大家好,我是新的PIC,所以请指导我如果我犯了任何错误。我试图产生一个PWM信号为500千赫频率。占空比在25%至50%的范围内的降压转换器(800 W)。我找不到PIC微控制器(8位优选),可以产生一个稳定的PWM为500公里。我的问题是,最大的PWM频率可以用PIC18、PIC16和PIC12微控制器产生,什么优化可能导致这个输出。此外,我需要计时器和时钟频率的计算。先谢谢你。
以上来自于百度翻译 以下为原文 Hi Everyone, I am new to the PIC so please guide me if I am making any mistake(s). I am trying to generate a PWM signal of 500Khz freq. with a duty cycle in the range of 25%to 50 % for a buck converter(800W). I cannot find a PIC microcontroller (8bit preferred) which can generate a stable PWM of 500Khz. my question is, what is the maximum PWM freq. that can be produced with pic18, pic16 and pic12 microcontrollers and what optimizations might lead to this output. Also, I need the calculations for timer and clock freq. required? Thank You in advance. |
3个回答
有一些PIC16设备,如PIC16F18855,可以在32 MHz时钟上运行。一个500 kHz的PWM可以产生如下:PRT + 1 = P/(ToSc* 4×PRES)=2000000 /(31250×4×1)=16,所以PRT= 15分辨率将是log(4×16)/log(2)=1.806 / 1.806=γ比特。
以上来自于百度翻译 以下为原文 There are some PIC16 devices, such as PIC16F18855, that can run on a 32 MHz clock. A 500 kHz PWM can be generated as follows: PRT+1 = PER / (TOSC * 4 * PRES) = 2000000 / (31250 * 4 * 1) = 16 so PRT = 15 The resolution will be log( 4 * 16 ) / log( 2 ) = 1.806 / 0.301 = 6 bits |
是的。在较早的PIC16,1MHz,但分辨率降低…
以上来自于百度翻译 以下为原文 Yep. On older PIC16, 1MHz but with reduced resolution... |
这意味着什么?你发现了一些不稳定的东西吗?我想不出任何一个8位PIC与PWM模块不能做一个500千赫PWM。唯一的区别因素是PIC能跑得多快,这给了你更多的占空比分辨率。一个64兆赫PIC18会给你7位的分辨率。
以上来自于百度翻译 以下为原文 What does that mean? Did you find some that are unstable? I can't think of any 8-bit PIC with a PWM module that can't do a 500 kHz PWM. The only differentiating factor is how fast the PIC can run, which gives you more duty cycle resolution. A 64 MHz PIC18 would give you 7 bits of resolution. |
5244 浏览 9 评论
2035 浏览 8 评论
1955 浏览 10 评论
3209 浏览 3 评论
2260 浏览 5 评论
779浏览 1评论
672浏览 1评论
598浏览 1评论
682浏览 0评论
579浏览 0评论
GMT+8, 2024-12-25 13:09 , Processed in 1.110753 second(s), Total 50, Slave 44 queries .
