffer
return m_pSwapChain->Present(0, 0);
二.实测效果图(偷拍这位童鞋勤奋的背影,哈哈!~)
三.例程工程分享:http://pan.baidu.com/s/1i50PWf7
