你好社区,
因为几个月后我在我以前使用K1的VDI农场安装了一些P40。 从那时起我就产生了一个奇怪的效果:当我打开一个新窗口时,例如当我开始一个新程序时,我会看到半秒钟的背面和白色方格窗口,而不是程序窗口。 在这个短暂的闪光后,该应用程序正常工作。 这是一个已知的错误? 亲切的问候 克里斯蒂亚诺 以上来自于谷歌翻译 以下为原文 Hello community, since a couple of months I have installed some P40 in my VDI fARM where I previously was using K1. Since then I have a strange effect: when I open a new window, for example when I start a new program, I see for half a second a back and white checkered window instead of the program window. After this brief flash, the app works normally. Is this a known bug? Kind regards Cristiano |
5个回答
也许你遇到了已知问题:
https://gridforums.nvidia.com/default/topic/8762 https://gridforums.nvidia.com/default/topic/8651 Nvidia说:升级! 以上来自于谷歌翻译 以下为原文 Maybe you hit known problem: https://gridforums.nvidia.com/default/topic/8762 https://gridforums.nvidia.com/default/topic/8651 Nvidia say: Upgrade ! |
正确!
使用最新的GRID5.2驱动程序修复了R384分支的驱动程序问题。 所以请升级到最新的驱动程序。 问候 西蒙 以上来自于谷歌翻译 以下为原文 Correct! There was a driver issue with R384 branch that is fixed with the latest GRID5.2 drivers. So please upgrade to the latest drivers. Regards Simon |
你好Simon和mcerveny,
会这样做...我希望GPU的情感很快就会出现。 没有,ESXi升级非常烦人 亲切的问候 克里斯蒂亚诺 以上来自于谷歌翻译 以下为原文 Hello Simon and mcerveny, will do that... I hope GPU emotion will be available soon. ESXi upgrade is quite annoying without Kind regards Cristiano |
嗨克里斯蒂亚诺,
没有必要立即进行vGPU管理器升级。 您只需将Windows驱动程序更新为5.2即可。 只要您运行相同的5.x GRID分支,该分支应该可以正常工作,然后您可以在下一个维护时段更新主机驱动程序。 现在,运行支持已准备好用于7.4版本的XenServer。 我们希望在不久的将来也能从VMWare获得一些有关此功能的好消息.... 问候 西蒙 以上来自于谷歌翻译 以下为原文 Hi Cristiano, there is no need to do the vGPU manager upgrade immediately. You can just update the Windows driver to 5.2. As long as you are running the same 5.x GRID branch that should work well and then you can update the host driver during your next maintenance window. Motion support is now ready for XenServer with 7.4 release. We will hopefully have some good news from VMWare in the near future also regarding this feature.... Regards Simon |
西蒙你好,
我升级了ESXi和Windows,因为我必须进行一些vSAN维护。 问题解决了! 谢谢 克里斯蒂亚诺 以上来自于谷歌翻译 以下为原文 Hello Simon, I upgraded both ESXi and Windows, since I had to do some vSAN maintenance. Issue solved! Thanks Cristiano |
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3228 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3643 浏览 4 评论
GMT+8, 2025-4-23 20:10 , Processed in 0.539729 second(s), Total 53, Slave 47 queries .
