嗨,我使用H3LIS200DL和RFduino(RFD22102)作为微控制器,我使用了数据手册中给出的原理图,除了我已经将CS引脚连接到Vdd(用于使用I2C)。我也使用下面附带的Arduino H3LIS331Dl_demo代码。
IC工作正常5分钟,然后读数变得不变。当我在10个小时后再次使用它时,它再次正常工作5分钟。这发生在3天之内。我也重新焊接了它并重新检查了电容器。 我用了3个IC。一个工作正常,但同样的问题发生在其他2。 这有焊接问题吗? 我错过了任何一点吗? 帮助将不胜感激。 H3LIS200Dl数据表: http://www.st.com/content/ccc/re ... 4.pdf/files/DM00162â€| RFD22102数据表: http://www.st.com/content/ccc/re ... 4.pdf/files/DM00162â€| 以上来自于谷歌翻译 以下为原文 Hi, I am using H3LIS200DL with RFduino (RFD22102 ) as microntroller, I have used the schematic given in data sheet except I have connected CS pin to Vdd (for using I2C). Also I am using Arduino H3LIS331Dl_demo code attached below. The IC works fine for 5mins and then readings become constant. And when I use it again after 10 hours or so, it again works fine for 5mins only. This is happening from 3 days. I have also resoldered it and rechecked the capacitors. I used 3 ICs. One worked fine but the same problem is happening with other 2. Is this any soldering problem? Am I missing any point? Help would be appreciated. H3LIS200Dl data sheet : http://www.st.com/content/ccc/re ... 4.pdf/files/DM00162… RFD22102 data sheet: http://www.st.com/content/ccc/re ... 4.pdf/files/DM00162… |
*更正
H3LIS200Dl数据表: http://www.st.com/content/ccc/resource/technical/document/datasheet/6c/e1/2a/9d/29/58/4e/25/DM00162194.pdf/files/DM00162194.pdf/jcr:内容/翻译/ en.DM00162194.pdf RFD22102数据表: http://www.rfduino.com/wp-content/uploads/2014/03/rfduino.datasheet.pdf 以上来自于谷歌翻译 以下为原文 *Correction H3LIS200Dl data sheet : http://www.st.com/content/ccc/resource/technical/document/datasheet/6c/e1/2a/9d/29/58/4e/25/DM00162194.pdf/files/DM00162194.pdf/jcr:content/translations/en.DM00162194.pdf RFD22102 data sheet: http://www.rfduino.com/wp-content/uploads/2014/03/rfduino.datasheet.pdf |
2747 浏览 1 评论
3244 浏览 1 评论
1813 浏览 1 评论
3655 浏览 6 评论
6045 浏览 21 评论
1342浏览 4评论
204浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
359浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
451浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
277浏览 2评论
GMT+8, 2024-12-29 18:40 , Processed in 1.066130 second(s), Total 77, Slave 61 queries .
