我在使用ADV7181C采集PC输出的VGA图象,图象分辨率是1024x768,ADV7181C被设置成SDR-16bit-YUV422输出,寄存器设置如下(省去了器件地址0x42):
unsigned char adv7181c_regs[]={ //##CP XGA 1024x768## //:RGB 1024x768 _@ 60Hz 12-Bit DDR 65.000MHz Out through HDMI: 0x03, 0x02<<2, //16-bit @ LLC2 4:2:2 LLC2=LLC1 /2 0x05, 0x02, // Prim_Mode =010b for GR 0x06, 0x0C, // VID_STD=1100b for 1024x768 _@ 60 0xC3, 0x46, // ADC1 to Ain4, ADC0 to Ain6, 0xC4, 0xB5, // ADC2 to Ain5 and enables manual override of mux 0x1D, 0x47, // Enable 28MHz Crystal 0x3A, 0x21, // set latch clock settings to 010b, Power Down ADC3 0x3B, 0x61, // Enable Internal Bias 0x3C, 0x5D, // PLL_QPUMP to 101b 0x6A, 0x00, // DLL Phase Adjust 0x6B, 0x83, // Swap Pr & Pb 0xC9, 0x00, // Set DDR_DISABLE 0x73, 0x90, // Set man_gain 0x7B, 0x1D, // TURN OFF EAV & SAV CODES Set BLANK_RGB_SEL 0x85, 0x03, // Enable DS_OUT 0x86, 0x0B, // Enable stdi_line_count_mode 0xF4, 0x3F, // Max Drive Strength 0x0E, 0x80, // ADI Recommended Setting 0x52, 0x46, // ADI Recommended Setting 0x54, 0x00, // ADI Recommended Setting 0xF6, 0x3B, // ADI Recommended Setting 0x0E, 0x00, // ADI Recommended Setting 0x52, 0x80, // ADI Recommended Setting 0x57, 0x08, // ADI Recommended Setting 0x5B, 0x20, // ADI Recommended Setting 0x5C, 0x00, // ADI Recommended Setting 0x62, 0x00, // ADI Recommended Setting 0x63, 0x01, // ADI Recommended Setting 0x67, 0x03, // ADI Recommended Setting 0x68, 0x01, // ADI Recommended Setting }; 采集到的图象如下: 原始图象如下: 请问这是什么问题造成的呢? 另外,我在使用8bit sdr bt656格式采集CVBS图象时是正常的 |
ADV7181C输出的16bit数据线与后端芯片连接是否有问题?ADV7181C输出的寄存器配置,和硬件连接是否一致?
2261个成员聚集在这个小组
加入小组给ADUM4223 增加信号驱动15V电压就不正常, 波动很大会被烧是什么情况?
1270 浏览 2 评论
1874 浏览 1 评论
4220 浏览 2 评论
8970 浏览 1 评论
3122 浏览 1 评论
1385浏览 3评论
1629浏览 2评论
1585浏览 2评论
1271浏览 2评论
1371浏览 1评论
GMT+8, 2024-11-10 16:50 , Processed in 0.658781 second(s), Total 43, Slave 38 queries .
