我有一些运行M10-1B配置文件的Windows 10 Xendesktop主机。
这一切都很好。 最近我不得不重建citrix MCS目录,现在我的主机无法获得许可证。 与此同时,我重建了Azure AD Connect,它是在Grid许可证服务器上共同托管的。 许可证服务器似乎工作正常,但我不确定如何远程测试与许可证端口的连接。 我无法访问http:// licenseserver:7070。 我仍然使用试用许可证并拥有40个vDWS许可证。 tiA 垫。 以上来自于谷歌翻译 以下为原文 I have some Windows 10 Xendesktop hosts running with M10-1B profiles. This all worked fine. Recently I had to rebuild the citrix MCS catalogs and now my hosts can't acquire a license. At the same time, I rebuilt Azure AD Connect which is co-hosted on the Grid license server. The license server appears to be working fine however I am not sure how to test connectivity to the license port remotely. I cannot access http://licenseserver:7070. I am still running with the trial license and have 40 vDWS licenses available. TIA Mat. |
9个回答
您应该检查从guest虚拟机到许可证服务器的所有防火墙。
“http:// licenseserver:7070”正确答案应为“404 Not Found”(许可证流程使用REST API POST“http:// licenseserver:7070 / request”)。 #curl -v http:// licenseserver:7070 *重建URL到:http:// licenseserver:7070 / *尝试许可证服务器...... * TCP_NODELAY设置 *连接到licenseserver(licenseserver)端口7070(#0) > GET / HTTP / 1.1 >主持人:licenseserver:7070 > User-Agent:curl / 7.59.0 >接受:* / * > 更多要测试的网址(标准浏览器GET方法): HTTP:// LICENSESERVER:7070 / API / 1.0 /健康 HTTP:// LICENSESERVER:7070 / API / 1.0 /配置/元数据 HTTP:// LICENSESERVER:7070 / API / 1.0 /主机标识 HTTP:// LICENSESERVER:7070 / API / 1.0 /实例/〜 HTTP:// LICENSESERVER:7070 / API / 1.0 /实例/〜/客户端 HTTP:// LICENSESERVER:7070 / API / 1.0 /实例/〜/特征 以上来自于谷歌翻译 以下为原文 You should check all firewalls from guest to license server. The "http://licenseserver:7070" correct answer should be "404 Not Found" (license process uses REST API POST "http://licenseserver:7070/request"). # curl -v http://licenseserver:7070 * Rebuilt URL to: http://licenseserver:7070/ * Trying licenseserver... * TCP_NODELAY set * Connected to licenseserver (licenseserver) port 7070 (#0) > GET / HTTP/1.1 > Host: licenseserver:7070 > User-Agent: curl/7.59.0 > Accept: */* > < HTTP/1.1 404 Not Found < Date: Thu, 28 Jun 2018 09:28:29 GMT < X-Content-Type-Options: nosniff < X-XSS-Protection: 1; mode=block < Cache-Control: no-cache, no-store, max-age=0, must-revalidate < Pragma: no-cache < Expires: 0 < X-Frame-Options: DENY < Content-Type: application/json < Transfer-Encoding: chunked < { "arguments" : [ "uri=/", "GET", "(unknown)" ], "message" : "No such REST API and METHOD combination supported: uri=/ with GET for user (unknown)", "key" : "glsErr.restNoSuchApi" * Connection #0 to host licenseserver left intact } More urls to test (standard browser GET method): http://licenseserver:7070/api/1.0/health http://licenseserver:7070/api/1.0/configuration/metadata http://licenseserver:7070/api/1.0/hostids http://licenseserver:7070/api/1.0/instances/~ http://licenseserver:7070/api/1.0/instances/~/clients http://licenseserver:7070/api/1.0/instances/~/features |
感谢您的额外信息。
我已经尝试禁用客户端和许可证服务器上的本地防火墙,我已将它们移动到同一子网上,以避免交叉子网防火墙全部没有区别。 我已经测试了所有的URL,它们都响应客户端的响应,表明许可证服务器确实在工作。 我还使用currports来检查7070正在服务器上监听。 许可证服务器上是否有某个日志可能显示与客户端的通信以及为什么它没有获得许可证? 以上来自于谷歌翻译 以下为原文 Thanks for the extra info. I have tried disabling the local firewalls on the client and license server and I have moved them to be on the same subnet to avoid an cross subnet firewall all with no difference. I have tested all the URLs and they all respond with responses to the client suggesting the license server is indeed working. I have also used currports to check 7070 is listening on the server. Is there a log somewhere on the license server which might show the communication with the client and why it isn't getting a license? |
/var/opt/flexnetls/nvidia/logs/access*request.log中的许可证请求类似于(检查其他日志):
guest_ip - - [28 / Jun / 2018:10:17:08 +0000]“POST / request HTTP / 1.1”200 889 271 以上来自于谷歌翻译 以下为原文 License request in /var/opt/flexnetls/nvidia/logs/access*request.log is something like (check other logs too): guest_ip - - [28/Jun/2018:10:17:08 +0000] "POST /request HTTP/1.1" 200 889 271 |
对不起 - 我在服务器或客户端都找不到该目录?
