你好,
我正在运行带有GRID K1和Citrix XenDesktop 7.1 / XenServer 6.2的Dell R720。 今天我将最新的Nvidia vGPU驱动程序(NVIDIA-GRID-vGPU-331.59-332.83-win64)应用到我的主机和虚拟机,现在我在启动今天早些时候使用旧驱动程序的应用程序时获得了BSOD。 我很乐意让Citrix或Nvidia的某个人看一看,或者至少得到他们的意见。 由于BSOD错误消息中提到的“nvlddmkm.sys”,我认为这是一个Nvidia的事情。 SYSTEM_SERVICE_EXCEPtiON *** nvlddmkm.sys 我不确定从这里收集什么数据或尝试什么。 很奇怪,因为这个应用程序曾经工作,但现在我们更新了驱动程序它不起作用和BSODs。 谢谢! 以上来自于谷歌翻译 以下为原文 Hello, I am running a Dell R720 with GRID K1's and Citrix XenDesktop 7.1/XenServer 6.2. Today I applied the latest Nvidia vGPU drivers (NVIDIA-GRID-vGPU-331.59-332.83-win64) to my host and VMs and now I get the BSOD when launching an application that was working earlier today with older drivers. I’d love to get someone from Citrix or Nvidia to take a look, or at least get their opinion. I think it’s an Nvidia thing due to the “nvlddmkm.sys” mentioned in the BSOD error message. SYSTEM_SERVICE_EXCEPTION *** nvlddmkm.sys I am not sure what data to gather or what to try from here. Weird since this application used to work but now that we have updated the driver it does not work and BSODs. Thanks! |
13个回答
感谢ajfilla报告此问题。
1)是否可以共享BSOD完全内存转储进行初始分析? 2)>>>启动应用程序时我得到了BSOD 您能否在启动哪个应用程序时确认您正在看BSOD? 3)>>>今天早些时候与老司机一起工作 您能帮忙确认旧的/工作主机和VM驱动程序版本吗? 4)如果你在主机和VM上切换到较旧的驱动程序版本,应用程序工作正常吗? 5)请运行nvidia-bug-report.sh脚本提供nvidia bug报告 以上来自于谷歌翻译 以下为原文 Thanks ajfilla for reporting this issue. 1) Is it possible to share BSOD full memory dump for initial analyze? 2) >>>I get the BSOD when launching an application Could you please confirm while launching which application you are seeing BSOD? 3) >>>that was working earlier today with older drivers Could you please help to confirm the older / working host and VM driver version? 4) If you switch to older driver version [on both host and VM], application is working fine? 5) Please provide nvidia bug report by running nvidia-bug-report.sh script |
你好,
你刚刚安装了最新的NVIDIA驱动程序,还是重新安装了XenTools和VDA? 干杯, 埃里克 Erik Bohnhorst | 解决方案架构师 - GRID NVIDIA公司 以上来自于谷歌翻译 以下为原文 Hello, did you just install the latest NVIDIA driver or did you reinstall XenTools and VDA again as well? Cheers, Erik Erik Bohnhorst | Solution Architect – GRID NVIDIA Corporation |
你好,
我会在今天下午尽快生成日志和完整的内存转储。 我们使用的是BAE SocetGXP 3.2。 我也会发送较旧的驱动程序版本。 我没有重新安装XenServer Tools或HDX3DPro VDA - 我在Win7 VM上安装了新的Nvidia驱动程序时运行了MontereyEnable exe。 谢谢! 安迪 以上来自于谷歌翻译 以下为原文 Hello, I will generate the logs and full memory dump as soon as I can this afternoon. We were using BAE SocetGXP 3.2. I will send the older driver versions out as well. I did not reinstall XenServer Tools or the HDX3DPro VDA - I did run the MontereyEnable exe upon installation of the new Nvidia drivers on the Win7 VM. Thanks! Andy |
我无法将压缩的屏幕截图,迷你转储和NVidia日志添加到网站。
以上来自于谷歌翻译 以下为原文 I'm having trouble adding the zipped up screenshot, mini dump, and NVidia logs to the site. |
转到上一条评论,右上角,您可以找到附件图标。
用它来上传附件。 以上来自于谷歌翻译 以下为原文 Go to your last comment, top right corner, you can find the attachment icon. Use that to upload the attachments. |
