嗨,我刚开始用PIC单片机。我有一个带有ICD3的LCD Explorer开发板,我想知道在MPLAB窗口中有一种打印输出的方式,就像我们通常在ARDUIO串行监视器中那样吗?谢谢
以上来自于百度翻译 以下为原文 Hi There, I am just getting started with PIC microcontrollers. I have a LCD Explorer Development board with ICD3, and I'm trying to figure out is there a way to print output in MPLAB Window like we generally go in ARDUINO serial monitor? Thanks |
最近我听到一些关于使用调试接口的谣言……但通常的方法是将串行USB转换器附加到一个UART中,并使用这个UART与调试器接口并行。阿杜诺IDE。MPLAB允许对代码的工作进行更深入和更直接的洞察。但是我必须承认:如果你使用UART来获得一些“进度信息”,这很难通过MPLAB来实现。这是简单地使用一个UART用于打印()与调试器连接并行的选项的地方。
以上来自于百度翻译 以下为原文 I recently heard some rumours about using the debug interface for such things... But the usual way would be to attach a serial-to-USB converter to one of the UARTs and use this UART parallel to the debugger interface. To word it: developing with ICDx or PICkitx is different from the way you develop in the ARDUINO IDE. MPLAB allows for a much deeper and more "immediate" insight into the workings of your code. But I have to admit: if you use the UART to get some "progress information", this is hardly doable via MPLAB. This is where the option to simply use one of the UARTs for print()'ing - parallel to the debugger connection - comes handy. |
嗨,你有哪些LCD资源管理器:参考?图片?你的LCD浏览器上有哪张图片?当做
以上来自于百度翻译 以下为原文 Hi, Which LCD explorer do you have : reference ? picture ? Which PIC is on your LCD explorer ? Regards |
5066 浏览 9 评论
1946 浏览 8 评论
1880 浏览 10 评论
3106 浏览 3 评论
2177 浏览 5 评论
620浏览 1评论
496浏览 1评论
352浏览 1评论
522浏览 0评论
428浏览 0评论
GMT+8, 2024-9-23 08:24 , Processed in 1.308353 second(s), Total 80, Slave 64 queries .
