你好,
我试图通过SPI发送数据到一个使用端口扩展器的LCD屏幕。 有人能帮助我做些什么指导吗? 我使用Microchip的MCP23 S17扩展器,我打算连接它是根据我上传的方案。 该芯片是CY8C634 7BZI BLD53。 感谢您的任何帮助。非常感谢。 最好的问候。 示意图 166 K 以上来自于百度翻译 以下为原文 Hi, I am trying to send data via SPI to a LCD screen using a port expander. Can anyone help with some guidance as to how I can do it? I am using Microchip's MCP23S17 expander and the way I intend to connect it is according to the scheme I uploaded. The chip is CY8C6347BZI-BLD53. Thanks in advance for any help. It is much appreciated. Best regards.
你好,马尔科,
请开发一个低级别的API来显示LCD总线上的数据。这将涉及三个传输,使能信号切换,其余的信号是相同的。请参考MCP23 S17数据表来设置串行-并行转换器和传输数据。如果你有任何问题,请利用Microchip资源。 基于此API,您可以开发两个API,(1)用于定位游标,以及(2)将字符写入LCD。您可以参考HD44 780的数据表以获得所需的波形。 最好的问候, 吉娜玛丽 以上来自于百度翻译 以下为原文 Hello Marko, Please develop a low level API to present a data on the LCD bus for writing. This will involve three transfers, with a enable signal toggling and the rest of the signals being the same. Kindly refer to MCP23S17 datasheet to setup the serial parallel converter and to transfer the data. If you have any issue, kindly make use of Microchip resoures. Based on this API you can develop two more APIs, (1) for positioning the curser, and (2) to write characters to the LCD. You may refer to the datsheet of the HD44780 for the required waveforms. Best Regards, Geona Mary |
741个成员聚集在这个小组
加入小组2004 浏览 1 评论
1766 浏览 1 评论
3552 浏览 1 评论
1697 浏览 6 评论
1466 浏览 1 评论
277浏览 2评论
171浏览 2评论
355浏览 2评论
299浏览 2评论
488浏览 2评论
GMT+8, 2024-9-22 07:09 , Processed in 0.774826 second(s), Total 76, Slave 60 queries .
