我在EVB博客上看到,新的PACKIT4将支持AVR MCU。这是真的吗?我在任何一个文学作品中都没有看到过。有人能证实或否认吗?我看到这个家伙使用AVR龙来编程PIC MCU,所以这里似乎有一些跨平台的业务,但是PACKIT4实际上能编程AVR的吗?如果是,新的MPLABX IDE允许使用AVR的项目吗?
以上来自于百度翻译 以下为原文 I saw on eevblog post that the new pickit4 is going to support the avr mcu's. Is this true? I have not seen this in any of the literature. Can anyone confirm or deny this? I saw the guy use the avr dragon to program a pic mcu, so there seems to be some cross platform business going on here, but can the pickit4 actually program avr's? If so, does the new mplabx ide allow projects with the avr's? |
嗨,在MPLAB X V4.15中,当你创建一个项目时,你已经可以看到一个8位AVR MCU的条目,但是你仍然不能选择一个部分。这意味着这还没有实现。PICTIT4(ICD4)有8位ICSP(PICTIT3和ICD3只有6个引脚),所以将来他们可能会编程其他部分,但没有可见的信息。
以上来自于百度翻译 以下为原文 Hi, In MPLAB X v4.15, when you create a project you can already see an entry for 8-bit AVR MCUs but you cannot yet select a part. It just means that this is not yet implemented. Pickit4 (an ICD4 ) have 8 bits ICSP (Pickit3 and ICD3 have just 6 pins) so in the future they will probably program other parts but no visible information yet. Regards |
是的,这一代开发工具的意图将支持所有AVR/山姆/PIC设备。收购完成后,也可能会支持新的微半部分。但它还没有列入任务清单。
以上来自于百度翻译 以下为原文 Yes, the intention of this current generation of development tools will support all AVR/SAM/PIC device. There will probably also be support for the new Microsemi parts, now that the acquisition is complete. But it's not on the list of tasks yet. |
5362 浏览 9 评论
2093 浏览 8 评论
1992 浏览 10 评论
3274 浏览 3 评论
2305 浏览 5 评论
870浏览 1评论
756浏览 1评论
699浏览 1评论
750浏览 0评论
644浏览 0评论
GMT+8, 2025-2-24 04:59 , Processed in 1.422866 second(s), Total 76, Slave 60 queries .
