有人能告诉我如何在Cube板上填充CYW43907程序吗?我们将很快发布Fab的董事会,并希望证实我们没有遗漏任何东西。
我们将JTAG / SWO港口带来了一个头球,我打算用JLINK。做JLINK程序内部芯片中的SRAM或是编程的外部闪光?如果程序内部SRAM,怎么上传图像到外部闪光? 我看着其他资源下载和调试cyw43907使用Jlink Segger,但尚不清楚是否是发展(SRAM)或写入Flash。 首先我需要能够调试应用程序和程序的原型基于自定义的PCBA板。这最终会导致怎样的程序在制造定制的PCBA。 以上来自于百度翻译 以下为原文 Can someone give me a run down on how to program the CYW43907 populated on a custom board? We will be sending out boards for fab shortly and want to verify that we are not missing anything. We will have the JTAG/SWO port brought out to a header and I plan on using a JLINK. Does the jlink program internal SRAM in the chip or is it programming the external flash? If it programs the internal SRAM, how do I upload a image to the external flash? I have looked at other resources like Downloading and debugging CYW43907 using Jlink Segger but it is not clear if it is for development (SRAM) or writing to flash. To begin with I will need to be able to debug apps and program prototype boards based on the custom PCBA. This will eventually lead to figuring out how to program the custom PCBA in manufacturing. |
5个回答
默认情况下,通过JTAG下载的代码直接编程到外部Sflash。您不必做任何特殊的加载代码到Sflash。您仍然可以使用上面链接的调试文档。
以上来自于百度翻译 以下为原文 The code you download via JTAG is directly programmed into the External SFlash by default. You will not have to do anything special to load the code into SFlash. You can still use the Debug document you linked above. |
khsahdwu 发表于 2018-9-18 09:59 谢谢。这很好知道。 以上来自于百度翻译 以下为原文 Thanks. This is good to know. |
我在跟随向导,在用Zadig切换驱动程序之后,我尝试将我的项目用-Debug JTAG= JLink下载添加到构建命令中,我得到OpenOCD-ALLUBRCM-LBFTTDI.EXE停止了工作消息。 控制台窗口输出 制作.exe [ 1 ]:*** [下载加载引导程序]错误- 1073741819 WICES/平台/MCU/BCM4390X/BCM94390XOR目标.MK:294:目标“下载BooLoad”失败的配方 使:***[MNIONAPP]错误2 MaFixFiel: 351:目标“MeNIApp”失败的配方 建立字符串 CyW943907AEVA1F FRESRTO-LWIP调试JTAG= JLink下载 JTAG:JLink Ultra 以上来自于百度翻译 以下为原文 I am following the guide and after I switch the driver with Zadig, I try to build my project with -debug jtag=jlink download added to the build command, I am getting the openocd-all_brcm-libftdi.exe has stopped working message. console window output make.exe[1]: *** [download_bootloader] Error -1073741819 WICED/platform/MCU/BCM4390x/BCM94390x_targets.mk:294: recipe for target 'download_bootloader' failed make: *** [main_app] Error 2 Makefile:351: recipe for target 'main_app' failed Build string test.CYW943907AEVAL1F-FreeRTOS-LwIP-debug JTAG=jlink download JTAG: JLink-Ultra |
cmh23 发表于 2018-9-18 10:32 我知道CYW43907支持SWD,但会在SVD上下载Studio下载数据吗?我们的自定义板没有连接所有的JTAG引脚到一个编程头。 以上来自于百度翻译 以下为原文 I know the CYW43907 supports SWD but will WICED studio download data over SWD? Our custom board did not connect all of the JTAG pins to a programming header. |
make.exe[1]: *** [download_bootloader] Error -1073741819 WICED/platform/MCU/BCM4390x/BCM94390x_targets.mk:294: recipe for target 'download_bootloader' failed make: *** [main_app] Error 2 Makefile:351: recipe for target 'main_app' failed 请问这个问题解决了吗?我也遇到了相同的问题 想请教一哈? |
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1761 浏览 1 评论
3544 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
273浏览 2评论
170浏览 2评论
355浏览 2评论
297浏览 2评论
487浏览 2评论
GMT+8, 2024-9-20 10:40 , Processed in 0.723747 second(s), Total 53, Slave 48 queries .
