你好,
有关于特斯拉板上视频编码器单元的信息吗? 关于它们支持多少流,分辨率和帧速率? 如果所有编码器单元都忙,Citrix VDA上的CPU编码是否会回退? 谢谢, Korbinian 以上来自于谷歌翻译 以下为原文 Hello, are there informations available about the video encoder units on Tesla Boards? About how much streams they support, in which resolution and frame rate? Is there a fallback to CPU encoding on Citrix VDA if all encoder units are busy? Thanks, Korbinian |
5个回答
目前,NVENC没有CPU回退。
这里提到了编码/解码引擎:https://developer.nvidia.com/video-encode-decode-gpu-support-matrix 此外,您还需要特定芯片的性能概述。 因此,您需要下载包含PDF文档的Video Codec SDK。 https://developer.nvidia.com/nvidia-video-codec-sdk 以上来自于谷歌翻译 以下为原文 Currently there is no CPU fallback for NVENC. The encoding/decoding engines are mentioned here: https://developer.nvidia.com/video-encode-decode-gpu-support-matrix In addition you need the performance overview for the specific chips. Therefore you need to download the Video Codec SDK which contains the PDF documentation. https://developer.nvidia.com/nvidia-video-codec-sdk |
谢谢。
性能概述的分辨率为1080p。 我可以从两个1440p屏幕的编码中得到什么? 以上来自于谷歌翻译 以下为原文 Thanks. The performance overview is for a resolution of 1080p. What can I expect from a encoding of two 1440p screens? |
计算?
当前数字除以4应该接近。 但是你真的希望在2个屏幕上拥有30fps的相同内容吗? 以上来自于谷歌翻译 以下为原文 Calculate? Current numbers divided by 4 should come close. But do you really expect to have same content with 30fps for example on 2 screens? |
因此,如果编码器可以达到约600fps @ 1080p,那么可能的NVENC流数量是这个数字除以此分辨率下的平均帧速率?
如果最大帧速率超过,则所有会话/流的帧速率会下降? 以上来自于谷歌翻译 以下为原文 So if a encoder can achieve about 600fps@1080p, the number of possible NVENC streams is this number divided by the average frame rate at this resolution? And if the maximum frame rate exceeds, the frame rate drops for all session/streams? |
正确。
根据电路板(例如M60),它不太可能达到编码器容量,但我们正在为未来的GRID版本开发一个后备方案。 问候 西蒙 以上来自于谷歌翻译 以下为原文 Correct. Depending on the board (M60 for example) it is very unlikely to hit the encoder capacity but we're working on a fallback scenario for a future GRID release anyway. Regards Simon |
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3272 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3704 浏览 4 评论
GMT+8, 2025-7-6 06:50 , Processed in 0.760630 second(s), Total 82, Slave 66 queries .
