我正在使用您的PSoC 4 BLE SOC,CY8CKIT-042-BLE先锋套件。我需要通过BLE发送来自传感器的原始数据到Android应用程序。
1。如何从板卡到定制的移动应用程序发送/接收定制数据(例如:.CSV文件)? 2。如何编程硬件? 三。你能提供一个示例程序吗? 我请求你尽可能早地回复我。 以上来自于百度翻译 以下为原文 I'm using your PSOC 4 BLE SoC, CY8CKIT-042-BLE Pioneer kit. I need to send raw data from the sensor to android application through BLE. 1. How to send/receive customized data (eg: .CSV file) from board to customized mobile application? 2. How do i program the hardware? 3. Can you provide an example program? I request you to get back to me as earliest as possible. |
1。您需要定制特性。
2。这是一个相当大的问题。我会从我做的教程开始 PSoC 4 BLE教程 HTTP://wwwyCyp.com /Primult/PSoC-4-BLU-101-VIETO教程系列-HOW-CRATET-OPTIONS USE-PSOC-4-BLE 安卓: HTTP://www. CyPress .COM/Primult/PSoC视频教程系列-HO-CRATET-ANDROID-APPS-ICAT-CysPer-BLE 三。在示例代码浏览器中有一组示例,您可以在PSoC Creator的文件中找到这些代码示例。 也有一些描述过程的BLE应用笔记。 HTTP://wwwyCysP.com/SqChy/ALL?f [ 0 ] = Meta类型%3 AtHeNeChanaX文档和F[ 1 ]=RealthyMeta类型%3A54&F; 如果你在我的博客上搜索BLE,你会发现一大堆BLL教程。 HTTPS://IOTHealth.COM/?S=BLE 以上来自于百度翻译 以下为原文 1. You will need to make custom characteristics 2. That is a pretty big question. I would start with the tutorials that I made A PSoC 4 BLE Tutorial http://www.cypress.com/training/psoc-4-ble-101-video-tutorial-series-how-create-products-using-psoc-4-ble Android: http://www.cypress.com/training/psoc-video-tutorial-series-how-create-android-apps-interact-cypress-ble 3. There are a bunch of examples in the example code browser that you can find on File->Code Examples in PSoC Creator There are also a number of BLE application notes that describe the process http://www.cypress.com/search/all?f[0]=meta_type%3Atechnical_documents&f[1]=resource_meta_type%3A574&f[2]=field_related_products%3A1209 And if you search for BLE on my blog www.iotexpert.com you will find a bunch of BLE tutorials https://iotexpert.com/?s=BLE |
1。为了制作自定义配置文件,示例:HTTP://wwwyCysP.COM/FIL/140826/Access对于理解如何使用BELL API来定制配置文件/特性是方便的。 以上来自于百度翻译 以下为原文 1. For making a custom profile, the examples: http://www.cypress.com/file/140826/download are handy for understanding how to use the BLE API for custom profiles/characteristics. |
762个成员聚集在这个小组
加入小组2185 浏览 1 评论
1934 浏览 1 评论
3754 浏览 1 评论
1857 浏览 6 评论
1600 浏览 1 评论
974浏览 2评论
663浏览 2评论
511浏览 2评论
478浏览 2评论
1349浏览 2评论
GMT+8, 2025-4-5 23:05 , Processed in 0.909931 second(s), Total 49, Slave 43 queries .