谢谢ajfilla,
你能帮忙分享一下BAE SocetGXP 3.2吗? 或者是否有任何其他应用程序/软件将帮助我们在本地重现此问题? 以上来自于谷歌翻译 以下为原文 Thanks ajfilla, Can you please help to share the BAE SocetGXP 3.2? or Is there any other applications / software's will help us to reproduce this issue locally? |
嗨Raja,该软件需要一个浮动许可证才能运行,我无法分享。
我可以通过GoToMeeting从Nvidia远程访问我的系统,如果你有帮助的话。 以上来自于谷歌翻译 以下为原文 Hi Raja, That software required a floating license to run and I can't share that out. I can give someone from Nvidia remote access into my system via GoToMeeting if you that would help. |
好的,我们在K100,K120Q和K140Q模式下使用331.59-332.83驱动程序重新进行了测试。
除了GPU的模式之外,每个测试中的一切都是相同的。 当我们在K100模式下运行它时,应用程序运行,但它在K120Q和K140Q模式下对我们的Win7会话进行了BSOD。 以上来自于谷歌翻译 以下为原文 Okay so we reran the tests with the 331.59-332.83 drivers in K100, K120Q, and K140Q modes. Everything was the same in each test except for the mode of the GPU. The application functioned when we ran it in K100 mode, but it BSOD our Win7 session in both K120Q and K140Q mode. |
ajfilla,我正面临着推出SocetGXP 4.0& amp;
3.1。 我在VM上安装了这个应用程序和许可证服务器并且工作正常。 但Launch manger没有展示任何产品/模块。 我已将USB许可证密钥连接到xenserver主机并传递给win7 VM。 你如何在VM上使用u***许可证? 我们无法使SocetGXP 4.0在VM上运行。 但是我们安装了SoCET SET 5.5,加载并启动了项目并观察了BSOD。 我们也在VNC会话上观察到BSOD。 您是否也可以使用SoCET SET 5.5重现此问题? 该问题是否也在VNC连接上重现? 以上来自于谷歌翻译 以下为原文 ajfilla, I am facing some issue for launching SocetGXP 4.0 & 3.1. I have installed this app and license server on VM and its working fine. But Launch manger is not showing any product/module to launch. I have connected USB license key to xenserver host and pass-through to win7 VM. How you are using u*** license on the VM? We are not able to make SocetGXP 4.0 work on VM. But we installed SoCET SET 5.5, loaded and launched project and observed BSOD. We observed BSOD on VNC session as well. Are you also able to repro this issue with SoCET SET 5.5 ? Is the issue repro on VNC connection as well? |
Sandipt,
我会检查一下,看看我是否可以参加SocetSet 5.5,但我不确定。 关于SocetGXP - 我没有使用USB密钥 - 我使用的是服务器浮动许可证。 也许我们可以安排一个时间,我可以让你通过VNC或GoToMeeting进入我的实验室,实时查看SocetGXP问题。 那会有帮助吗? -Andy 以上来自于谷歌翻译 以下为原文 Sandipt, I will check and see if I can get my hands on SocetSet 5.5 but I am not sure. With regards to SocetGXP - I am not using a USB key - I am using a server floating license. Perhaps we can schedule a time and I could allow you to VNC or GoToMeeting into my lab to view the SocetGXP issue in real time. Would that help? -Andy |
大家好,
我在许多带有K1和K2卡的XenServer上运行XenDesktop 7.1。 虚拟桌面随机播放蓝屏并引用驱动程序dxgmms1.sys。 我知道这是一个DirectX驱动程序。 大多数时候,我实际上发现虚拟桌面是在Windows恢复模式下启动的。 我已经能够抓住蓝调了。 Windows事件日志不会显示导致问题的任何内容。 我相信这些机器只是空闲时的蓝屏,因为没有用户报告在会话期间被踢出局。 虚拟桌面可以跨各种不同的主机和GPU配置文件进行蓝屏扫描。 K1和K2直通以及vGPU配置文件K120Q和K140Q均为蓝屏。 所有虚拟桌面都是64位Windows 7,并且没有根据需要从Windows Update显示Direct X更新。 如果我运行DXdiag,则表明我有DirectX 11.Microsoft指出,即使系统具有DirectX 11.1或11.2,该工具也会读取“DirectX 11”。 我还运行了64位DxDiag,它说没有发现任何问题。 我几周前更新了XenServer和GRID Manager,但问题发生在此之前。 