亲爱的柏树。
我对BC1.2的针带设置有疑问。 请确认并回答以下问题。 Q1) 请让我们知道如何使可行性(SDP,DCP,CDP)用针带? Q2) 当CDP失效时,DCP在这个时间会失效吗? 或者DCP成为启用的? Q3) 有没有办法通过使用针带来启用DCP? Q4) 它可以控制所有可行性模式(SDP,DCP,CDP)只有销带设置? Q5) 下面是DS的表6。 两个条件上市条件下带“0”。 参考下表,CDP是启用或禁用在紧张的“0”。 我看不懂桌子下面的意思。 我应该怎么看待CDP针带设置? 最好的问候。 松塔 以上来自于百度翻译 以下为原文 Dear Cypress. I have questions about pin strap setting for BC1.2. Please confirm and answer below questions. Q1) Could you please let us know how to enable BC1.2(SDP, DCP, CDP) by using pin strap? Q2) When CDP desabled, does DCP become disable in this time? Or does DCP become enable? Q3) Is there a way to enable DCP only by using pin strap? Q4) Is it possible to control all BC1.2 modes(SDP, DCP, CDP) with only pin strap setting? Q5) Below is Table 6 of DS. Two conditions are listed under the condition of strapped ‘0’. Refer to below table, CDP becomes enabled or disabled at strapped ‘0’. I could not understand a meaning of below table. What should I think about CDP pin strap setting? Best Regards. Yutaka Matsubara |
5个回答
你好,
A1 请参阅数据表上的第24页。 HX3可以使用下列之一来配置: FEUSES(一次性可编程存储器) 针带(从电源上的专用引脚读取配置) 外部的I2C从属,如EEPROM 外部I2C主控器 A2 您可以在每个端口上设置DCP或CDP。 A3 不,没有。 A4 我在回答3的时候说不,所以也没有。 A5 请看注释[15 ]:当pWRYSWSWOPL设置为低电平时,DSXY-CDPGEN将是低电平有效输入;同样地,当pWRYSWSWOPL设置为活动高电平时,DSXY-CDPGEN将是高活性的高输入。 也就是说, PWRYSWSWOPOL=低和DSXY-CDPGEN=0,启用了DSx’PIN CDP。 PWRYSWSWOPL=低和DSXY-CDPGEN=1,DSX’PIN CDP被禁用。 PWRYSWSWOPOL =高和DSXY-CDPGEN=0,DSX’PIN CDP被禁用。 PWRYSWSWOPOL=高和DSXY-CDPGEN=1,启用了DSx’PIN CDP。 最好的问候, 高山弘 以上来自于百度翻译 以下为原文 Hi, A1. Refer to page 24 on the datasheet. HX3 can be configured by using one of the following: ■ eFuse (one-time programmable memory) ■ Pin-Strap (read configuration from dedicated pins at power on) ■ External I2C slave such as an EEPROM ■ External I2C master A2. You can set DCP or CDP on each port. A3. No, there is not. A4. I said No on Answer 3, so it is also No. A5. Please look at remark [15]: DSx_CDP_EN will be active LOW input when PWR_SW_POL is set to active LOW; similarly DSx_CDP_EN will be active HIGH input when PWR_SW_POL is set to active HIGH. That is, PWR_SW_POL = LOW and DSx_CDP_EN = 0, DSx' pin CDP is enabled. PWR_SW_POL = LOW and DSx_CDP_EN = 1, DSx' pin CDP is disabled. PWR_SW_POL = HIGH and DSx_CDP_EN = 0, DSx' pin CDP is disabled. PWR_SW_POL = HIGH and DSx_CDP_EN = 1, DSx' pin CDP is enabled. Best regards, Hirotaka Takayama |
