你好,我想在Flash地址X0xC00中设置一个标志。在启动之前,我从BooDouther-main中运行这个代码,它工作。Bootloader占用内存的前2页,页3被保留为状态标志。后来从我的应用程序运行,从地址0x1000到以后,如果我运行相同的代码,Flash地址没有被正确地写入。所以PIC24可以写入到T以外的闪存位置吗?在链接器脚本中定义了程序空间?我使用的是PIC24FJ128GB202
以上来自于百度翻译 以下为原文 Hello, I am trying to set a flag in flash at address 0x00C00. From my bootloaders main before anything starts I run this code and it works. The bootloader takes the first 2 pages of memory and page 3 is reserved for status flags. // Write the new launching flag to memory. NVMCON = 0x4003; uint16_t dataL = 0x01; //lint !e9034 !e712 uint16_t dataH = 0xFFFFU; __builtin_tblwtl(0xBD2C, dataL); //Write the low word to the latch i __builtin_tblwth(0xBD2C, dataH); //Write the high word to the latch (8 bits of data + 8 bits of "phantom data") i+1 disable_interrupts(); __builtin_write_NVM(); while(NVMCONbits.WR == 1U){} NVMCONbits.WREN = 0; enable_interrupts(); Later from my application which runs from addresses 0x1000 to much later, if I run the same code the flash address is not properly written to. So can a PIC24 write to a flash memory location that is outside of the program space defined in its linker script? I am using a PIC24FJ128GB202 |
它被擦除了。你需要一次擦除一个Flash页面。/ Ruben
以上来自于百度翻译 以下为原文 And it is erased. You need to erase one flash page at a time. /Ruben |
5565 浏览 9 评论
2214 浏览 8 评论
2106 浏览 10 评论
3386 浏览 3 评论
2421 浏览 5 评论
1054浏览 1评论
889浏览 1评论
905浏览 1评论
934浏览 0评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 威廉希尔官方网站 问题可以咨询我,微信:A-chip-Ti
638浏览 0评论
GMT+8, 2025-7-6 04:05 , Processed in 1.173529 second(s), Total 49, Slave 43 queries .
