你好
我们正在为使用Autocad 2015的客户运行一系列POC。 POC硬件是具有2 K2的超微服务器。 我们已经应用了Jason(thx btw)共享的策略,所有Nvidia演示都通过HDX 3D pro完美运行。 VDI计算机正在运行Windows 7 64位,最新的VDA修补程序。 我们的问题和showstopper是Autocad。 我们遇到的是鼠标滞后和游标问题。 有时Windows光标位于acad光标的顶部。 有时光标变为随机Windows光标,通过将指针移出绘图区域然后返回来解决问题。 Autocad在首次启动时会发出有关硬件加速的警告,但会看到grafx卡并显示使用DirectX 11。 我们知道GRID不在Acad 2015硬件兼容性列表中。 我们一直在尝试使用Acad 2016来查看问题是否已解决。 但它完全一样。 GRID也不在这里的hw兼容性列表中。 如果有人知道如何解决这个问题,或者知道有人这样做,请告诉我! :) 以上来自于谷歌翻译 以下为原文 Hi We are running a series of POC's for customers who use Autocad 2015. The POC hardware is a supermicro server with 2 K2's. We have applied the policies shared by Jason (thx btw), and all Nvidia demos are working perfectly through HDX 3D pro. The VDI machines are running Windows 7 64 Bit, latest VDA hotfixes. Our issue, and showstopper, is with Autocad. What we experience is mouse lag and cursor problems. Sometimes the Windows cursor sits ontop of the acad cursor. Sometimes the cursor changes to a random Windows cursor, the problem is "solved" by moving the pointer out of the drawing area and then back. Autocad gives a warning at first startup regarding the hardware acceleration but sees the grafx Card and shows DirectX 11 is used. We are aware that GRID is not on the Acad 2015 hardware compatibility list. We have been experimenting with Acad 2016 to see if the problem is solved. But it is exactly the same. GRID not on the hw compatibility list here as well. If anyone has an idea to how this problem can be fixed or know someone who does, tell me! :) |
12个回答
光标滞后是远程协议的结果,并且由网络条件(特别是ICA延迟)复杂化。
我建议优化网络以稳定延迟,提高帧速率,与Citrix合作以最佳方式改善这一点。 (例如,在注册表中可能的鼠标计时器调整。) 以上来自于谷歌翻译 以下为原文 The cursor lag is as a result of the remoting protocols, and is compounded by the network conditions (ICA latency in particular). I'd suggest optimising the network to stabilise latency, ramping up the framerate, working with Citrix on the best way to improve this. (possible mouse timer tweaks in the registry for example.) |
尝试给自己的核心acad.exe,另外ctxcfg.exe。
机器有多少vCPU? 如果必须与OS和ctxcfg.exe(Citrix'压缩器)共享AutoCAD,它通常只能使用1个核心,它会很迟钝。 以上来自于谷歌翻译 以下为原文 try giving acad.exe his own core, and ctxcfg.exe another. also howmany vCPU's does the machine have? AutoCAD can only use 1 core normally if it has to share it with OS and ctxcfg.exe (Citrix' compressor) it will be sluggish. |
K260Q在认证列表中
http://usa.autodesk.com/adsk/servlet/syscert/card?siteID=123112&catID=18254205&id=18844534&product=106&os=8192&hw=343 以上来自于谷歌翻译 以下为原文 K260Q is on the certified list http://usa.autodesk.com/adsk/servlet/syscert/card?siteID=123112&catID=18254205&id=18844534&product=106&os=8192&hw=343 |
jaccow提出了一些非常有效的观点。
建议在提供3D工作负载时至少应有4个CPU。 以上来自于谷歌翻译 以下为原文 jaccow makes some very valid points. Recommendation is that you should have at leas 4vCPU's when delivering 3D workloads. |
哦是的,对于AutoCAD,不要忘记更新客户端的驱动程序。
我发现XD会话中带有NVIDIA网格的本地旧AMD卡会出现奇怪的鼠标问题。 以上来自于谷歌翻译 以下为原文 oh Yes and for AutoCAD don't forget to update the client's drivers as well. I've found that a local old AMD card with a NVIDIA Grid in the XD sessions will give strange mouse issues. |
AutoCAD可以是服务器渲染的光标,您可以找到调整MouseTimer(如此处所述https://www.citrix.com/blogs/2015/04/09/performance-tip-disabling-mouse-shadow-for-xendesktop-and
-xenapp /)很有帮助。 如果延迟到网络,我会尝试调查为什么,如果有限的带宽,您可能会发现思科在XD 7.6 FP3中添加了Thinwire +帮助https://www.citrix.com/blogs/2015/10/09/a -big-leap-in-ica-protocol-innovation-for-citrix /(参见AutoCAD / CAD用户博客中关于构建到无损成功的评论)。 如果您处于高延迟> 70ms,则可能需要调整TCP / IP窗口,如下所述:CTX125027 - 如何在高延迟连接上优化HDX带宽https://support.citrix.com/article/CTX125027 如果有任何帮助,请告诉我,如果没有,请告诉我! 雷切尔 以上来自于谷歌翻译 以下为原文 AutoCAD can be a server rendered cursor and you may find tweaking MouseTimer (as described here https://www.citrix.com/blogs/2015/04/09/performance-tip-disabling-mouse-shadow-for-xendesktop-and-xenapp/ ) helpful. If the lag is down to the network I'd try to investigate why, if limited bandwidth you might find thinwire+ added by Citrix in XD 7.6 FP3 helps https://www.citrix.com/blogs/2015/10/09/a-big-leap-in-ica-protocol-innovation-for-citrix/ (see the comments below the blog from AutoCAD / CAD users on build to lossless success). If you are on high latency >70ms then it might be worth tuning the TCP/IP window as described in: CTX125027 – How to Optimize HDX Bandwidth Over High Latency Connections https://support.citrix.com/article/CTX125027 Do let me know if anything helps and also if it doesn't! Rachel |
