我在8164A主机上有81600B,但它最近开始重启并且无法完全启动。
50欧姆处于联锁状态。 任何建议 以上来自于谷歌翻译 以下为原文 I have got 81600B on a 8164A mainframe but it has recently started to reboot itself and failing to power up fully. The 50 ohm is in the interlock. Any advice |
这很可能是8164A主机的硬件问题。
您可以检查它是否仍然可以正常启动而无需任何模块来本地化大型机的问题。 如果您有另一台主机,您可以尝试在该主机上测试激光模块。 然后需要将有缺陷的产品送去维修。 由于8164A已过时,并非所有部件都可用。 以上来自于谷歌翻译 以下为原文 Most likely this is a hardware problem with the 8164A mainframe. You could check whether it can still boot correctly without any modules to localize the problem with the mainframe. If you have another mainframe, you could try testing the laser module in that one. Then the defective product will need to be sent for repair. Since the 8164A is obsolete, not all parts may be available. |
1287 浏览 0 评论
2375 浏览 1 评论
2194 浏览 1 评论
2064 浏览 5 评论
2951 浏览 3 评论
1111浏览 1评论
753浏览 0评论
926浏览 0评论
1287浏览 0评论
GMT+8, 2024-12-24 09:17 , Processed in 1.493225 second(s), Total 44, Slave 38 queries .