以下是我目前的驱动程序。 如果您从2014年9月22日到http://www.imvidia.com/download/driverResults.aspx/77752/en-us访问此站点,我将使用发布的所有最新驱动程序“331.59.01 / 332.83 “ 从Windows设备管理器:9.18.13.3283 所有XenServer都具有:NVIDIA-vgx-xenserver-6.2-331.59.01.i386.rpm XenServer的: 建立日期2014-06-26 BUild号码:70446c 版本:6.2 有没有其他人经历过这个或对下一步有任何想法? 谢谢你的帮助!! 理查德 以上来自于谷歌翻译 以下为原文 Hi All, I have XenDesktop 7.1 running on a number of XenServers with K1 and K2 cards. The virtual desktops are bluescreening at random times and referencing the driver, dxgmms1.sys. I understand that this is a DirectX driver. Most of the time, I actually find the virtual desktops started in Windows Recovery Mode. I have been able to catch it bluescreened though. Windows event logs do not show anything leading up to the issue. I believe these machines are just bluescreening while idle as no users have reported getting kicked out during a session. The virtual desktops are bluescreening across various different hosts and GPU profiles. The are bluescreens on both K1 and K2 passthroughs and vGPU profiles K120Q and K140Q. All the virtual desktops are 64 bit Windows 7 and there are no Direct X updates showing as needed from Windows Update. If I run DXdiag, it shows that I have DirectX 11. Microsoft notes that this tool reads "DirectX 11" even if the systems have DirectX 11.1 or 11.2. I also ran the 64bit DxDiag and it said that there were no problems found. I updated XenServer and the GRID Manager a couple of weeks ago but the issue occurred before then. Here are my current drivers below. If you go to this site http://www.nvidia.com/download/driverResults.aspx/77752/en-us as of 9/22/2014, I am using all the latest drivers from release "331.59.01/332.83" From Windows Device Manager: 9.18.13.3283 All XenServers have: NVIDIA-vgx-xenserver-6.2-331.59.01.i386.rpm XenServer: Build Date 2014-06-26 BUild Number: 70446c Version: 6.2 Has anyone else experienced this or have any ideas on next steps? Thanks for your help!! Richard |
你好,
我有XenDesktop 7.1运行一个带K1的XenServer 具有Windows 8.1 64位的VM始终进行蓝屏并引用驱动程序nvlddmkm.sys。 XenServer驱动程序:NVIDIA-vgx-xenserver-6.2-331.59.01.i386.rpm Windows最新驱动程序:332.83 XenServer包含所有更新 有没有其他人经历过这个或对下一步有任何想法? 谢谢你的帮助!! 米格尔比斯波 以上来自于谷歌翻译 以下为原文 Hello, I have XenDesktop 7.1 running one XenServer with K1 The VM with Windows 8.1 64 bits are bluescreening all times and referencing the driver nvlddmkm.sys. XenServer driver: NVIDIA-vgx-xenserver-6.2-331.59.01.i386.rpm Windows latest driver: 332.83 XenServer with all updates Has anyone else experienced this or have any ideas on next steps? Thanks for your help!! Miguel Bispo |
嗨米格尔,
您能否详细介绍一下您正在使用的应用程序。 谢谢 以上来自于谷歌翻译 以下为原文 Hi Miguel, Can you give some detail on the applications you're using. Thanks |
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
2982 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3394 浏览 4 评论
GMT+8, 2024-9-20 14:48 , Processed in 0.730552 second(s), Total 64, Slave 59 queries .
