大家好,我是我修电工程的最后一年。目前我正在为我的毕业设计做一个项目。在这个项目中,我尝试设计一种开发板,它与USB到JTAG转换器进行通信。我使用的微控制器是AT32 UC3A0512,我使用的USB到JTAG转换器是FT223 2HL。我选择的原因是什么。这种微控制器是因为它支持Modbus,并且可以使用大量的I/O引脚和模拟引脚。我已经用FTTPRG编程了FT2262HL,用于JTAG的目的。我的问题是,我不知道从哪里开始初始化设备,所以它可以与微控制器通信,因为我找不到任何人已经做过这件事。我希望有人能帮助我开始,因为我不。我不知道从哪里开始,谢谢你。
以上来自于百度翻译 以下为原文 Hello everyone, I'm in my last year of my study electrical engineering. Currently I'm working on a project for my graduation. In this project I'm trying to design some kind of a developmentboard that communicates with an USB to JTAG converter. The microcontroller I'm using is the at32uc3a0512 and the USB to JTAG converter I'm using is the ft2232hl. The reason why I chose this microcontroller is because it supports Modbus and has a large number of I/O pins and analog pins I can use. I already programmed the ft2232hl with FT_prog to be used for JTAG purposes. My problem is that I don't know where to start to initialise the device so it can communicate with microcontroller, because I can't find anyone who did this already. I hope someone can help me getting started, because I don't have a clue where to begin. Thank you in advance. |
我认为第一个开始的地方是读芯片数据表/PDF,查找所有你不理解的单词,直到你得到一个线索开始。作为一个工程师,你不能总是把你的工作放在另一个工作上,但是必须经常从头开始。也许有一个P。重新制作的开发板,如果你坚持复制,你可以开始。
以上来自于百度翻译 以下为原文 I would think the first place to start would be reading the chip data sheet / pdf , looking up all the words you do not understand till you gain a clue where to begin. As an engineer you will not always be able to base your work on that of another but must often start from scratch. Maybe there is a pre made development board you could start with if you insist on copying. |
嗨,你可能有点在这个论坛的错误的地方。虽然Atmel和Microchip已经合并,AvrFRAKS论坛仍然运行与以前相同的URL地址,大多数AVR爱好者仍然在那里。PIC设备也大多通过ICSP编程和调试,这是一个DI。JTAG协议,所以在微芯片论坛中很少涉及JTAG的活动,很多PIC设备都有JTAG硬件接口。它用于生产测试,但很少用于固件的开发和调试。与Atmel的合并似乎有一些协同作用:新的PACIT 4开发程序员和调试器工具,似乎大部分是适应JTAG和JTAG的Atmel程序员。ICSP接口,以支持所有的微芯片微控制器产品。在Microchip网站的AT32 UC3A0512的产品网页中,在文档中,除了设备的数据表外,还列出了许多应用注意事项。还有一些提到JTAG。迈西尔
以上来自于百度翻译 以下为原文 Hi, You may be somewhat in the wrong place here in this Forum. While Atmel and Microchip have merged, AVRfreaks forum is still running with the same URL addresses as before, with most of the AVR enthusiasts still there. Also PIC devices have mostly been programmed and debugged thru ICSP, which is a different protocol from JTAG, so there is little activity related to JTAG in Microchip Forum. Many PIC devices have JTAG hardware interface. It is used in production testing, but seldom for firmware development and debugging. There seem to be some synergies coming along from the merger with Atmel: The new PICkit 4 development programmer and debugger tool, seem to be mostly a Atmel programmer that have been adapted to handle both JTAG and ICSP interfaces, in order to support all Microchip microcontroller products. In the Product webpage for AT32UC3A0512 in Microchip website, under Documentation, there are listed a number of Application Notes in addition to Datasheet for the device. Also some mentioning JTAG. Mysil |
5064 浏览 9 评论
1946 浏览 8 评论
1880 浏览 10 评论
3106 浏览 3 评论
2177 浏览 5 评论
619浏览 1评论
495浏览 1评论
351浏览 1评论
521浏览 0评论
427浏览 0评论
GMT+8, 2024-9-22 20:31 , Processed in 1.215591 second(s), Total 79, Slave 63 queries .
