大家好,
请帮忙!! 我用9-30V输入和5V输出制作了DC-DC转换器。您可以在附件中找到eDesign Suite的pdf打印件。 我正在使用的Cin是:C1210C335K5RACTU L是:B82477G4153M Cout是:LMK325BJ476MM-P 在引脚2上,我得到大约500kHz的脉冲,这是可以的。 但是,我在引脚1上获得的波形(也是附加的)具有额外的脉冲,这对我来说很奇怪。 对于大于1.5A的输出电流,电源不工作。输出电压降至4V左右,不稳定。 我的想法用完了,请告诉我你的想法。 #a7986a 以上来自于谷歌翻译 以下为原文 Hi to all, please help!! I made a DC-DC converter from 9-30V input and 5V output. You can find in the attachment a pdf print from the eDesign Suite. The Cin that I'm using is: C1210C335K5RACTU The L is: B82477G4153M The Cout is: LMK325BJ476MM-P On pin 2 I'm getting pulses with around 500kHz which is OK. But, the waveform that I'm getting on pin 1, which is also attached, has additional pulses that are strange to me. For output currents greater than 1.5A the power supply is not working. The output voltage drops to around 4V and it is unstable. I run out of ideas, please tell me your thoughts. #a7986a |
附加信息。
在附件中有另外3个波形,其中电路表现“好”和坏。 以上来自于谷歌翻译 以下为原文 Additional info. In the attachment are additional 3 waveforms where the circuit performed ''good'' and bad. |
2742 浏览 1 评论
3244 浏览 1 评论
1813 浏览 1 评论
3653 浏览 6 评论
6044 浏览 21 评论
1342浏览 4评论
203浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
356浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
446浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
275浏览 2评论
GMT+8, 2024-12-27 07:16 , Processed in 1.050191 second(s), Total 78, Slave 62 queries .
