各位工程师好
最近使用ADV7181c 做PAL视频采集项目,PAL的CVBS/YC/RGsB 输入到ADV7181c ,8bit 4:2:2 YPbPr输出给CPU,然后再输出到显示器。在调试过程中遇到问题,具体如下: 1.PAL CVBS输入,输出黑白,STATUS1寄存器值为0x69; 2.PAL YC输入,输出黑白且模糊,STATUS1寄存器值为0x4d; 3.PAL RGsB输入,输出蓝屏,STATUS1寄存器值为0x8a; 视频源可以确定是没有问题的,配置信息完全官网下载的“ADV7181C_Evaluation_Software”里面的“ADV7181C_ADV7181C@_ADV7341-VER.3.2c.txt”配置,7181c的电路也是按照官方参考电路做的。 在没有信号源输入的情况下输出为蓝屏,应该说明7181c进入到freerun 模式,因此可以排除后端问题。 希望各位工程师能给出解决思路,谢谢! |
5个回答
yweyerwq 发表于 2018-9-19 06:15 谢回复 硬件连接如下图 软件配置如下 ##SETTINGS## :version 3.2 May 4th 2010: End ##SD CVBS## :AUTODETECT CVBS IN NTSC/PAL/SECAM, 8-Bit 422 encoder: 42 00 00 ; CVBS IN 42 03 0C ; 8 Bit Mode 42 04 77 ; Enable SFL 42 17 41 ; select SH1 42 1D 47 ; Enable 28MHz Crystal 42 31 02 ; Clears NEWAV_MODE, SAV/EAV to suit ADV video encoders 42 3A 17 ; Set Latch Clock & power down ADC 1 & ADC2 & ADC3 42 3B 81 ; Enable internal Bias 42 3D A2 ; MWE Enable Manual Window, Colour Kill Threshold to 2 42 3E 6A ; BLM optimisation 42 3F A0 ; BGB 42 86 0B ; Enable stdi_line_count_mode 42 F3 01 ; Enable Anti Alias Filter on ADC0 42 F9 03 ; Set max v lock range 42 0E 80 ; ADI Recommended Setting 42 52 46 ; ADI Recommended Setting 42 54 00 ; ADI Recommended Setting 42 7F FF ; ADI Recommended Setting 42 81 30 ; ADI Recommended Setting 42 90 C9 ; ADI Recommended Setting 42 91 40 ; ADI Recommended Setting 42 92 3C ; ADI Recommended Setting 42 93 CA ; ADI Recommended Setting 42 94 D5 ; ADI Recommended Setting 42 B1 FF ; ADI Recommended Setting 42 B6 08 ; ADI Recommended Setting 42 C0 9A ; ADI Recommended Setting 42 CF 50 ; ADI Recommended Setting 42 D0 4E ; ADI Recommended Setting 42 D1 B9 ; ADI Recommended Setting 42 D6 DD ; ADI Recommended Setting 42 D7 E2 ; ADI Recommended Setting 42 E5 51 ; ADI Recommended Setting 42 F6 3B ; ADI Recommended Setting 42 0E 00 ; ADI Recommended Setting 56 17 02 ; Software Reset 56 00 FC ; Power up all DAcs and PLL 56 01 80 ; SD only mode, Data input on Y-bus 56 80 10 ; SSAF Luma filter enabled, NTSC mode 56 82 c9 ; Step control on, pixel data valid, pedestal on, PrPb SSAF on,CVBS/YC out. 56 84 06 ; RTCO/SFL Enable 56 88 00 ; 8 bit input enabled 56 87 20 ; Encoder PAL/NTSC auto-detect enabled End |
硬件和软件没有问题。请问您有用示波器测量过CbCr上的数值吗?是否有数值输出? |
没有量过,如果要测量的话需要量哪些pin呢?换句话说哪些pin是对应cbcr的? |
问题已经找到了,是软件配置有问题,现在已经正常工作了。 |
1 条评论
2314个成员聚集在这个小组
加入小组1189 浏览 2 评论
1540 浏览 2 评论
2057 浏览 1 评论
4365 浏览 2 评论
9203 浏览 1 评论
2045浏览 3评论
1817浏览 2评论
1198浏览 2评论
1845浏览 2评论
1545浏览 2评论
GMT+8, 2025-3-29 06:16 , Processed in 0.749623 second(s), Total 55, Slave 50 queries .
