我使用Momentum分析输出匹配电路到GaN晶体管。
模拟完成后,我将生成的电路符号放入原理图中。 我还使用数据文件工具生成S参数。 符号和数据项之间的交换(链接到数据文件工具生成的S参数)给出了不同的结果。 我究竟做错了什么? 谢谢,史蒂夫 以上来自于谷歌翻译 以下为原文 I used Momentum to analyze an output match circuit to a GaN transistor. Once the simulation completed, I dropped the generated symbol for the circuit into my schematic. I also used the Data File Tool to generate S-Parameters. Interchanging between the symbol and the Data Item (linked to the Data File Tool generated S-Parameters) gives me different results. What am I doing wrong? Thanks, Steve |
> {quote:title = owkmann写道:} {quote}>符号和数据项之间的交换(链接到数据文件工具生成的S参数)给出了不同的结果。
史蒂夫,你应该得到相同的结果。 差异可以来自您访问数据集的SnP块中定义的不同插值方法。 检查是否已使用自适应频率扫描数据链接到_a数据集,或者只是具有几个频率点的“原始”数据。 对于Symbol和底层emModel数据,一个可能的(微不足道的)错误是,在某些布局更改后重新运行EM模拟时,您没有更新emModel。 手动启动EM模拟时,有一个设置可自动更新emModel。 以上来自于谷歌翻译 以下为原文 > {quote:title=owkmann wrote:}{quote} > Interchanging between the symbol and the Data Item (linked to the Data File Tool generated S-Parameters) gives me different results. Steve, you should get the same results. Differences can be from different interpolation methods as defined in the SnP block where you access the dataset. Check if you have linked to the _a dataset with the adaptive frequency sweep data, or maybe just the "raw" data with a few frequency points. For the Symbol and the underlying emModel data, one possible (trivial) mistake would be that you didn't update the emModel when re-running the EM simulation after some layout change. There is a setting to auto-update the emModel when the EM simulation is started manually. 附件
1392 浏览 0 评论
2423 浏览 1 评论
2273 浏览 1 评论
2109 浏览 5 评论
3025 浏览 3 评论
1483浏览 1评论
833浏览 0评论
1247浏览 0评论
1392浏览 0评论
GMT+8, 2025-3-5 04:48 , Processed in 1.469116 second(s), Total 75, Slave 59 queries .
