大家好。我正在使用S29 GL01GP设备。当我尝试编程内存时,我看到RI/BIN引脚在60s(TWHW1)的夏令时间之前变高。我的体重大约是7。
我还发现,当这种情况发生时,数据不会被编程。这是“写不成功”的警告吗? 谢谢你的帮助。 以上来自于百度翻译 以下为原文 Hi everyone. I am working with the S29GL01GP device. When I try to program the memory, I see that the RY/BY pin goes high before the estipulated time of 60us (tWHWH1). I am measuring around 7 us. I also figured out that when this happens, the data is not programmed. Is this some kind of warning of "write not successful"? Thanks for your help. |
3个回答
你好,
RY/BY引脚是闪存状态控制器的专用输出引脚,这在数据表7.7.1的部分中描述,您可以通过检查该引脚简单地知道芯片是否处于忙碌状态。 若要获取特定信息和错误类型,可以使用数据表中提到的DQ切换方法。不同的DQ位组合和定义简单地如下,更多信息,请参阅数据表的第7.8部分。 文森翰 客户应用工程师,赛普里斯。 以上来自于百度翻译 以下为原文 Hi, The RY/BY# pin is the dedicate output pin from the flash state controller, this described in the section 7.9.1 of the datasheet, you can simply know whether the chip is in busy state by checking this pin. To get the specific information and error type, you can use the DQ toggle method mentioned in the datasheet. The different DQ bit combination and definition is simply as follow, for more information, please refer the Section 7.8 of the datasheet. Vincent Han Customer Application Engineer, Cypress. |
lkxzmclz 发表于 2018-9-19 10:33 谢谢文森特。 我想知道为什么RI/BY的PIN从数据表中的典型时间提前(0)到“1”(或高Z)。 我用这个信号来指示我的Flash控制器,程序已经准备好了,开始下一个单词编程,但是它不起作用。 除此之外,我没有在写操作状态实现数据查询。要完成单字编程周期? 当做, 但丁 以上来自于百度翻译 以下为原文 Thanks Vincent. I would like to know why RY/BY# pin goes from '0' to '1' (or high Z) before the typical time estipulated in the datasheet (section 11.7.3). I'm using this signal to indicate my flash controller that the program is ready and start the next word programming, but it's not working. Besides, I didn't implement the data polling in the write operation status. Is it necessary to complete the single word programming cycle? Regards, Dante |
我已经知道,RI/BY信号的“0”级持续时间取决于数据路径中“1”的数量。
例如,当数据为0xFFFF时,最短的低电平时间发生。这是可能的吗?数据表说,典型的时间是60US。我认为它应该是最大的,而不是典型的。 以上来自于百度翻译 以下为原文 I have figured out that the '0' level duration of the RY/BY signal depends on the amount of '1's in the data path. For example, the shortest low level time happens when data is 0xFFFF. Is this possible? Datasheet says that the TYPICAL time is 60us. I think it should be MAX, instead of typical. |
760个成员聚集在这个小组
加入小组2156 浏览 1 评论
1904 浏览 1 评论
3726 浏览 1 评论
1837 浏览 6 评论
1582 浏览 1 评论
791浏览 2评论
549浏览 2评论
489浏览 2评论
448浏览 2评论
1264浏览 2评论
GMT+8, 2025-3-6 21:38 , Processed in 0.833157 second(s), Total 48, Slave 43 queries .
