我的MyPrim3不再被我开发的一台开发机器所识别。它在另一个方面起作用。我想也许如果我继续更新PSoC程序员,可能会安装一个更新的驱动程序。
当我试图通过CyPress更新管理器更新PSoC程序员时,我不断地得到服务器错误。有时在更新过程中的不同点,有些是在开始时,有时是在下载第一个文件之后。我的同事也得到了这些更新服务器错误。CyPress更新服务器现在在下降吗? 以上来自于百度翻译 以下为原文 My MiniProg3 stopped being recognized by one of the development machines I use. It works on another. I thought maybe if I went ahead and updated PSoC Programmer, an updated driver would be installed possibly that the machine it was working on had. When I attempt to update PSoC Programmer through Cypress Update Manager, I keep getting server errors. Sometimes at different points in the update process, some right at the beginning, sometimes after it's downloaded the first file. My coworker is also getting these update server errors. Are the Cypress update servers down at the moment? |
请尝试从这个链接安装PSoC Programmer:
HTTP://www. CyPress .COM/PROSPIDS/PSOC编程解决方案 以上来自于百度翻译 以下为原文 Please try to install PSoC Programmer from this link: http://www.cypress.com/products/psoc-programming-solutions |
756个成员聚集在这个小组
加入小组2129 浏览 1 评论
1871 浏览 1 评论
3687 浏览 1 评论
1806 浏览 6 评论
1552 浏览 1 评论
622浏览 2评论
460浏览 2评论
455浏览 2评论
408浏览 2评论
1099浏览 2评论
GMT+8, 2025-1-23 12:17 , Processed in 0.786929 second(s), Total 43, Slave 38 queries .
