嗨,
我试图让lsm303c在INT_XL引脚上输出“低电平有效”中断。 这是我的初始代码: void LSM303C_AccInit(void) { uint8_t result = 0; ACCELERO_IO_Write(LSM303C_CTRL_REG1_A,0b00100101); //禁用y轴以避免mg ACCELERO_IO_Write(LSM303C_CTRL_REG2_A,0b00000000); ACCELERO_IO_Write(LSM303C_CTRL_REG3_A,0b00001000); ACCELERO_IO_Write(LSM303C_CTRL_REG4_A,0b00000000); ACCELERO_IO_Write(LSM303C_CTRL_REG5_A,0b00000011); //中断低电平有效,开漏 ACCELERO_IO_Write(LSM303C_FIFO_CTRL,0b01000000); //流模式 ACCELERO_IO_Write(LSM303C_IG_CFG1_A,0b11100010); // y中断禁用 ACCELERO_IO_Write(LSM303C_IG_THS_X1_A,5); ACCELERO_IO_Write(LSM303C_IG_THS_Y1_A,5); ACCELERO_IO_Write(LSM303C_IG_THS_Z1_A,5); ACCELERO_IO_Write(LSM303C_IG_DUR1_A,0b10000001); //中断延迟 } 嵌入式控制器的引脚配置为弱上拉输入。 示波器显示出对加速的良好中断反应,但不是我配置的:没有中断时INT_XL为低电平,但一旦检测到加速度,信号就会变为高电平约40ms然后再次回到低电平状态。 我究竟做错了什么? 谢谢, 吉尔 以上来自于谷歌翻译 以下为原文 Hi, I am trying to get lsm303c output an "active low" interrupt on pin INT_XL. here is my init code: void LSM303C_AccInit(void) { uint8_t result = 0; ACCELERO_IO_Write(LSM303C_CTRL_REG1_A, 0b00100101); // disable y axis to avoid mg ACCELERO_IO_Write(LSM303C_CTRL_REG2_A, 0b00000000); ACCELERO_IO_Write(LSM303C_CTRL_REG3_A, 0b00001000); ACCELERO_IO_Write(LSM303C_CTRL_REG4_A, 0b00000000); ACCELERO_IO_Write(LSM303C_CTRL_REG5_A, 0b00000011); //interrupt active low, open-drain ACCELERO_IO_Write(LSM303C_FIFO_CTRL, 0b01000000); //stream mode, ACCELERO_IO_Write(LSM303C_IG_CFG1_A, 0b11100010); //y interrupt disabled ACCELERO_IO_Write(LSM303C_IG_THS_X1_A, 5); ACCELERO_IO_Write(LSM303C_IG_THS_Y1_A, 5); ACCELERO_IO_Write(LSM303C_IG_THS_Z1_A, 5); ACCELERO_IO_Write(LSM303C_IG_DUR1_A, 0b10000001); //interrupt delay } The embedded controller's pin is configured as input with weak pull up. The oscilloscope shows a good interrupt reaction to acceleration, but not as i configured it: the INT_XL is low when no interrupt, but as soon as there is acceleration detected, the signal goes high for about 40ms and then goes back to low again forever. What am i doing wrong? Thanks, Gil |
以下配置不正确:
ACCELERO_IO_Write(LSM303C_IG_CFG1_A,0b11100010); // y中断禁用 如果需要AND组合,请将AOI位设置为1;如果需要OR,请将其设置为0并设置 6D位为0。 以上来自于谷歌翻译 以下为原文 Following configuration is not correct: ACCELERO_IO_Write(LSM303C_IG_CFG1_A, 0b11100010); //y interrupt disabled Please set the AOI bit to 1 if you want AND combination or to 0 if you want OR and set the 6D bit to 0. |
2877 浏览 1 评论
3282 浏览 1 评论
1861 浏览 1 评论
3710 浏览 6 评论
6124 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
411浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
510浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
334浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
246浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
353浏览 2评论
GMT+8, 2025-2-23 09:32 , Processed in 0.857439 second(s), Total 42, Slave 37 queries .
