你好
我正在研究一个PSoC040S ValueKIT(4045),它的程序例子是“CE210311O-CAPENSESEP4PADYAXCONTELAL01”。 我已经用CY8CMBR31 16的固定编程IC做了一些CAPSESE经验。 用CY8CMBR31 16-如果改变或拿走覆盖(例如从4mm改变到10mm玻璃),它大约4-5秒,并且所有的感觉被重新校准到0个差异,并且我可以触摸并得到正确的检测。 现在,随着可编程PSOC4000的重新校准时间更长,因此如果改变或拿走覆盖/玻璃采取APROX 2-3min,直到所有传感器校准,相应地复位到0个差异。 那么,我可以在哪里安装,或强制复位,如果检测到去校准(例如删除覆盖等)? 或者我可以调用一个函数来强制校准吗? 非常感谢 以上来自于百度翻译 以下为原文 Hello I am working on a PSOC4000S Evalkit (4045) with programm-example "CE210311_CapSense_P4_ADC_Sequential01" I already did some Capsense experience with a fix programmed IC like the CY8CMBR3116. With the CY8CMBR3116 - if change or take away the Overlay (for example change from 4mm to a 10mm Glass) it tooks about 4-5seconds and all sense was recalibrated to 0 diffcounts and I could touch and got correct detections again. Now with the programmable PSOC4000S the recalibration time is much longer, so if change or take away the overlay/glass it takes aprox 2-3min until all sensors are calibrated, respectievly reseted to 0 diffcounts. So where can I setup, or force a reset if a decalibration is detected (e.g. removed overlay etc.)? Or is there a function I can call to force a calibration? thank you very much |
4个回答
嗨,Pierre Kaeser,
如果您使用Smart Stand(全自动调谐),每当您改变CAPSENSE传感器的环境时,您应该用新参数重新校准CAPSENSE块。要做到这一点,只需调用API CAPENSESE-STATE()。在调用CAPENSESEA START()API调用API CAPENSESSION()之前。 谢谢 加内什 以上来自于百度翻译 以下为原文 Hi Pierre Kaeser, If you are using Smart sense (Full Auto tune) , whenever you change the environment of the CapSense sensors you should recalibrate the CapSense block with the new parameters. To do this just call the API CapSense-Start(). Before calling the CapSense_Start() API call the API CapSense_Stop(). Thanks Ganesh |
huhuiyun 发表于 2018-9-12 09:13 无论何时改变CopSoSE传感器的环境,都应该重新校准CAPSENSE。 是否还存在一个检测环境是否发生变化的函数?或者我需要用我自己的程序代码来检测吗? 非常感谢 以上来自于百度翻译 以下为原文 whenever you change the environment of the CapSense sensors you should recalibrate the CapSense is there also a function available which detect if the environment has changed or not? - or do I need to detect that with my own programm-code? thank you very much |
cmh11 发表于 2018-9-12 09:26 我怀疑你可能会读一些原值从电容感应来检测环境的变化,而是一种或另一种方式,它是由用户来处理环境变化检测/补偿(如果我没记错的话)。 以上来自于百度翻译 以下为原文 I suspect you might be able to read some of the raw values from the capsense to detect changes in the environment, but one way or another, it is left up to the user to handle the environment change detection/compensation (If I am not mistaken). |
cmh11 发表于 2018-9-12 09:26 你好, 通过观察原始计数,可以在应用程序运行时检测环境变化。但如果有断电事件或任何复位事件,CapSense的参数将被重新配置,根据目前的环境。所以在检测环境的变化,不应该有任何断电或复位事件。 谢谢 加内什 以上来自于百度翻译 以下为原文 Hi, It is possible to detect the environment change while the application is running by observing the raw counts. But if there is power off and on event or any reset event, the CapSense parameters will be reconfigured according to the present environment. So while detecting the environment changes there should not be any power off or reset event. Thanks Ganesh |
741个成员聚集在这个小组
加入小组2004 浏览 1 评论
1766 浏览 1 评论
3552 浏览 1 评论
1697 浏览 6 评论
1466 浏览 1 评论
277浏览 2评论
173浏览 2评论
355浏览 2评论
299浏览 2评论
488浏览 2评论
GMT+8, 2024-9-22 15:27 , Processed in 0.587895 second(s), Total 51, Slave 46 queries .
