5个回答
你的问题是想问DFB激光器的激光管的正极接在什么地方么,还是其他问题
cai868 发表于 2018-9-24 13:43 你的问题已经发到了如下链接, 可以在如下链接中查看 https://ez.analog.com/message/215674#215674 |
好的,谢谢。 |
Your selected laser module is in a butterfly package with the laser anode pin connected to the case ground. There are two ways to use this laser module with ADN2871: 1. Connecting the laser module case ground to supply Vcc. This keeps the "positive supply" design and you can use Fig. 29 circuit directly; or 2. Using "negative supply" way to ADN2871 circuitry. In the Fig. 29 circuit, change all external Vccs to new "negative supply" ground, change all external GNDs to -3.3V. Now, you can connect the laser module case to negative supply ground. In this way, you may have to pay attention to the ADN2871 control/monitor signal levels accordingly. Please note, in this case, all these DC levels are referred to -3.3V, not the ground. |
2314个成员聚集在这个小组
加入小组1198 浏览 2 评论
1545 浏览 2 评论
2060 浏览 1 评论
4370 浏览 2 评论
9207 浏览 1 评论
2050浏览 3评论
1818浏览 2评论
1199浏览 2评论
1846浏览 2评论
1546浏览 2评论
GMT+8, 2025-3-29 14:39 , Processed in 0.772496 second(s), Total 53, Slave 47 queries .
