Twitter今天提出的一个问题是:“一个客户试用了vWSE许可证。我们需要测试vPC是否有可能获得vPC许可证的试用?”
答:GRID软件许可证是对该版本或更低版本以及相应的vGPU配置文件有效的超集。 例如,如果我有100x vWS(虚拟工作站)版许可证,我可以将它们用作vWS或vPC(虚拟PC),但不能用于vWSE(虚拟WorkStation Extended)。 我在访客设置中分配了所需的vGPU配置文件,例如 M60-1Q,在启动时,它将从许可证服务器获取许可证,留下N-1用于剩余许可证。 注意:在配置文件中(例如上面提到的或M60-1B)Q = Quadro Driver,因此具有专业的可视化功能和性能,B =非Quadro驱动程序 - 卢克 以上来自于谷歌翻译 以下为原文 A question from Twitter today: "a client got a trial, which came with vWSE licenses. We need to test vPC is it possible to get a trial for vPC licenses?" Answer: The GRID software license is a superset so valid for that edition or lower, and those corresponding vGPU profiles. For example, if I have 100x vWS (virtual WorkStation) edition licenses I can use them as vWS or vPC (virtual PC), but not for vWSE (virtual WorkStation Extended). I assign the desired vGPU profile in the guest settings, e.g. M60-1Q, and on boot it will pull a license from the license server, leaving N-1 for remaining licenses. Note: In the profile (e.g. noted above or M60-1B) Q = Quadro Driver and so has professional visualization features and performance, B = non Quadro driver - Luke |
3个回答
我在哪里可以获得有关许可的报价。
使用戴尔R730和K2 GPU 以上来自于谷歌翻译 以下为原文 Where do I go to receive a quote on the licensing. using a Dell R730 and the K2 GPU |
我打电话给Ingram Micro,但他们似乎迷路了
以上来自于谷歌翻译 以下为原文 Ive called Ingram Micro but they seem lost |
K2不需要许可证。
它缺少更高版本的功能集,因此没有许可证。 以上来自于谷歌翻译 以下为原文 K2 does not require licenses. It lacks the feature set of the later versions and so is license free. |
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3170 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3581 浏览 4 评论
GMT+8, 2025-2-12 13:45 , Processed in 0.433464 second(s), Total 46, Slave 41 queries .
