你好,
一直在玩M60和7.11 XenDesktop VDA。 我发现NVENC只在我使用1GB帧缓冲配置文件时启动(我假设如上) - 它对512MB帧缓冲配置文件不起作用/启动? - 我认为这是由于帧缓冲区的大小限制或卡可以支持的流的数量,但是在我找到的任何文档中都没有突出显示,并且显然具有非常大的可伸缩性含义? 营销培训,特别是在这里:https://blogs.nvidia.com/blog/2016/09/14/citrix-xendesktop-nvidia-grid/当然没有提到它.. 增加“可扩展性”一切都很好,但是当你“降级”你的vGPU容量时,这并没有什么帮助。 我只是做错了吗? 我当然能说出性能上的提升! 以上来自于谷歌翻译 以下为原文 Hello, Been playing with the M60 and 7.11 XenDesktop VDA. I'm finding that NVENC only kicks in when I use the 1GB frame buffer profile (and I assume above) - it doesn't work/kick in for the 512MB framebuffer profile? - I assume this is due to the size limitation of the framebuffer or the number of streams the card can support itself but this isn't highlighted anywhere in any documentation I've found and obviously has very large scalability implications ? The marketing train, especially here: https://blogs.nvidia.com/blog/20 ... esktop-nvidia-grid/ certainly makes no mention of it.. It's all well and good to increase your 'scalability' but that's not really helpful when you 'descaled' your vGPU capacity.. Am I simply doing something wrong? I can certainly tell the improvement in performance! |
13个回答
你好
我不知道NVEnc的任何vGPU配置文件限制,但我从未使用过512MB配置文件... 所以我可以尝试在我的实验室中复制这个,仅供我参考,你用什么来确定NVEnc是否有效? 您使用的是“B”或“Q”配置文件吗? 问候 本 以上来自于谷歌翻译 以下为原文 Hi I'm not aware of any vGPU Profile limitations for NVEnc, but I've never used a 512MB Profile... So I can try and replicate this in my lab, just for my reference, what are you using to determine whether the NVEnc is active or not? Are you using a "B" or "Q" profile? Regards Ben |
我正在使用M60-0Q配置文件..我即将去测试B配置文件,我也会报告我的结果。
谢谢 安德鲁 以上来自于谷歌翻译 以下为原文 I was using the M60-0Q profile.. I'm about to go and test the B profile and I also will report back my results. Thanks Andrew |
没有与B配置文件的区别--NVENC没有启动。如果我关闭并重启机器与任何M60-1及以上的配置文件,它就像一个魅力:(
以上来自于谷歌翻译 以下为原文 No difference with the B profile - NVENC does not kick in. If I shutdown and reboot the machine with any of the M60-1 and above profiles it works like a charm :( |
嗨安德鲁,
我们的工程/ PM团队已经确认,由于需要避免过度使用,目前还没有在512MB配置文件上启用NVENC。 我们正在积极努力解除限制。 目前,NVENC确实仅适用于1GB及更高FB配置文件的GRID 4.0。 我们欢迎您通过我们的ESP支持资料(提高机票)提出此问题,以便我们可以将您纳入任何早期访问计划,主动通知您更改并突出您的需求。 这应该通过客户的企业支持门户网站完成,客户应该通过以下网址提出票证/案例:https://nvidia-esp.custhelp.com/门户链接可以在主GRID支持页面上找到:http:// www.nvidia.com/object/grid-support.html。 最好的祝愿, 雷切尔 以上来自于谷歌翻译 以下为原文 Hi Andrew, Our engineering/PM teams have confirmed that at the moment NVENC is not enabled on 512MB profiles owing to a need to avoid overcommit. A limitation we are actively working on to lift. For the time being NVENC is indeed only available for GRID 4.0 on 1GB and higher FB profiles. We'd welcome you raising this issue with our ESP support profile (raise a ticket) so we can include you in any early access program, proactively notify you of changes and highlight your need. This should be done via the customer’s enterprise support portal where customers should raise a ticket/case via: https://nvidia-esp.custhelp.com/ links to the portal can be found on the main GRID support page: http://www.nvidia.com/object/grid-support.html. Best wishes, Rachel |
嗨雷切尔,
太遗憾了,但感谢你这么快回到我身边。 我会根据你的建议提出一张票,并期待更新。 干杯 安德鲁 以上来自于谷歌翻译 以下为原文 Hi Rachel, Thats a shame but thanks for getting back to me so quickly. I'll raise a ticket as you suggest and look forward to updates. Cheers Andrew |
Rachel,这也适用于M10和VMware Horizon,还是只适用于XenDesktop限制?
