应用很简单 - 接近检测在20mm和150mm之间。
VL6180x是透明的(没有玻璃或覆盖传感器的任何其他表面) 我尝试使用VL6180X的默认值和 PremiumEvalboard 中使用的值以及两个不同的传感器进行初始化,并始终得到相同的结果。在~100 mm以下的读数是最小的。 更改偏移量(SYSRANGE_PART_TO_PART_RANGE_OFFSET)不会更改最小感应距离,也不会更改其他参数,如SYSRANGE_THRESH_LOW / HIGH,SYSRANGE_RANGE_IGNORE_VALID_HEIGHT等等。 什么可以导致这种行为?有什么建议? #vl6180x#proximity-sensor#vl6180 以上来自于谷歌翻译 以下为原文 The application is simple - proximity detection between 20mm and 150mm. The VL6180x is clear (no glass or any other surface covering the sensor) I tried to initialize both with the default values of the VL6180X and with the values used in the �Premium Eval board� and with two different sensors and always got the same results. The readings under ~100 mm were in the minimum. Changing the offset (SYSRANGE_PART_TO_PART_RANGE_OFFSET) didn�t change the minimal sensing distance, nor changing other parameters like the SYSRANGE_THRESH_LOW/HIGH, SYSRANGE_RANGE_IGNORE_VALID_HEIGHT and many others. What can cause this kind of behavior? Any recommendations? #vl6180x #proximity-sensor #vl6180 |
沙龙你好,
从阅读下面的问题,我不确定你的“最小”价值究竟是什么意思。 如果可能,您可以从工作电子邮件帐户地址向我发送您的高级评估套件中的任何数据记录。 我的电子邮件地址是colin.ramrattan@st.com 通过这种方式,我可以查看您遇到的问题,并为您提供更完整的反馈。 以上来自于谷歌翻译 以下为原文 Hello Sharon, From reading your question below, I am unsure exactly what you mean by ''minimum'' values. If possible can you send me any datalogs you have from your premium evaluation kit from your work email account address. My email address is colin.ramrattan@st.com This way I can take a look at the issue you are having and provide you with more complete feedback. |
我面临着同样的问题。
“最小”值表示0。 我尝试了EVALKIT-VL6180X,它工作正常。然后我用我自己的电路板尝试了两个VL6180X,传感器从未设置result_range_device_ready。我以延迟的方式取得结果,传感器测量值从~100mm开始为0并且在较长距离处增加。 以上来自于谷歌翻译 以下为原文 I am facing exactly the same problem. The 'minimum' value means 0. I tried the EVALKIT-VL6180X and it works fine. Then I tried two VL6180X with my own board and the sensor never set result_range_device_ready. I take the result with delay and the sensor measure start from ~100mm as 0 and increasing at longer distance. |
2733 浏览 1 评论
3241 浏览 1 评论
1810 浏览 1 评论
3650 浏览 6 评论
6038 浏览 21 评论
1339浏览 4评论
201浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
350浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
443浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
274浏览 2评论
GMT+8, 2024-12-23 22:37 , Processed in 0.894299 second(s), Total 45, Slave 40 queries .