如果有所不同,我将Windows用于客户端和服务器。 我只能找到一堆tomcat,Catalina,host-manager和localhost日志文件。 没有访问日志? 我也尝试过配置一组新的VDI主机,但问题仍然存在,尽管它在尝试获取和失败之间不断循环时会尝试很多。 我在另一篇文章中发现,如果您在成像前获得原始图像的许可证可能会出现问题。 您是否了解任何问题,是否有从图像中删除许可证的简洁方法? 以上来自于谷歌翻译 以下为原文 Sorry - I can't find that dir on either server or client? I am using Windows for both client and server if that makes a difference. I can only find a bunch of tomcat, Catalina, host-manager, and localhost log files. No access logs? I have also tried provisioning a new set of VDI hosts but the issue persists although it does try a lot to get a license constantly cycling between acquiring and failing. I found in another post there can be problems if you acquire a license in the original image before imaging. Are you aware of any issues and is there a clean way of removing the license from the image? |
如果在应用NVIDIA许可证之前开始建立用户会话,请查看此博客文章,该文章有一些很好的解决方法:
https://jhmeier.com/2018/05/16/nvidia-grid-license-not-applied-before-the-user-connects/ 路径:HKLM SOFTWARE NVIDIA Corporation Global GridLicensing 键入:DWORD 名称:IgnoreSP 价值:1 KB文章在这里: http://nvidia.custhelp.com/app/answers/detail/a_id/4638/~/grid-license-not-acquired-in-time-for-first-user-logon%2C-or-i-log- 在和屏 http://nvidia.custhelp.com/app/answers/detail/a_id/4643/~/issues-in-remote-desktop-sessions-if-a-license-is-acquired-after-a-session-is 以上来自于谷歌翻译 以下为原文 Check out this blog post which has some good workarounds if the user session is begin established prior to the NVIDIA license being applied: https://jhmeier.com/2018/05/16/nvidia-grid-license-not-applied-before-the-user-connects/ Path: HKLMSOFTWARENVIDIA CorporationGlobalGridLicensing Type: DWORD Name: IgnoreSP Value: 1 KB Article(s) here: http://nvidia.custhelp.com/app/answers/detail/a_id/4638/~/grid-license-not-acquired-in-time-for-first-user-logon%2C-or-i-log-in-and-screen http://nvidia.custhelp.com/app/answers/detail/a_id/4643/~/issues-in-remote-desktop-sessions-if-a-license-is-acquired-after-a-session-is |
感谢您提供新信息。
我已经应用了该注册表项。 我现在的问题是我根本无法获得许可证。 它只是报告无法在弹出通知中获取许可证。 然后循环获取许可证...... 以上来自于谷歌翻译 以下为原文 Thanks for the new info. I have already applied that registry key though. My issue now is that I am not able to acquire a license at all. It just reports Failed to acquire license in a popup notification. Then cycles around to acquiring license... |
好的 - 我发现Windows服务器上的日志文件位于C: Windows ServiceProfiles NetworkService flexnetls nvidia logs,从中我发现有错误 -
16:37:26,626 WARN无法处理功能GRID-Virtual-PC 2.0 count = 1的请求。 原因:FEATURE_NOT_AVAILABLE。 16:37:29,416 WARN无法处理功能GRID-Virtual-WS 2.0 count = 1的请求。 原因:FEATURE_NOT_AVAILABLE。 16:37:32,158 WARN无法处理Quadro-Virtual-DWS 5.0 count = 1的功能请求。 原因:FEATURE_SERVER_HOST_ID_MISMATCH。 16:37:34,884 WARN无法处理功能GRID-Virtual-WS-Ext 2.0 count = 1的请求。 原因:FEATURE_NOT_AVAILABLE。 这一遍又一遍地重复。 以上来自于谷歌翻译 以下为原文 OK - I found the log files on a Windows server are located at C:WindowsServiceProfilesNetworkServiceflexnetlsnvidialogs and from this I found that there is an error - 16:37:26,626 WARN Unable to handle request for feature GRID-Virtual-PC 2.0 count=1. Reason: FEATURE_NOT_AVAILABLE. 16:37:29,416 WARN Unable to handle request for feature GRID-Virtual-WS 2.0 count=1. Reason: FEATURE_NOT_AVAILABLE. 16:37:32,158 WARN Unable to handle request for feature Quadro-Virtual-DWS 5.0 count=1. Reason: FEATURE_SERVER_HOST_ID_MISMATCH. 16:37:34,884 WARN Unable to handle request for feature GRID-Virtual-WS-Ext 2.0 count=1. Reason: FEATURE_NOT_AVAILABLE. This is repeated over and over. |
嗨马特曼,
从消息HOST_ID不匹配我首先检查你的licserver。 似乎有一些变化(例如MAC或IP),因此lic文件不再有效。 问候 西蒙 以上来自于谷歌翻译 以下为原文 Hi Matman, from the message HOST_ID mismatch I would first of all check your licserver. Seems there is something changed (MAC or IP for example) so that the lic file is not valid any more. Regards Simon |
谢谢西蒙。
这就是我的想法。 发现我必须将MAC地址设置为静态,因为许可证服务器已实时迁移到新主机并收到新的MAC地址。 使用许可证上使用的设置将其设置为静态,并且所有设置都恢复正常。 以上来自于谷歌翻译 以下为原文 Thanks Simon. That's what I was figuring. Found that I had to set the MAC address to static as the license server had live migrated to a new host and received a new MAC address. Set it to static with the one used on the license and all is back to normal. |
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3176 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3587 浏览 4 评论
GMT+8, 2025-2-24 08:52 , Processed in 0.793132 second(s), Total 91, Slave 75 queries .