以上来自于谷歌翻译 以下为原文 Rachel, does this apply to the M10 and VMware Horizon, too, or just an XenDesktop restriction? |
我与我的NVIDIA SE的聊天表明,这也影响了M10,它不是特定于Citirx / VMWare,而是驱动程序/ nvidia级别。
以上来自于谷歌翻译 以下为原文 My chat with my NVIDIA SE indicated that yes this affects the M10 as well, it's not specific to Citirx/VMWare but at the driver/nvidia level. |
有人可以提供一些关于如何最好(可靠)识别NVENC是否在Windows桌面虚拟机(XenDesktop 7.11)上“启动”的提示?
REG KEY EncoderType_Mon1是唯一的提示吗? 以上来自于谷歌翻译 以下为原文 Can someone please give some hints on how to best (reliable) identify if NVENC "kicks in" on Windows Desktop Virtual Machines (XenDesktop 7.11) ? Is the REG KEY EncoderType_Mon1 the only hint? |
本
除此之外,使用Putty和SSH到运行要测试的VM的GRID主机。 键入“nvidia-smi”以显示主机上的vGPU,然后您可以识别您的VM正在使用哪个。 要查询vGPU,请使用“-q” 要指定组中的某个vGPU,请使用“-i 1”(假设您要监视的vGPU的编号为1.您可以从上面提到的运行“nvidia-smi”获取vGPU编号) 要不断循环(刷新)此结果以提供基本监视形式,请使用时间变量来说明循环间隔的秒数,使用“-l 1” 因此,要以1秒的循环速率监视vGPU 4,您将运行以下命令: nvidia-smi vgpu -q -i 4 -l 1 这将一直运行,直到您取消它(Ctrl + C)或关闭SSH连接,并将为您提供各种有用的信息。 问候 本 以上来自于谷歌翻译 以下为原文 Ben For a bit more than that, use Putty and SSH to the GRID Host that is running the VM you want to test. Type "nvidia-smi" to show the vGPUs on the host, you can then identify which one your VM is using. To query the vGPU use "-q" To specify a certain vGPU out of the group, use "-i 1" (assuming the number of the vGPU you want to monitor is 1. You can get the vGPU number from just running "nvidia-smi" as mentioned above) To constantly loop (refresh) this result to provide a basic form of monitoring, use a time variable stating the number of seconds for the loop interval, use "-l 1" So to monitor vGPU 4 with a loop rate of 1 second, you would run the following: nvidia-smi vgpu -q -i 4 -l 1 This will run until you cancel it (Ctrl + C) or close the SSH connection and will give you all sorts of useful information. Regards Ben |
嗨本(如果你的名字是一样的话很奇怪;),
很好的解释,非常感谢你。 您知道Citrix是否会在未来的版本中在Xencenter中显示这些记录吗? 这将是如此酷和更容易。 另一个好的解决方案是Splunk。 Nvidia是否可以使用splunk App或者有一些经验来转发和分析这些网格数据/ w splunk? 干杯 本 以上来自于谷歌翻译 以下为原文 Hi Ben (strange if your name is the same ;), great explanation, thank you so much. Do you know if Citrix is going to display these records within Xencenter in a future release? This would be so cool and easier. Another good solution would be Splunk. Does Nvidia work on a splunk App or has some experience to forward and analyse these grid data /w splunk? Cheers Ben |
嗨本
