扫一扫,分享给好友
struct bus_type {
const char *name; // 总线名 struct bus_attribute *bus_attrs; // 总线属性 struct device_attribute *dev_attrs; struct driver_attribute *drv_attrs; int (*match)(struct device *dev, struct device_driver *drv); // 匹配方法 int (*uevent)(struct device *dev, struct kobj_uevent_env *env); int (*probe)(struct device *dev); int (*remove)(struct device *dev); void (*shutdown)(struct device *dev); int (*suspend)(struct device *dev, pm_message_t state); int (*resume)(struct device *dev); const struct dev_pm_ops *pm; struct subsys_private *p;
struct device { struct device *parent; // 当前设备的父类 struct device_private *p; struct kobject kobj; const char *init_name; /* initial name of the device 设备名*/ const struct device_type *type; struct mutex mutex; struct bus_type *bus; /* type of bus device is on 设备所在的总线*// struct device_driver *driver; /* which driver has allocated this device ,该对象中包含操作设备的的方法*/ void *platform_data; /* Platform specific data, device core doesn't touch it,私有平台数据,给用户使用 */ struct dev_pm_info power; struct dev_power_domain *pwr_domain; /* arch specific additions */ struct dev_archdata archdata; struct device_node *of_node; /* associated device tree node */ dev_t devt; /* dev_t, creates the sysfs "dev" */ spinlock_t devres_lock; struct list_head devres_head; struct klist_node knode_class; struct class *class; const struct attribute_group **groups; /* optional groups */ void (*release)(struct device *dev); //当设备的最后一个引用被删除时,调用该函数 };
struct device {
struct mutex mutex;
const char *name; // 驱动名字 struct bus_type *bus; // 所属总线 struct module *owner; const char *mod_name; /* used for built-in modules */ bool suppress_bind_attrs; /* disables bind/unbind via sysfs */ const struct of_device_id *of_match_table;// 设备id表,表示该驱动支持哪些型号的设备 int (*probe) (struct device *dev); // 当设备和驱动匹配的时候执行的方法 int (*remove) (struct device *dev); void (*shutdown) (struct device *dev); int (*suspend) (struct device *dev, pm_message_t state); int (*resume) (struct device *dev); const struct attribute_group **groups; const struct dev_pm_ops *pm; struct driver_private *p; };
83个成员聚集在这个小组
Qualcomm_Snapdragon_VR_SDK SvrPlugin脚本简介(1)
1715 浏览 0 评论
【DragonBoard 410c试用体验】之OpenCV中canny算子边缘检测
9016 浏览 0 评论
【DragonBoard 410c】汇总帖(2016.10.25更新)
36102 浏览 2 评论
查看 »
GMT+8, 2025-1-26 15:33 , Processed in 0.479326 second(s), Total 34, Slave 28 queries .
