你好
真的是冠军。 我有一个安装了7.13 VDA的Linux VM。 有谁知道如何启用H.264编码? 我会告诉我这不是一个Linux家伙,所以有可能误解了一些东西...... 我分配了M60 8Q配置文件,因此可以使用CUDA。 已安装GRID 4.1驱动程序并且已获得许可。 我正在关注本指南:http://docs.citrix.com/en-us/linux-virtual-delivery-agent/7-13/configuration/configuring-graphics.html 但是,当我尝试在VDA上运行时: sudo ctxreg create -k“HKLM System CurrentControlSet Control Citrix Thinwire”-t“REG_DWORD”-v“AdvertiseH264”-d“0x00000001”--force 我得到了回应: sudo:ctxreg:找不到命令 我最初的想法是,我正在尝试在Linux VM上安装Windows注册表项,当然它不起作用。 但是,作为一个非Linux的家伙,我其实不知道。 通常的说明并不像它们应该的那样清楚。 所以任何指导都表示赞赏 非常感谢 以上来自于谷歌翻译 以下为原文 Hi As title really. I have a Linux VM with 7.13 VDA installed. Does anyone know how to enable H.264 Encode? I'll caveat this by stating I'm not a Linux guy, so have more than likely misunderstood something ... I have an M60 8Q profile assigned so CUDA is available. GRID 4.1 drivers are installed and it's licensed. I'm following this guide: http://docs.citrix.com/en-us/linux-virtual-delivery-agent/7-13/configuration/configuring-graphics.html However, when I try and run this on the VDA: sudo ctxreg create -k "HKLMSystemCurrentControlSetControlCitrixThinwire" -t "REG_DWORD" -v "AdvertiseH264" -d "0x00000001" --force I get this in response: sudo: ctxreg: command not found My initial thoughts were, I'm trying to install a Windows registry key on a Linux VM, of course it won't work. However, as a non-Linux guy, I actually don't know. Instructions as usual aren't as clear as they should be. So any guidance is appreciated Many thanks |
得到了朋友的一点帮助......
对于使用Linux的任何其他人,您需要从此处运行命令:/ opt / Citrix / VDA / bin 然后根据上面的链接,运行: ctxreg create -k“HKLM System CurrentControlSet Control Citrix Thinwire”-t“REG_DWORD”-v“AdvertiseH264”-d“0x00000001”--force 那么这个: ctxreg create -k“HKLM System CurrentControlSet Control Citrix Thinwire”-t“REG_DWORD”-v“HardwareEncoding”-d“0x00000001”--force 启用它,然后检查它: ./ctxreg dump | grep HardwareEncoding 一切正常。 以上来自于谷歌翻译 以下为原文 Had a little help from a friend ... For anyone else playing with Linux, you need to run the command from here: /opt/Citrix/VDA/bin Then as per the link above, run this: ctxreg create -k "HKLMSystemCurrentControlSetControlCitrixThinwire" -t "REG_DWORD" -v "AdvertiseH264" -d "0x00000001" --force then this: ctxreg create -k "HKLMSystemCurrentControlSetControlCitrixThinwire" -t "REG_DWORD" -v "HardwareEncoding" -d "0x00000001" --force to enable it, and then this to check it: ./ctxreg dump | grep HardwareEncoding All working now. |
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3129 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3539 浏览 4 评论
GMT+8, 2024-12-26 00:45 , Processed in 0.631769 second(s), Total 77, Slave 61 queries .
