当前环境;
戴尔R730,E5-2695 v3 2.3ghz 14核x 2,768GB内存,2 x 10GB NICS XenServer 7.0,Windows 2012 R2和XenApp 7.13 2 x Nvidia Grid K1,带有GPU直通功能 适用于XenApp服务器的Compellent SAN和SSD 我们有7个R730,并将Grid K1划分为8个虚拟机,每个虚拟机运行大约8-9个用户。 我们是一家建筑公司,我们所有的设计人员都在Citrix内部工作。 我们运行AutoCAD 2017,Revit 2017,3DS Max 17和其他设计工具。 我们现在发现,在与Autodesk联系时,我们在获得支持方面遇到了问题,因为他们建议自Autodesk 2015产品以来尚未支持Grid K1卡。 我们正在调查我们的选项,但随着网格的变化和需要许可证,以及可用的卡片,我们正在寻找一些建议。 由于Grid K1的支持问题,我们一直在寻求用M10 GPU取代它们。 我们担心下一代特斯拉P卡,即P100现在可用,并且不想购买可能具有短保质期的东西。 M10仍然是最合适的还是我们会更好地看待另一个范围? 我们还阅读了www.poppelgaard.com上的博客,其中详细介绍了Grid 5.0的变化。 我们能否澄清XenApp需要哪些许可证? 我们是否需要vApp记住我们只提供已发布的桌面? 非常感谢 以上来自于谷歌翻译 以下为原文 Current Environment; Dell R730, E5-2695 v3 2.3ghz 14 cores x 2, 768GB Memory, 2 x 10GB NICS XenServer 7.0, Windows 2012 R2 and XenApp 7.13 2 x Nvidia Grid K1 with GPU Pass-Through Compellent SAN with SSD for XenApp Servers We have 7 x R730's and divide the Grid K1 into 8 virtual machines each running around 8 - 9 users. We are an architectural firm and all of our design staff work inside Citrix. We run AutoCAD 2017, Revit 2017, 3DS Max 17, and other design tools. We are now finding that when contacting Autodesk we are having problems obtaining support as they are advising that the Grid K1 cards haven't been supported since Autodesk 2015 products. We are now investigating our options, but with the changes in Grid and requiring licenses, and the available cards we are looking for some advice. Due to the support issues with the Grid K1 we have been looking at replacing these with the M10 GPU. We are wary that the next generation Tesla P cards, i.e. P100 are now available and don't want to purchase something which may have a short shelf life. Are the M10's still the best fit or would we be better looking at another range? We have also read the blog on www.poppelgaard.com which details the change with Grid 5.0. Can we clarify which licenses we require for XenApp? Would we require vApps bearing in mind we only provide a published desktop? Many Thanks |
嗨迈克,
vApp许可是XenApp的正确选择。 总的来说,我认为Autodesk根本不支持他们在ServerOS上的产品。 根据使用这些产品的用户工作负载,如果您需要更多渲染能力,可以考虑使用Tesla P40,或者您可以将Tesla M10用于中等工作负载。 Tesla P100是双精度应用的特定用例,因此不是您的方案中的最佳选择。 问候 西蒙 以上来自于谷歌翻译 以下为原文 Hi Mike, vApps licensing is the right choice for XenApp. In general I don't think Autodesk supports their products on ServerOS at all. Depending on the users workloads with these products it might make sense to think about Tesla P40 if you need more rendering power or you can use the Tesla M10 for moderate workloads. Tesla P100 is a specific use case for double precision applications and therefore not the best choice in your scenario. Regards Simon |
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3176 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3587 浏览 4 评论
GMT+8, 2025-2-24 06:02 , Processed in 0.421793 second(s), Total 42, Slave 37 queries .