Q1 α,α,β,β,β? SDP、DSP Q2 DCP 〔1〕 Q3) CDP,γ,β,DCP,α,β,α,α,β,β EEPROM? 一、二、二、二、二、三、二、三、四、四、四、四、 CDPα? Q4) 一、二、二、二、二、二、二、二、二、二、二、三、二、四、六、六、六、六、六、六、六、六、六、六、六、六、六、六、六、六、六、六、六、六、六、六、六、六、六、六、六、六、六、六、八、三、四、八、三、四、八、八、三、四、八、六、六、六、四、四、八、八、八、四、四、六、六、六、八、 一、二、二、三、六、六、六、六、六、六、六、六、六、六、六、六、六、六、六、六、六、六、六、六、六、六、四、六、六、六、六、六、六、六、六、六、六、六、… “1”字形“BC1.2” 以上来自于百度翻译 以下为原文 Q1 ピンストラップで設定できるのはCDPだけ、という事でしょうか? SDP、DSPはピンストラップでは設定できないのでしょうか? Q2 DCPだけを有効にする方法はないとの事ですが、 下図のDCP_EN[3:0]だけを"1"にしてDCPだけを有効にする事も出来ない、という事なのでしょうか? Q3) CDPを無効にした時、DCPは無効、有効どちらになるのでしょうか。 EEPROMの設定値によるのでしょうか? ただDCPだけを有効にする方法はないとの事でしたので、 CDPを無効にした場合はDCPは必ず無効になるのでしょうか? Q4) ピンストラップの設定でBC1.2の有効、無効の切り替えは出来ないという理解で良いでしょうか? 切り替える場合はEEPROMの設定を変更する必要がある、という理解で良いでしょうか? また特に何もしなければデフォルト値が"1"なのでBC1.2は有効になっているという理解で良いでしょうか? |
A1 α,α,β,β,α,β,α,β,β,α,β,β; A2 一、二、二、二、二、二、二、二、二、二、二、二、二、二、二、二、二、二、二、二、二、二、二、二、二、二、二、二、二、二、二、二、二、 你可以在每个端口上设置DCP或CDP。 第二、第二、第二、第二章、第二章、第二章、第二章、第二章、第三章、第二章、第二章、第二章、第二章、第二章、第二章、第三章、第二章、第二章、第二章、第二章、第二章、第二章、第二章、第五章、第二章、第五章、第五章、第五章、第五章、第二章。 AN92554α-π介子α。 “Hx3,β,β,α,β,β,β,β,α,β,β,β α,α,α,β,α,β,β,α,β,β,β,α,β,β,α,β,β,β,α,β,β,β,α,β,β,β,α,β,β,α,β,β,β,α,β,β,β,α,β,β,α,β,β,β,α,β,β,βγ射线。 B~(1) A3 一种新的方法,即一种方法。 A4 第二类是: 高山弘 以上来自于百度翻译 以下为原文 A1. はい、データシートに記述されている通り、CDPだけがピンストラップで設定可能です。 A2. いいえ、DCPだけを有効にすることは可能です。 「You can set DCP or CDP on each port.」という文章が短すぎて正しく意図が伝わりませんでした。すみません。 意味としては、各ダウンストリームポートはDCPかCDPかSDPのいずれかとして機能するということを言っています。 AN92554をご参照ください。以下の記述がPage6にございます。 ”HX3 はグローバルおよび独立した (それぞれの個別ポート用)ポート パワーコンフィギュレーション オプションの両方を提供して充電サポート (SDP, CDP またはDCP) を制御します。 グローバル コンフィギュレーション オプション「BC_ENABLE」はすべてのダウンストリーム ポートの充電サポートを制御するために使用されます。このビットがクリアされた時、すべてのダウンストリーム ポートはSDP として動作します。 「BC_ENABLE」が「1」にセットされた時、それぞれの個別のダウンストリーム ポートの充電サポートはポートのコンフィギュレーション オプション 「DCP_EN」と「CDP_EN」によって異なります。” A3. 各ダウンストリームポートはDCPかCDPかSDPのいずれかとして機能しますので、複数のモードが同時並行で機能はしませんが、CDP_ENとDCP_ENを同時に1にすることは可能です。 A4. はい。全てご認識いただいている通りです。 Hirotaka Takayama |
一、二、二、二、三、二、四、六、六、六、四、四。 EEPROM? α? EEPROM α,γ,β,CDP,γ,π? α,β,α,β,β; 以上来自于百度翻译 以下为原文 回答有難う御座います。 EEPROMとピンストラップではどちらが優先されるのでしょうか? ピンストラップの設定が優先されますでしょうか? EEPROMの設定でSDPもしくはDCPになっていたとしても ピンストラップでCDPを有効にするとそのポートはCDPとして動作しますでしょうか? どうか宜しくお願いします。 |
第二类配置选项。 I2C,β,α,β,β,α,β,β,β α,α,α,α,α,α,β,α,β,α,β,α,β,α,β,α,β,α,α,β,α,β,α,β,α,β,α,α,β,α,β,β EFEX,γ,α,β,α,β,α,β,α,β,α,β,α,β,β α,ε,EEPROM。 高山弘 以上来自于百度翻译 以下为原文 データシートのConfiguration Optionsをご確認ください。 I2C マスター/スレーブのコンフィギュレーションはピンストラップのコンフィギュレーションをオーバーライドします。 ピン ストラップはeFuse コンフィギュレーションをオーバーライドします。 eFuse コンフィギュレーションは内部ROMコンフィギュレーションをオーバーライドします。 つまり、EEPROMが優先されます。 Hirotaka Takayama |
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1761 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
275浏览 2评论
170浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-21 00:42 , Processed in 0.816569 second(s), Total 54, Slave 48 queries .