我用acad.exe获得的单个最大性能提升是设置CPU亲和力。
所以将exe固定到一个CPU。 您需要配置用户启动应用程序的任何快捷方式,但性能提升非常明显。 以上来自于谷歌翻译 以下为原文 The single largest performance boost I get with acad.exe is setting CPU affinity. So pin the exe to one CPU. You'll need to configure any shortcut the user launches the application from to do that, but the performance boost is very noticeable. |
查看MouseTimer。
它是客户端上的注册表项。 当用户和服务器之间有一点延迟时,使autocad更像是本地程序。 我有一个链接,但看起来Citrix在上次重组期间关闭了页面; 糟糕 - 打赌我的很多链接现在都坏了。 reg键应该是: HKEY_LOCAL_MACHINE SOFTWARE Citrix ICA Client Engine Lockdown Profiles All Regions Lockdown Virtual Channels Mouse 由于artcile失败,我从记忆中拉 - 我认为默认值是100(它是*,但它转换为100)。 它是MS中的一种测量,因此每100ms所有鼠标操作都将被收集并发送到服务器。 把这个家伙放到30-40毫秒,也许再多一点,看看是否有所作为。 我不知道它会给你带来多大的影响,但它会产生更多的带宽...... 以上来自于谷歌翻译 以下为原文 Check out MouseTimer. It's a registry key on the client. Makes autocad feel much more like a local program when you have a little latency between the user and the server. I had a link, but it looks like Citrix took the page down during their last restructuring; bummer -- bet lots of my links are broken now. The reg key should be: HKEY_LOCAL_MACHINESOFTWARECitrixICA ClientEngineLockdown ProfilesAll RegionsLockdownVirtual ChannelsMouse Since the artcile is down, I'm pulling from memory -- I think the default value is 100 (it's a *, but it translates to 100). It's a measurement in MS, so every 100ms all mouse actions will be collected and sent to the server. Drop this guy down to 30-40 ms, maybe a little more, and see if that makes a difference. I have no idea how much of an impact it will be fore you, but it will generate more bandwidth... |
嗨Virge,
Mousetimer默认为10,你正在做的是实际提高它 - 我在这里写了一个解释:https://www.citrix.com/blogs/2015/04/09/performance-tip-disabling-mouse-shadow-for- 的XenDesktop - 和 - 的XenApp / 您可能还会发现这很有用:https://www.citrix.com/blogs/2014/05/28/configuring-virtualised-autodesk-and-similar-applications-including-xenapp-gpu-sharing-and-tools-for -sanity检查的directxopengl使用率/ AutoCAD相对于GPU而言CPU非常重,因此CPU GHz通常非常重要。 最好的祝愿, 雷切尔 以上来自于谷歌翻译 以下为原文 Hi Virge, Mousetimer default is 10, what you are doing is actually raising it - I wrote an explanation here: https://www.citrix.com/blogs/2015/04/09/performance-tip-disabling-mouse-shadow-for-xendesktop-and-xenapp/ You may also find this useful: https://www.citrix.com/blogs/2014/05/28/configuring-virtualised-autodesk-and-similar-applications-including-xenapp-gpu-sharing-and-tools-for-sanity-checking-directxopengl-usage/ AutoCAD is very CPU heavy relative to GPU so often the CPU GHz is important. Best wishes, Rachel |
瑞秋,
整个传统图形与DCR与H264对比编解码器与其他任何似乎漂浮的东西是另一个错综复杂的东西,只是逃避了我。 Windows 7 - 您喜欢AutoCAD中的哪一个? Windows 10 - 您喜欢AutoCAD中的哪一个? Windows 7 - 您喜欢Revit,SpaceGAss和Inventor中的哪一个? Windows 10 - 您喜欢Revit,SpaceGAss和Inventor 这么多相互矛盾的意见......我想用DCR吗? 你喜欢XenDesktop 7.11的哪种压缩? 非常感谢。 以上来自于谷歌翻译 以下为原文 Rachel, the whole legacy graphics vs DCR vs H264 vs codecs vs whatever else seems to be floating around is another one of the intricacies that just escapes me. Windows 7 - Which one do you like with AutoCAD Windows 10 - Which one do you like with AutoCAD Windows 7 - Which one do you like with Revit, SpaceGAss and Inventor Windows 10 - Which one do you like with Revit, SpaceGAss and Inventor So many conflicting opinions... and do i want to use DCR ? And which compression do you like with XenDesktop 7.11 ? Many thanks. |
最后 - 接收器上的新“相对鼠标”设置是一个优势吗?
以上来自于谷歌翻译 以下为原文 Lastly - is the new "Relative Mouse" setting on the receiver an advantage ? |
从零开始 - 相对鼠标对AutoCAD没有好处。
以上来自于谷歌翻译 以下为原文 Scratch that - the relative mouse is no good for AutoCAD. |
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3278 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3705 浏览 4 评论
GMT+8, 2025-7-12 09:28 , Processed in 0.922818 second(s), Total 97, Slave 81 queries .
