大家好,我可以使用''ST-LINK / V2''为STM8S系列编程闪存吗?
#ST-LINK / V2 以上来自于谷歌翻译 以下为原文 Hi to all,Can i use ''ST-LINK/V2'' to program flash for STM8S series? #st-link/v2 |
5个回答
我一直使用ST-LINK / V2用于STM8S部件。
以上来自于谷歌翻译 以下为原文 I use ST-LINK/V2 all the time for STM8S parts. |
大家好,我买了st-link v2,但我无法连接到stm8,在jtag上连接stm32没有问题。
stm8上的相同设备通过stm8l152C6T6_discovery_board完美连接。 我做错了什么? 以上来自于谷歌翻译 以下为原文 Hi all, I bought st-linkv2, but I can't connect to stm8, to stm32 on jtag it connect without problem. Same device on stm8 perfect connect by stm8l152C6T6_discovery_board. What do I do wrong? |
你好,
ST-LINK / V2是两个MCU系列的编程/调试工具:STM32和STM8。它们都使用不同的接口(STM32:JTAG或SWD; STM8:SWIM),因此ST-LINK / V2提供两个连接器,每个系列一个。 要将ST-LINK / V2与STM8一起使用,您需要使用名为STM8的4针连接器。这四个引脚分别为:VDD,GND,SWIM和复位。如果将这些引脚(至少VDD,GND和SWIM,因为复位是可选的)连接到相关的STM8引脚,则可以调试和编程MCU。请在下面找到显示与STM8L052连接的ST-Link / V2的照片: 如果您想将ST-LINK / V2与STM8 Discovery套件一起使用,那么首先您需要将ST-LINK / V2引脚连接到MCU引脚,然后您需要通过打开CN3上的跳线来断开Discovery工具包中嵌入的ST-LINK。请在下面找到显示以下内容的照片: Szymon 以上来自于谷歌翻译 以下为原文 Hello, ST-LINK/V2 is a programming/debugging tool for two MCUs families: STM32 and STM8. Both of them use different interface (STM32: JTAG or SWD; STM8: SWIM) and as a result ST-LINK/V2 provides two connectors, one for each family. To use ST-LINK/V2 with STM8 you need to use 4-pin connector named STM8. These four pins are: VDD, GND, SWIM and Reset. If you connect these pins (at least VDD, GND and SWIM, because Reset is optional) to relevant STM8 pins, then you are ready to debug and program the MCU. Please find below a photo showing ST-Link/V2 connected with STM8L052: If you want to use ST-LINK/V2 with STM8 Discovery kit, then first you need to connect ST-LINK/V2 pins to MCU pins and second you need to disconnect ST-LINK embedded on Discovery kit by opening jumpers on CN3. Please find below a photo showing this: Szymon |
耶士!加工。我都做对了,但我不知道一个细微差别,我的ST-LINK没有为我的设备供电。
您帮助在st-link中找到错误。 现在新问题:如何通过ST-Link V2为我的目标设备编程? 以上来自于谷歌翻译 以下为原文 Yess!! Working. I all did the right, but I did not know one nuance, my ST-LINK don't powered my device. You helped find error in st-link. And now new question: How I can powered programmed my target device via ST-LinkV2? |
你好德米特里,
我很高兴你解决了这个问题。 实际上,SWIM连接器无法为MCU供电。该连接器提供VDD引脚,但其目的不是为MCU供电,只是为了验证MCU是否已经供电。 通常,MCU应由其自己的电源供电,而不是从ST-LINK供电。但是我相信你可以使用ST-LINK来达到这个目的。基于 http://www.st.com/resource/en/user_manual/dm00026748.pdf 它看起来第二个连接器(STM32的JTAG / SWD连接器)提供3.3V和GND(引脚19和20).Regards Szymon 以上来自于谷歌翻译 以下为原文 Hello Dmitriy, I am glad that you solved the issue. Indeed SWIM connector can't supply the MCU. This connector provides a VDD pin, but its purpose is not to supply the MCU, only to verify if MCU is already supplied. Typically MCU should be supplied from its own supply source, not from ST-LINK. However I believe that you can use ST-LINK for this purpose. Based on http://www.st.com/resource/en/user_manual/dm00026748.pdf it looks that second connnector (JTAG/SWD connector for STM32) provides both 3.3V and GND (pins 19 and 20).Regards Szymon |
2985 浏览 1 评论
3313 浏览 1 评论
1894 浏览 1 评论
3748 浏览 6 评论
6164 浏览 21 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
57浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
60浏览 5评论
92浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
60浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
56浏览 5评论
GMT+8, 2025-4-6 16:39 , Processed in 0.866078 second(s), Total 83, Slave 67 queries .
