您好,我用MICROStiCK 2编程PIC 32,没有问题,我可以使用非常酷的调试器(我来自ARDUINO,非常有限),但是当我尝试编程PIC24EP时,不管我在做什么,当用MICROSTICK II调试:编程/验证时总是有以下结果完成目标设备尚未准备好进行调试。请检查配置位设置并在继续之前对设备进行编程。这种故障最常见的原因是振荡器和/或PGC/PGD设置和调试停止。我花了好几个小时去理解…有什么我错过的吗?PICS在一个电路板上写的很好,所以我不理解它与PIC32的关系,而不是PIC24EP128MC202。谢谢大家对我法语的抱歉。
以上来自于百度翻译 以下为原文 Hello, I program pic 32 with the microstick 2 and there's no problem, I Can use the debugger wich is very cool ( i come from arduino, very limited) but when I try to program pic24EP no matter what I'm doing there's always the following result when debuging with the microstick II : Programming/Verify complete The target device is not ready for debugging. Please check your configuration bit settings and program the device before proceeding. The most common causes for this failure are oscillator and/or PGC/PGD settings. and the debug stop. I've spent several hours to try to understand ... is there something I miss ? The pic restes on a breadboard is well written so l don't understand wy it débuts with the pic32 and not with the pic24ep128mc202. Thanks in advance ans sorry for my frenchy english :) Attachment(s) merd22.c (2.63 KB) - downloaded 52 times |
5个回答
您好,PIC24EP128MC202有编程/调试引脚:引脚4和5,PGED3和PGEC3,PIN 6和7,PGEC1和PGED1,PIN 14和15,PGED2和PGEC2PGEDA和PGECA在MICROSTICK 2板上连接到PGED3和PGEC3,在这个芯片类型中。n在XC16编译器中安装的目录中有文件,如:文件:///C: /程序%20Cfile 20(x86)/Microchip /XC16/V1.34 /DOCS/CONTIONDOCS/24EP128MC202.HTML MysIL。
以上来自于百度翻译 以下为原文 Hi, PIC24EP128MC202 have programming/debugging pins on: pin 4 and 5, PGED3 and PGEC3, pin 6 and 7, PGEC1 and PGED1, and pin 14 and 15, PGED2 and PGEC2 PGEDA and PGECA on the Microstick 2 board is connected to PGED3 and PGEC3 in this chip type. For Debugging to function, you have to specify this connection. #pragma config ICS = 1 or #pragma config ICS = PGD3 There are documentation in directories installed with the XC16 compiler, somewhere like: file:///C:/Program%20Files%20(x86)/Microchip/xc16/v1.34/docs/config_docs/24EP128MC202.html Mysil |
嗨,GalouChe,一定要使用MyCHIPCRead网站。它包含了很多教程。
以上来自于百度翻译 以下为原文 Hi Galouche, Make sure to use Microchipdeveloper website. It contains a lot of tutorials Regards |
5318 浏览 9 评论
2073 浏览 8 评论
1978 浏览 10 评论
3250 浏览 3 评论
2286 浏览 5 评论
831浏览 1评论
724浏览 1评论
670浏览 1评论
723浏览 0评论
619浏览 0评论
GMT+8, 2025-2-1 12:05 , Processed in 1.249020 second(s), Total 85, Slave 69 queries .
