hi,all
最近遇到一个问题,需要求助大家。 f28377d最小系统板是自己做的,仿真器是xds100v3,CCS6.1,JTAG电路参考ti的, 仿真器连接DSP有时会连接不上,错误提示有以下3种 1: IcePick_C_0: Error connecting to the target: (Error -233 @ 0x0) The JTAG IR and DR scan-paths cannot circulate bits, they may be broken. An attempt to scan the JTAG scan-path has failed. The target's JTAG scan-path appears to be broken with a stuck-at-ones or stuck-at-zero fault. (Emulation package 6.0.14.5) 2: IcePick_C_0: Error connecting to the target: (Error -234 @ 0x0) The instruction scan-path cannot circulate bits, it may be broken. An attempt to scan the JTAG instruction registers has failed. The target's JTAG instruction path appears to be broken with a stuck-at-ones or stuck-at-zero fault. (Emulation package 6.0.14.5) 3: IcePick_C_0: Error connecting to the target: (Error -235 @ 0x0) The data scan-path cannot circulate bits, it may be broken. An attempt to scan the JTAG data registers has failed. The target's JTAG data path appears to be broken with a stuck-at-ones or stuck-at-zero fault. (Emulation package 6.0.14.5) 请问是什么问题导致的,如何解决?谢谢 |
5 个讨论
581 浏览 1 评论
419 浏览 1 评论
613 浏览 2 评论
900 浏览 3 评论
705 浏览 1 评论
181浏览 29评论
1144浏览 23评论
316浏览 20评论
277浏览 14评论
128浏览 13评论
GMT+8, 2025-2-1 01:50 , Processed in 0.806797 second(s), Total 51, Slave 45 queries .