是的,另一个本:-) 您可能知道也可能不知道,但XenCenter具有一些内置的vGPU监控功能。 您可以使用性能监视选项卡来创建一些自定义vGPU监视器(电源,内存利用率等),但我不相信他们有NVEnc可用。 其他专业供应商(eG Innovations,Goliath,LakeSide等)在他们的软件中使用这些信息以他们自己的定制方式显示这些指标,因此可能值得检查评估。 您可能想要尝试的另一块监控软件来自Jeremy Main。 它可以从这里免费下载:https://github.com/JeremyMain/GPUProfiler/releases并具有您所追求的功能。 只需下载.exe并在您想要评估的桌面上本地运行它。 它不需要安装,因为它是便携式.exe。 是的,UberAgent可以监控vGPU https://gridforums.nvidia.com/default/topic/237/uberagent-for-splunk-monitors-gpu-usage-per-machine-and-per-process/但是没有亲自使用它 我无法确定它的深度。 问候 本 以上来自于谷歌翻译 以下为原文 Hi Ben Yes, another Ben :-) You may or may not know, but XenCenter has some built in vGPU monitoring abilities. You can use the performance monitoring tab to create some custom vGPU monitors (Power, Memory Utilisation etc), however I don't believe that they have the NVEnc available. Other specialised vendors (eG Innovations, Goliath, LakeSide etc etc) are using this information in their software to display these metrics in their own custom way, so may be worth checking out an evaluation. Another piece of monitoring software you may want to try is from Jeremy Main. It's free to download from here: https://github.com/JeremyMain/GPUProfiler/releases and has the features you're after. Just download the .exe and run it locally on the desktop you want to asses. It doesn't require installation as it's a portable .exe. Yes, UberAgent can monitor vGPU https://gridforums.nvidia.com/default/topic/237/uberagent-for-splunk-monitors-gpu-usage-per-machine-and-per-process/ However not having personally used it I can't confirm what depth it goes to. Regards Ben |
嗨本:-)
谢谢,关于工具的好总结! 对于Xenserver PM /开发人员来说,直接在Xencenter中显示Nvenc使用情况将是一个很好的提示。 vGPU已经可以使用了。 当我为一个快乐的uberagent合作伙伴工作时,我知道如何使用splunk监控Sessions中的vGPU使用情况,而我的问题更多是“Nvidia是否提供/开发自己的(或splunk app)集成方式来监控网格的硬件/和nvenc编码器使用情况 牌”。 Nvidia-Smi很棒,但是嘿,我认为网格板值得一个具有使用报告功能的管理服务器;) 亲切的问候 本 以上来自于谷歌翻译 以下为原文 Hi Ben :-) Thank you, good summary on tools! It would be a good hint for the Xenserver PM/developers to display Nvenc usage directly within Xencenter. vGPU Usage is already possible. As i work for a happy uberagent partner i know how to monitor vGPU usage within Sessions with splunk and my question was more "does Nvidia provide / develop a own (or splunk app) integrated way to monitor hardware/and nvenc encoder usage of the Grid Cards". Nvidia-Smi is great but hey, a Grid Board is worth a management server with usage reporting functionality in my opinion ;) Kind regards Ben |
我非常确定Citrix已经在开发Xenserver,以便将我们的Encode / Decode新指标添加到XenCenter性能监控中。
我得到一些新闻后立即发布... 问候 西蒙 以上来自于谷歌翻译 以下为原文 I'm pretty sure Citrix is already working on the Xenserver piece to add the new metrics we have like Encode/Decode into the XenCenter performance monitoring. Keep you posted as soon as I get some news... Regards Simon |
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3209 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3616 浏览 4 评论
GMT+8, 2025-4-6 21:14 , Processed in 0.910163 second(s), Total 96, Slave 80 queries .
