您好,我正在设置新的XenApp / XenDesktop部署(第一个计时器)并遇到问题。
使用GRID K260Q vGPU设置主映像时,可以在Revit和AutoCAD中启用硬件加速并运行。 两个程序都知道卡,没有问题。 只要在主映像上安装VDA组件,它就会在Revit中中断此功能。 它仍显示在AutoCAD中启用,但在Revit中它说:“Revit检测到不支持的视频卡和驱动程序'。”。 当我查看设备管理器时,它显示正确的GRID卡。 我尝试过完全GPU passthrough同样的问题。 我已经尝试安装VDA作为Power控制而不是,没有区别。 有谁知道是什么导致了这个或我做错了什么? 我们的系统如下: 戴尔R720 2张GRID K2卡 XenServer 6.5(所有当前更新) XenDesktop / XenApp 7.6 Revit 2015,2016 AutoCAD 2015,2016 以上来自于谷歌翻译 以下为原文 Hello, I am setting up a new XenApp/XenDesktop deployment (first timer) and am running into issues. While setting up the master image using the GRID K260Q vGPU, hardware acceleration is enabled and functioning in Revit and AutoCAD. Both programs are aware of the card and there is no issue. As soon as I install the VDA component on the master image, it breaks this functionality in Revit. It still shows enabled in AutoCAD, but in Revit it says: "Revit detects an unsupported video card '' and driver ''.". When I look in the Device manager it shows the correct GRID card. I have tried full GPU passthrough with the same issue. I have tried installing VDA as both Power controlled and not, no difference. Does anyone know what is causing this or what I am doing wrong? Our system is as follows: Dell R720 2 x GRID K2 cards XenServer 6.5 (all current updates) XenDesktop/XenApp 7.6 Revit 2015, 2016 AutoCAD 2015, 2016 |
您应该在任何应用程序之前安装VDA。
尝试该命令,然后看看它的行为。 以上来自于谷歌翻译 以下为原文 You should install the VDA before any applications. Try that order then see how it behaves. |
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3158 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3573 浏览 4 评论
GMT+8, 2025-1-31 20:05 , Processed in 0.453787 second(s), Total 41, Slave 36 queries .
