当不使用无线电时,R4核心@ 3MHz的功耗是多少?
我将用R4在主动模式下做大量的工作,每隔5到10秒只发送一次数据包。我找不到一个关于核心有功功耗的指标。 谢谢, 迈克 以上来自于百度翻译 以下为原文 What is the power consumption of the R4 Core @ 320Mhz when not using the radio? I will be doing a lot of work with the R4 in active mode and only transmitting packets every 5 to 10 seconds. I can't find an spec on the core active power consumption. Thanks, Mike |
7个回答
姆罗伯茨箭头
请检查如CYW43907/CYW54 907产品指南中提到的功耗数字。假设您已经通过了电源文档,仍然找不到用例,您可以通过在EVK中编程示例应用程序来测量电源。如果你在这方面遇到困难,请告诉我们。 以上来自于百度翻译 以下为原文 mroberts_arrow Please check the power consumption numbers as mentioned inCYW43907/CYW54907 Product Guide. Assuming you have already gone through the power document and still could not find the use-case, you can always measure the power by programming your sample application in the EVK. Please let us know if you face any difficulty in that. |
chm5 发表于 2018-9-13 12:05 没有收音机,我找不到任何R4活动电流的规格。所以你说要测量一个EVE板。,R4核心电流不规范会将给我1板的一个典型的数字。没有一个好的号码为最坏的情况在现场选择正确的电源或电池。 以上来自于百度翻译 以下为原文 I couldn't find any specs for the R4 active current without the radio. So you are saying to measure an eval board. That the R4 core current is not spec'd. That will give me a typical number for 1 board. Not a good number to choose the correct power supply or battery for a worst case situation in the field. |
60user169 发表于 2018-9-13 12:14 姆罗伯茨箭头 R4核心电流号在数据表(CYW43907数据表(2.4/5GHz,802.11b/g/n,带有嵌入式ARM CORTEX-R4应用处理器)中指定),如果您检查表33-39。如果您想检查您的具体使用情况,我的建议是测量相同的R41,R55,如在低功耗电流测量使用CYW943907AEV1F。 以上来自于百度翻译 以下为原文 mroberts_arrow The R4 core current numbers are specified in the datasheet (CYW43907 Data Sheet (2.4/5GHz, 802.11b/g/n with Embedded ARM Cortex-R4 Application Processor) ) if you check Table 38-39. If you want to check your specific use-case, my suggestion was to measure the same across R41, R55 as mentioned in Low Power Current Measurements Using CYW943907AEVAL1F . |
chm5 发表于 2018-9-13 12:27 在2.4和5GHz以下的无线电关断值是否正确? 以上来自于百度翻译 以下为原文 Radio Off value at both 2.4 and 5GHz per below correct rroy? |
好啊。我看见那些桌子了。你能告诉我,从这些表中,什么是当前的消费R4核心@ 3MHz活动模式@ 3.6V与无线电关闭?这就是我正在寻找的一切。 谢谢, 迈克 以上来自于百度翻译 以下为原文 OK. I saw those tables. Can you tell me, from those tables, what is the current consumption of the R4 core @ 320Mhz active mode @ 3.6V with the radio off? That is all that I am looking for. Thanks, Mike |
60user169 发表于 2018-9-13 12:43 谢谢你指出正确的部分。 嘿,罗伯茨 你正在寻找2.4 GHz的数字:302900 UA和5 GHz:312000 UA。 以上来自于百度翻译 以下为原文 mifo Thanks for pointing out the correct sections. Hey mroberts_arrow The number you are looking for 2.4 GHz : 302900 uA and for 5 GHz: 312000 uA. |
我将使用这些值,即使它们与TX收音机有关,但我希望您能理解,没有应用程序处理器本身没有无线电的规格。 以上来自于百度翻译 以下为原文 I will use those values even though they are with the TX radio on, but I hope that you can understand that there no spec for the Apps processor by itself with no radio. |
760个成员聚集在这个小组
加入小组2152 浏览 1 评论
1900 浏览 1 评论
3721 浏览 1 评论
1833 浏览 6 评论
1578 浏览 1 评论
786浏览 2评论
543浏览 2评论
486浏览 2评论
445浏览 2评论
1189浏览 2评论
GMT+8, 2025-3-4 02:30 , Processed in 1.154378 second(s), Total 110, Slave 94 queries .
