NVIDIA GRID是否支持VMWare的10位颜色格式?
我想在专业市场上对10位色的需求会增加。 以上来自于谷歌翻译 以下为原文 Does NVIDIA GRID support 10-bit color format with VMWare? I guess the demand for 10-bit color would be increasing in professional markets. |
4个回答
嗨Tsumatsumo,
首先,VMWare或Citrix需要在远程协议中支持这一点,否则没有任何意义。 据我所知,今天不支持/工作。 几乎没有人要求他们推动这一主题。 问候 西蒙 以上来自于谷歌翻译 以下为原文 Hi Tsumatsumo, first of all VMWare or Citrix need to support this in the remoting protocol otherwise it makes no sense. As far as I know it is not supported/working today. There is to little demand to push them on this topic. Regards Simon |
问题出在NVidia方面。
有可能用驱动程序> = r376捕获10位颜色,但NVidia Grid(vGPU)驱动程序卡在 以上来自于谷歌翻译 以下为原文 The problem is on NVidia side. There is possibility to capture 10-bit color with drivers >= r376 but NVidia Grid (vGPU) drivers are stuck in <= r370 and no information about backport of this feature was published (see https://gridforums.nvidia.com/default/topic/402/grid-boards/10bit-hardware-and-vdi-for-medical-purpose/post/3915/). You can use Quadro card in passthrough mode but be aware of NVidia unknown status about passthrough of Pxxxx cards (see https://devtalk.nvidia.com/default/topic/992447/). Terrible NVidia ! |
嗨mcerveny,
不幸的是你似乎没有看到整个画面。 正如我所说,只要远程供应商(Citrix和VMWare)不提供解决方案,我们就没有任务。 顺便说一下,最新的UDA驱动程序分支将很快推出下一个GRID主要版本。 Tsumatosumo特别询问VMWare,所以你应该在责备别人之前考虑到这一点。 问候 西蒙 以上来自于谷歌翻译 以下为原文 Hi mcerveny, unfortunately you seem not to look at the whole picture. As I said already as long as the remoting vendors (Citrix and VMWare) doesn't provide a solution there is no task on our side. And btw there will be the next GRID major release very soon with the latest UDA driver branch. Tsumatosumo especially asked about VMWare so you should definetely take this into consideration before blaming others. Regards Simon |
西蒙你好
您认为只有Citrix和VMWare吗? 我的解决方案完全能够支持H.265 Main10远程协议,但我被NVidia“等待”决定阻止了。 VMWare能够直接通过vDGA,这是迈向2017年1月(NVidia Capture SDK 6.0)启用10位编码的第一步(直到新的Grid驱动程序),但您可能需要Pascal Quadro GPU(NVidia Video Codec SDK 8.0)。 Pascal Quadro GPU(Pxxxx)不在VMWare vDGA兼容性列表中,我想它不会在这里,因为VBios或guest虚拟机中的驱动程序初始化代码中存在某些问题。 我找到了Xen虚拟化的解决方法。 我的观点:像往常一样,我并非要求NVidia方面或者没有任何解决方案(如果有任何问题,它将无法用于无许可证的Grid K1 / K2)。 我根据我的真实编程实验仅描述了我的观点,并且我不试图干涉NVidia的Visions。 你真诚的,马丁 以上来自于谷歌翻译 以下为原文 Hello Simon. Do you think that there is only Citrix and VMWare ? My solution is perfectly capable of H.265 Main10 remote protocol but I am blocked by NVidia "waiting" decision. VMWare is capable of passthrough vDGA that is first step (until new Grid drivers) to enable 10bit encoding from Jan 2017 (NVidia Capture SDK 6.0) but you probably need Pascal Quadro GPU (NVidia Video Codec SDK 8.0). Pascal Quadro GPUs (Pxxxx) are not on VMWare vDGA compatibility list and I suppose it will not be here because there is something crippled in VBios or driver initialization code in guest. I found workaround for Xen virtualization. My opinion: As usual I am not requesting neither or expecting any solution from NVidia side (if something will come either it won't be usable for licenseless Grid K1/K2). I described only my point of view based on my real programming experiments and I do not try to interfere with NVidia's Visions. Yours sincerely, Martin |
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3278 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3705 浏览 4 评论
GMT+8, 2025-7-12 09:10 , Processed in 0.716283 second(s), Total 81, Slave 65 queries .
