所有的,我将PIC32 MZ CPU连接到一个TFT显示器上,每种颜色都有6行,对应于一个RGB666图形模式。虽然总共有18个比特需要颜色信号,但是总共有24个I/O信号与图形接口相关,排列成RGB88。(1)在连接6位彩色显示器时,是否会掉下两个颜色信号?(2)我可以使用与未使用的颜色信号相关的PIN用于其他I/O目的吗?谢谢,加里
以上来自于百度翻译 以下为原文 All, I'm connecting a PIC32MZ CPU to a TFT display which has 6 lines for each color, corresponding to a RGB666 graphics mode. While there is a total of 18 bits required for the color signals, there are a total 24 I/O signals associated with the graphics interface, arranged as RGB888. The datasheets are not clear on two items... (1) Do I drop the lower or upper two bits of the color signals when interfacing the 6 bit color display? (2) Can I use the pins associated with the unused color signals for other I/O purposes? Thanks, Gary |
1)通常你放下Luest2)不确定…但可能是
以上来自于百度翻译 以下为原文 1) usually you drop the lowest 2) not sure... but could be |
5317 浏览 9 评论
2072 浏览 8 评论
1977 浏览 10 评论
3248 浏览 3 评论
2285 浏览 5 评论
830浏览 1评论
723浏览 1评论
669浏览 1评论
722浏览 0评论
618浏览 0评论
GMT+8, 2025-1-31 18:40 , Processed in 0.863120 second(s), Total 44, Slave 39 queries .
